Old 01-03-2012, 04:35 PM   #1
Sonnyblk
Member#: 164505
06 WRX TR
CGM
Default How important is the coolant reservoir tank?
Today went to go buy oil from the local subaru dealership got home decided to check my oil level. What do u know there is hose just dangling up by my intake manifold. After the initial 5 mins of cursing loudly in the parking lot of my apartment complex. I was looking for where the hose goes there is no fluid coming out or anything no check engine lights. I realize hey I know where this goes its to the coolant reservoir that is not there. I had my 60k service done and they removed it to inspect my timing belt. I then went to the nearest wall and proceeded to bang my head very hard against it till my vision was blurry. This was due to my stupidity cause i have had the hood up I dont know how many times since I had it done 2 months ago. Just wondering how bad this really is? Gonna call the shop I had it done at to see if they still have it.
PS-The oil is at full and looks clean I love the Subaru 5w30 synthetic. Please excuse any errors my vision was still blurry while typing this.
Sonnyblk is offline   Reply With Quote
Old 01-03-2012, 05:10 PM   #2
Sonnyblk
Member#: 164505
06 WRX TR
CGM
Called the shop they dont have it and said they were sorry and that was it. So I will just buy another one or maybe go after market.
Old 01-03-2012, 05:29 PM   #3
fiveightandten
Member#: 219524
2002 WRX Wagon
AW
Shop removed part.
Shop did not reinstall part, or an equalivent.
Shop produces said part, or pays for a replacement.
It's as simple as that. Removing a functioning part from someone's car and leaving the car incomplete? Are they normally in the business of stealing, and returning cars to paying customers in a state where they can be damaged easily?
Unacceptable. Call them back and ask them when they'll have your new reservoir in.
And to answer your question, yes, you need it. Coolant expands and contracts with heating and cooling. It expands, it dumps into the reservoir...it contracts, it pulls fluid from the reservoir instead of air. When it gets in to the cooling system, it can get circulated into the coolant passages. If an air pocket gets trapped around the block, or one of the heads, it can cause a hot spot and damage a head gasket, crack a head, etc. So, yes, it's pretty important to have that reservoir. You're pulling air into your cooling system currently.
Sounds like a hack shop to me. I'd get a replacement out of them and never go back.
fiveightandten is offline   Reply With Quote
Old 01-03-2012, 08:19 PM   #4
Sonnyblk
Member#: 164505
06 WRX TR
CGM
The shop called me back they found the tank and will be putting it back on tommaro. They also will be making ammends with some nice deals on parts and apologised prefusely and said the guy that did the service is no longer working with the company. Thanks for the info and answering my question.
Old 01-03-2012, 11:50 PM   #5
fiveightandten
Member#: 219524
2002 WRX Wagon
AW
Good to hear there's a happy ending. Be sure to double check that they topped off the coolant and that the system is properly bled after the reservoir is put back on.
Old 01-04-2012, 12:10 PM   #6
Sonnyblk
Member#: 164505
06 WRX TR
CGM
Got it put back on this morning the coolant level was full and everything is in working order. They are going to give me a severley discounted VF48 turbo and STI TMIC to make everything better. Thanks for the Info again this thread can be closed.
SS brake lines: How important is the PVC coating on the outside? phenryiv1 Brakes, Steering & Suspension 7 12-15-2011 04:31 PM
How important is the air filter behind the glove box?? dj.ile Service & Maintenance 6 11-13-2010 11:17 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 06:26 PM
How important is the primer on the Goped? twinbrd Off-Topic 8 05-15-2009 11:37 AM
How important is the vacuum line behind the intake manifold? KAX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-22-2008 10:49 PM
