Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Old 01-03-2012, 10:51 AM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default 2012 New Year's discounts!!!!!
New shipment of Feal Suspension upgraded STI struts in stock,
add a set of RCE springs for.......
-All prices include shipping to and from Feal Suspension, something you do not have to worry about doing:
'04 STI, '02-07 WRX fitment-$995set - 1 set only(very rare)
-zerk fittings added to allow for strut housing service/regrease
'05+STI-$995set- 2 sets in stock
Info below:
Feal Suspension has researched and identified simple solutions to improve the performance of the stock Subaru STI suspension system. After dyno analysis and testing of various coilover systems for the 2004-2007 Subaru STI chassis, we at Feal Suspension concluded that the original STI suspension damping can be improved.
Feal Suspension has designed, developed, and now offers a Revalve & Service of stock STI suspension to optimize performance on the road or in the dirt. Committed drivers can now improve their STI’s performance without the purchase of aftermarket suspension.
The STI Revalve & Service includes:
Cleaning and re greasing strut housings
Polishing out nicks and glazed spots from insert surface
Revalving inserts
High performance shock fluid and nitrogen recharge
Typical turnaround time of 2 business days
Why tune my original Sti suspension? The original struts on your Sti are high quality long lasting KYB Japanese units that we can tune to match the performance of the high end expensive systems.
We now offer Zerk fitting installation into your strut bodies. We strategically place this fitting between the struts bushings. This now allows you to add fresh grease to your struts without removing them from your car! When grease is worn away from the strut bushings, the strut begins to clunk. By applying more grease via a Zerk fitting, you create grease pressure bettween the bushings and fill the dry spots.
'08+STI-$975set add a set of RCE springs for $329
Our solution for making the 08+ STI handle great is using our Feal 460 rear damper and revalving the oem front struts.
We have spent countles hours testing dampers and we are confident that this package is the best option for your 08+ STI.
Feal 460 08+ rear shock specs:
  • 46mm piston
  • 14mm shaft
  • Monotube
  • Rebuildable and Revalvable
  • Rally race grade materials
  • Can be used with stock spring perch (trimming of spring perch required)
  • Can be used as coilover
  • Dust boots and bump stops included
Front STI revalve service specs:
Revalving inserts
Add any set of RCE springs for an additional $319set!!!
*$350 additional core charge until we receive your STI suspension. The suspension has to be in useable condition.
__________________________________________________ __________________________________________________ ____
10% off on all "in stock" Whiteline suspension parts
Email [email protected] your enquiries
Here is what we have,
Strut top-camber/caster adj MOTOTSPORT KCA255M
Anti-lift/caster kit - lwr c/arm KCA359
Anti-lift/caster kit COMFORT KCA362
Anti-lift/caster kit RACE KCA359M
Brace-strut tower alloy adj KSB554
Brace-strut tower alloy adj KSB599
4 point Brace-Lower control arm KSB723
Brace-strut tower alloy adj KSB568
Subframe lock kit KSB750
Front of rear diff support lock KSB751
Gearbox positive shift kit W0584
Gearbox positive shift kit-MOTORSPORT W0584M
Heavy duty steer rack mounts KSR202
H/duty steer rack bushes KSR206
H/duty steer rack bushes KSR207
Roll-centre / bump-steer adjust kit KCA313
Camber adj kit-control arm upper bushes KCA326
Anti-lift/caster kit - lwr c/arm KCA334
Anti-lift/caster kit - lwr c/arm KCA334M Race
Strut top-camber/caster off-set KCA335
Sway bar link conv kit - extra h/d alloy KLC26
Sway bar link-bushed allow link KLC32
Swaybar link kit-spherical rod end KLC39
Swaybar link kit-spherical rod-end KLC066
Swaybar link kit-spherical rod end KLC047
Anti-roll link kit- h/duty adj ball link KLC139
Swaybar mount-h/duty kit KBR20-22
Swaybar mount-h/duty kit KBR20-24
Swaybar 22mm-h/duty Blade adjustable BSF12Z
Swaybar 22mm-h/duty Blade adjustable BSF30Z
Swaybar 22mm-heavy duty BSF30
Swaybar 24mm-X heavy duty Blade adjustab BSF30XZ
Swaybar 22mm-h/duty Blade adjustable BSF33Z
Swaybar 24mm-X h/duty Blade adjustable BSF33XZ
Swaybar 24mm-X heavy duty BSF33X
Swaybar 24mm-X h/duty Blade adjustable BSF36XZ
Swaybar 27mm-XX h/duty Blade adjustable BSF36XXZ
Swaybar 22mm-h/duty Blade adjustable BSF39Z
Swaybar 22mm-heavy duty BSF39
Swaybar 24mm-X heavy duty BSF39XZ
Swaybar 22mm-h/duty Blade adjustable BSR33Z
Swaybar 22mm-heavy duty BSR33
Swaybar 24mm-X h/duty Blade adjustable BSR33XZ
Swaybar 22mm-h/duty Blade adjustable BSR36Z
Swaybar 24mm-X h/duty Blade adjustable BSR36XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR37XZ
Swaybar 27mm-XX h/duty Blade adjustable BSR37XXZ
Swaybar 20mm-h/duty Blade adjustable BSR49Z
Swaybar 22mm-X heavy duty Blade adjustab BSR49XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR49XXZ
Email [email protected] for your enquiries, please no pm
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline   Reply With Quote
Newbie New Year's Resolutions dead-eye Newbies & FAQs 5 01-01-2001 08:24 PM
Survived New Year's Eve! T-WRX Mid West Subaru Owners Club Forum -- MWSOC 0 01-01-2001 10:28 AM
New Year's??? Necromancer Bay Area Impreza Club Forum -- BAIC 4 12-30-2000 02:56 PM
Big plans for New Year's Eve??? BlueRidgeRS South East Region Forum 10 12-23-2000 11:50 PM
CT New Year's Drive (non-Subie) GoFaster New England Impreza Club Forum -- NESIC 2 12-14-2000 12:24 AM
