Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 01-02-2012, 03:40 PM   #1
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
Default Help with burnt coolent smell and oil light.
I posted this in the 2.0 section. I just want to get the locals oppinion.
So here's the deal, I have a 03 WRX with 100K+ miles on the stock motor. The pas couple of months I have been smelling burnt coolent and having to refill the coolent about twice a month and that was the end of that.
Today my temp peaked to the top of the gauge on the dash and the oil light is going on and off. The coolent gauge will peak for the most part when idling and for the most part will go down when driving at a normal speed but there are the times that it will peak when driving 30-40MPH. There is still the smell of coolent.
The other problem is when starting the car up after being static for 12-14hrs it will blow a puff of whiteish smoke from the exhaust.
What could the problem be? Is the motor going, bad compression, something is going on.
Thanks,
Mike
SUBYS R US is online now   Reply With Quote
Old 01-02-2012, 04:20 PM   #2
Momosaurus WRX
Member#: 214737
wait, you are driving when your water temp gauge is peaking?!
If the oil light is going on/off, check your upper radiator hose. Sometimes on bugeyes the upper hose swells, hits the alternator pulley/belt, and gets pinhole in it, sprays coolant on teh engine and on one of the oil sensors (i dunno what it's called off the top of my head...) on top of the block causing the oil light to turn on and off.
Momosaurus WRX is offline   Reply With Quote
Old 01-02-2012, 04:23 PM   #3
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
I saw that is was peaked .5 miles from my house, so it wasnt a long drive but I did notice it was going up and down but not from the peak of the gauge.
There is alot of coolent in the splash tray on the bottom area were the rad is. I did not see any crack or coolent on the top of the rad.
Old 01-02-2012, 04:39 PM   #4
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
Sounds like a bad head gasket to me, basically pushing oil and pressure into the coolant, and also burning oil and coolant in the process. The oil gauge coming on is what scares me, that means that your oil pressure is way too low, like dangerously low.
1. Check oil level immediately.
2. once car is cool, open the upper radiator cap and overflow bottle, look for oil blobs or oil in the coolant.
3. if you discover oil in the coolant, it is most likely a head gasket, so you will want to run a compression test to make sure.
Let us know what you find out, and good luck
Rick
scoobydorift is offline   Reply With Quote
Old 01-02-2012, 05:40 PM   #5
godfather2112
doesn't like pears
Member#: 53794
.... Just call me
Papi Chulo
Im going with head gasket as well. Compression test that bad boy.
godfather2112 is offline   Reply With Quote
Old 01-02-2012, 05:41 PM   #6
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
Cracked radiator.
Psychoreo is online now   Reply With Quote
Old 01-02-2012, 05:43 PM   #7
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
Rick
oil level is good,There is absolutly no oil in the coolent that I saw or in the res. I filled it with some coolent and ran it for 30 mins and took a drive around the block. There is steam coming from the return line and fluid build up in that area. I dont see any fluid or residual fluid on top just on the bottom.
Old 01-02-2012, 05:54 PM   #8
bhhamblin
n00b Moderator
Member#: 99397
'13 BRZ, '13 STi
SRs13 '83 Skyline '93 GTR
Return line from the turbo? Or lower coolant radiator hose?
bhhamblin is offline   Reply With Quote
Old 01-02-2012, 05:58 PM   #9
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
OHH... Lower rad hose. That's where you can see the steam burn off from when the car is turned off.
Old 01-02-2012, 06:45 PM   #10
Eww Evo
Member#: 299687
06 Impreza Wrx
Track car in the making.
Bottom hose not ripped?
Eww Evo is offline   Reply With Quote
Old 01-02-2012, 07:04 PM   #11
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
no, not that i can see. I will be taking it to the base hobby shop tomorrow and see whats going on
Old 01-03-2012, 10:34 AM   #12
CprWrx
Member#: 264748
2006 wrx
check your oil is there water in it?
CprWrx is offline   Reply With Quote
Old 01-03-2012, 09:27 PM   #13
Derk Deez
Member#: 265246
2006 STi
Make ya say giggggittyyy
If white smoke is coming out the back, you have to be burning either coolant or oil. Smell the exhaust when its coming out, both have a distinct smell. Sounds like you have a leak somewhere if there's coolant in the undertray. Follow your hoses and look for one with a white-ish green hint. More than likely with overheating and smoke, head gasket...
Derk Deez is offline   Reply With Quote
FS NY: FS:04-05 WRX Grille with JDM i badge and fog light covers and bumper cover rayc Tri-State Area Private Classifieds 1 04-13-2010 01:41 PM
Problems with factory keyless entry and security light. Please Help goover Newbies & FAQs 5 12-14-2009 09:50 PM
Wrx Cel And oil light on???? elementsk8trbam Factory 2.0L Turbo Powertrain 8 08-28-2006 04:53 PM
need help with burnt connectors jskho Electrical & Lighting 5 10-07-2004 05:41 PM
Help with blown fuse, brake and battery warning light TygerStile Electrical & Lighting 6 09-09-2004 03:11 AM
Message Board Statistics All times are GMT -4. The time now is 08:02 PM.
