Old 01-04-2012, 09:47 PM   #1
olivertwisto
Member#: 224318
1998 WRX
snow white
Default constant RPM ticking noise madness
Hi folks,
My 98 WRX has a ticking noise that is driving me nuts. Only comes when I'm on the throttle, but the speed of the ticking does not increase with engine RPM. It's coming from the drivers side (my car is RHD) of the engine. Not really loud, and performance does not appear to be affected by it. Fuel burn and oil consumption are normal. Any ideas? It's much appreciated!
olivertwisto is offline   Reply With Quote
Old 01-08-2012, 01:54 AM   #2
blessthekellen
Member#: 273859
MY98
WRX
heat shield rattle? My best guess.
blessthekellen is offline   Reply With Quote
Old 01-16-2012, 10:06 PM   #3
olivertwisto
Member#: 224318
1998 WRX
snow white
Checked out the heat shields, no dice. Man, this noise is making me nuts.
Old 01-17-2012, 02:28 AM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Constant speed of ticking like a metronome or variable
Old 01-17-2012, 01:07 PM   #5
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Does it sound like the ticking noise you get when you put the car in diagnostic mode and it cycles the fans and all of the solenoids?
If its RHD drivers side you have the factory boost controller solenoid located where you are talking about.
I read a howto on cleaning the factory 3 port boost controller that talks about putting the car into daig mode and cleaning the solenoid while its doing its ticking thing. Perhaps its stuck which is causing the ebc solenoid to repeatedly cycle.
TommyAtomic is offline   Reply With Quote
Old 01-19-2012, 07:57 PM   #6
olivertwisto
Member#: 224318
1998 WRX
snow white
Cheers, that's a good suggestion. I'll try putting it in diagnostic mode and see if i can hear it. It is a constant tick, like a metronome, and doesn't increase with speed or RPM, but it is only present when accelerating and the car has to be moving. Otherwise, the car runs like a champ. I'll post results if I find anything. Thanks again!
EJ207 won't hold constant rpm Faster_Gun Factory 2.0L Turbo Powertrain 5 10-16-2010 12:28 PM
Ticking noise from Trans/driveline at low RPM under light acceleration, deceleration CIATexan Transmission (AT/MT) & Driveline 26 10-14-2010 09:18 AM
Constant loud ticking...help Hoffman Service & Maintenance 4 09-29-2004 07:37 AM
Car won't hold constant RPM - Bad O2 Sensor? jetskizero Factory 2.0L Turbo Powertrain 4 11-21-2003 01:22 PM
Message Board Statistics All times are GMT -4. The time now is 08:56 PM.
