Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-05-2012, 12:20 AM   #1
seth1981
Member#: 183115
2005 WRX Stg 2
San Remo Red
Default checking oil
One side of the stick says to much the other side either shows low or oil half way up the stick. Which should I pay attn to. I have read threads that say this is an issue. I had to swap oil but not filter. (drain gasket was bad after 500 miles on last oil change) I put in 4 qts not the 4.2 and its showing over full. It has been sitting for about 5 hours. Hell when I pull the stick and try again I get oil way half way up the stick. I have had a few cars and this one dosnt seem to like getting its oil checked. Im not a proctoligst but im sure im doing it right
seth1981 is offline   Reply With Quote
Old 01-05-2012, 08:49 AM   #2
bluesubie
Member#: 767
04 FXT
Pay attention to side of the dipstick with the L and F marking. There is still a small amount of oil that may have come out of the engine if you had removed the filter. As long as you're not over the notch in the dipstick (above the F) when the engine is hot, you're fine.
-Dennis
Check Oil Light on 2004 STI drfrink24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 02-21-2006 11:31 AM
Checking Oil Level Saturn Service & Maintenance 13 01-06-2005 01:14 AM
Checking Oil slowscooby Newbies & FAQs 4 11-10-2004 11:23 PM
Help checking oil JDMSubaru Newbies & FAQs 7 11-07-2003 03:22 PM
Check Oil Levels when service is done! EddyRS Bay Area Impreza Club Forum -- BAIC 1 07-03-2001 06:38 PM
