Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Drivetrain
Old 01-01-2012, 10:09 PM   #1
JASWRX
Member Sales Rating: (17)
Member#: 40742
Default TSK2 Snout Repair Kit ( throwout/release bearing for turbo 5MT Legacy/WRX/Forester
I am selling my TSK kit I just purchased in November. I no longer need it as I am using the 6 speed transmission. If you don't know about this part, read here: http://www.subaruwrxparts.com/shop/p...ry=235#details
$100.00 shipped.
THE PROBLEM:
These are the most common symptoms associated with a damaged or grooved quill on a transmission. It is also referred to as the snout, bearing carrier, or case extension. In most cases it is an integral part of the transmission case & cannot be replaced. The logical solution is to replace the case or the transmission. Both options are expensive & time consuming, neither of which solves the problem permanently.
THE CAUSE:
In the operation of the clutch, the release or throw-out bearing slides on the clutch snout or quill, allowing you to engage and dis-engage the clutch mechanism. Due to various reasons the quill becomes grooved over time. If the quill were made of a harder metal than aluminum, this would not be as common. The most common causes are: improper clutch adjustment, defective clutch assemblies, stop & go traffic, keeping your foot on the clutch (commonly referred to as riding the clutch), loss of lubricant, heat, & etc.
THE EFFECT:
The effects of these grooves on the clutch operation are catastrophic. They cause: premature clutch disc wear, premature bearing failure (further adding to the problem), sticky &/or jerky pedal travel, rattling clutch forks, transmission damage, etc.
THE SOLUTION:
The Transmission Sleeve Kit (TSK) solves this problem by utilizing a sleeve, precision machined out of 303 Stainless steel, which slips over the original quill. This provides a smooth, hard surface for the oversize bearing to slide on. It is anchored with set screws and is removable & re-usable. As in the case of the Subaru, it must be removed in order to allow any transmission repairs.
THE RESULTS:
After installing the Transmission Sleeve Kit (TSK) you have eliminated the problem forever! You will notice a smooth, fluid like, feel to the pedal. Your engagements will be smoother. Your clutch will last longer. This in turn, will reduce the wear on your transmission. It will never groove again!
THE KIT:
The kit comes complete with a 303 Stainless steel sleeve, set screws & , oversized release bearing for the 5 spd transmission.
Replaces Subaru part #: 30502AA080/ 30502AA130
Fits: 1992-1994 Turbo Legacy, WRX models with 5 speed transmission prior to May 2005 Production, Turbo Forester prior to January 2005 Production.
JASWRX is offline   Reply With Quote
Old 01-09-2012, 01:47 AM   #2
JASWRX
Member#: 40742
had a few people PM, but none came through...
Old 01-10-2012, 10:05 AM   #3
Ongbak
Member Sales Rating: (2)
Member#: 253376
2005 Lgt
PM sent
Ongbak is offline   Reply With Quote
Old 01-10-2012, 11:51 AM   #4
Scoobyjohn
Member#: 298621
What's the difference between the tsk2 and the latest tsk3? Thank you
Scoobyjohn is offline   Reply With Quote
Old 01-10-2012, 08:23 PM   #5
JASWRX
Member#: 40742
pending sale...
Old 01-11-2012, 09:25 AM   #6
omahasubaru
Member Sales Rating: (6)
Member#: 1594
1995 WRX
2002 Legacy
The number after TSK designates fitment differences, that is it.
omahasubaru is offline   Reply With Quote
Old 01-11-2012, 01:46 PM   #7
JASWRX
Member#: 40742
sold....
Turbo Snout repair kit ralliboi Drivetrain 2 02-08-2010 11:25 AM
Clutch Snout Repair kits? Anyone buy one latey? HamFist Transmission (AT/MT) & Driveline 8 05-30-2007 08:18 PM
anyone heard of TranQuil Snout Repair kit DaFastOne Transmission (AT/MT) & Driveline 5 05-24-2006 01:53 PM
Tranny Snout Repair Kit - Still Sold? SOLUTION Transmission (AT/MT) & Driveline 3 12-02-2005 02:40 PM
Clutch Throwout/Release bearing Mapplex Private 'For Sale' Classifieds 0 08-12-2003 10:35 PM
