Old 01-01-2012, 11:57 PM   #1
amnvince88
Member#: 289978
2006 Sti
Exclamation Clutch will NOT engage in any gear!!! *HELP PLEASE**
Please help before I start pulling my hair out, thanks in advance....
The Car:
06 sti 6/mt
stock clutch(as far as I know)
stock trans(as far as I know)
~290whp
~300wtq
Background:
-Having the "smell" of a burning clutch for a few thousand miles during normal driving, I haven't been beating on it much. (my questions start)
-started noticing "rough engaged from N to 1st & 2nd about 200miles ago
-had a tech at my local shop adjust the clutch pedal to give more free play...it was releasing high-two weeks ago
Maintenance/mods since:
-installed a kartboy SS two weeks ago
-changed grearbox fluid w/ Extra S
-dropped pan to clean the magnet, ~2 tablespoons of shavings(most likely origanal fluid)
-used grey trans pan gasket maker rtv to seal it.
TODAY:
-So up until today the car was fine......then all of a sudden my car lost power......my rpms were still rising(3-5K) in 4th but i was struggle to go 20 miles an hour!!!!!
-This happens in every gear...I shift the tranny goes into gear fine and easy but then the car doesn't go anywhere....just the RPMs, they are in sync will the gas pedal as normal.
-I checked the fluid, it was foamy indicating I over serviced it, so I drained it to exactly the "full" line. drove it around the block.....same condition
-I have a clutch in my online shopping cart ready to buy, but I want to confirm that there is no other things to check before I do.
So, please if you have any knowledge of this please help, I'm pissed b/c this is my DD and I dont want to drop $1k if I dont have too. thanks guys
Vince
amnvince88 is offline   Reply With Quote
Old 01-02-2012, 02:05 AM   #2
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Sounds like your clutch said goodbye. Not too difficult to interpret.
4wdrift is offline   Reply With Quote
Old 01-02-2012, 01:01 PM   #3
5.0Ranger
Member#: 93546
08 wrx
pearl white
^^^^agree. its pretty easy to see your clutch is done.
5.0Ranger is offline   Reply With Quote
Old 01-04-2012, 11:55 AM   #4
amnvince88
Member#: 289978
2006 Sti
Yeah. Just wanted to make sure... just seemed wierd I can still shift great and the pedal feels normal...but I'm pulling the tranny now(stuck trying to seperate the eng&trans....thanks guys.
Installed engine- now clutch will not engage... crane550 Normally Aspirated Powertrain 5 11-29-2011 07:15 PM
6 speed will not go into any gear matt06rex Transmission (AT/MT) & Driveline 10 05-10-2011 11:45 PM
Car will not move in any gear WRteXan Transmission (AT/MT) & Driveline 2 01-07-2010 08:46 AM
clutch will not engage 100% rodknock02 Transmission (AT/MT) & Driveline 1 01-09-2008 01:42 PM
85,000 miles: AT often will not engage in "D" Tooth Transmission (AT/MT) & Driveline 23 02-16-2004 10:44 AM
