Welcome to the North American Subaru Impreza Owners Club Friday October 31, 2014
Old 01-03-2012, 07:30 PM   #1
DerekNitroRC
Member#: 222105
2000 Legacy GT Wagon
Black/Red Metallic
Default Random mis-fire issue
I had a Subaru specialist check out my car and was not able to find out what is going on so I'm posting on here to see if someone can help me out. The history, my car has 159k on it and had no issues at all with mis-fires until after I did my headgaskets. The thing that drives me crazy is that the car ran perfectly fine for two days after doing the head gaskets. Then it started to have a random misfire every once in awhile while idling, no big issue. Drive it back home to Georgia (from Wisconsin) and the mis-fire gets so bad that the car is barely driveable under 3k. Once I hit 3k it runs perfectly fine. Also while it is mis-firing while idling, if I just slightly touch the gas pedal it will stop and run perfectly smooth. The specialist I had check out my car said that he was getting codes from my IAT and MAP sensors. So just today both sensors came in from the warehouse. Plugged them in with the battery off and the car started up and ran perfectly fine until it warmed up and started to slightly mis-fire. Drove for a mile and it was back to its normal misfire. Has anyone else had this issue? What can I do? The sparkplugs are brand new NGK iridiums and I had just changed out the wires a year ago. The mis-fire is inconsistent as well, there are times where it will idle or drive without a mis-fire but then once it mis-fires once it goes back to normal. Thanks for any help!
DerekNitroRC is offline   Reply With Quote
Old 01-03-2012, 10:24 PM   #2
CosmoTheCat
Member#: 3409
1998 Ram 2500
Green.
Vacuum leak?
That thing got an EGR valve on the back of the intake manifold? If so, yank it off and clean it out, see if it's got a good seal. I've had one come in with multi cylinder misfires and it turned out to be the EGR valve not closing.
CosmoTheCat is offline   Reply With Quote
Old 01-04-2012, 08:29 AM   #3
DerekNitroRC
Member#: 222105
Black/Red Metallic
my car did not come with a EGR valve
Old 01-04-2012, 08:32 AM   #4
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
one or more coil packs are on their way out?
MY EJ20TTTTTT is offline   Reply With Quote
Old 01-04-2012, 10:29 AM   #5
DerekNitroRC
Member#: 222105
Black/Red Metallic
we tested the coil pack and it was running strong, actually had three different people test that one...each one got zapped while testing it
HELP Supertones randomly went on in the night and stayed on Hotgunz Electrical & Lighting 4 01-03-2012 10:16 PM
Problems with Idle and random Starting issues. jonthesloth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-26-2011 12:05 AM
Random Missfire issues...? GochYou Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 09-22-2010 03:51 PM
random noise issue from 09 wrx hjmik Newbies & FAQs 3 06-08-2010 12:28 AM
Help me with my random overheating issue!!! SicWRX37 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-07-2008 07:53 PM
