Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-05-2012, 02:28 PM   #1
TubeDriver
Member#: 14987
Default 1991 Legacy 2WD front axles the same as AWD?
I need to replace the front axles on a 91 2WD Legacy wagon. Most of the online part suppliers don't seem to differentiate between AWD and 2WD. Are these the same axles?
Any opinions on rebuilt/refurbished vs new (and by new I mean cheap new Chinese) axles? Thanks.
TubeDriver is offline   Reply With Quote
Old 01-06-2012, 12:15 AM   #2
Azlegacy
Member#: 279837
Dunnno but I say do an awd swap.
Azlegacy is offline   Reply With Quote
Old 01-06-2012, 08:22 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I thought I remembered reading here at some point that the 2WD axles were thicker than the front axles for the AWD. I've never actually held a 2WD axle in my hand to compare it to something else, though, so I dunno if that's really the case.
I think that the front axles I have on the Legacy now are cheap new Chinese axles. They both appear to have had the outer CV boot slip partly off, like the big clamp (the one right at the back of the knuckle) wasn't tight enough. I haven't done anything about it yet other than clean up the grease.
Old 01-06-2012, 04:57 PM   #4
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Pretty sure 2WD axles are beefier to handle the torque.
Samirr76 is offline   Reply With Quote
Old 01-06-2012, 05:02 PM   #5
TubeDriver
Member#: 14987
I remember reading something about that. It looks like a lot of Chinese axles share the same part number between AWD and 2WD.
I really don't care so I got a set of Duralast from Autozone for $45 each with free shipping (lifetime warranty). These will go on a beater that basically only get driven when it snows/rains or when I have to park outside in DC. I am throwing on a set of Firestone Wintermaster studless snows 185/60-15 on some Outback wheels I have (15x6). It should kick ass in the snow and rain.
Old 01-07-2012, 12:16 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Well, damn. I was going to offer you some axles sitting in my garage for free.
Old 01-07-2012, 11:34 AM   #7
TubeDriver
Member#: 14987
Thanks for the offer Pat, if the cheap Chinese axles don't fit I'll let you know.
Old 01-07-2012, 11:38 AM   #8
tibug
Member#: 273906
2006 VTECAccordVTEC
Also it has VTEC.
I've heard that they will fit and work, and that's why a lot of parts places sell 2wd axles as an all-encompassing solution. However, while these axles may be physically stronger, they will fail earlier because the passenger inboard boot is even closer to the exhaust than OEM.
http://allwheeldriveauto.com/seattle...ems-explained/
Originally Posted by allwheeldriveauto.com
A large supplier of axles has also decided that because the older 2 wheel drive axle used by Subaru many years ago which was larger in size and believed to be stronger, has decided for you that your newer Subaru should have a 2 Wheel drive axle installed regardless of the fact that this puts the inner cv boot much closer to the exhaust and it will fail very quickly the 2 wheel drive axle in the earlier years was larger in diameter than the AWD axles.
tibug is offline   Reply With Quote
Old 01-12-2012, 03:29 PM   #9
minghi
Member#: 306690
wow... didn't know subaru ever made a non AWD
minghi is offline   Reply With Quote
are GC8 rear axles the same as WRX?? 1st02wrx Newbies & FAQs 0 10-11-2006 03:49 PM
Are JDM sti axles the same as USDM sti axles? Capt Crunch Transmission (AT/MT) & Driveline 0 06-25-2006 03:34 PM
are 99-01 gc8 lsd axles the same as wrx axles turbocolin Transmission (AT/MT) & Driveline 0 01-23-2005 12:34 AM
driveshafts in version 3-6 WRXs are the same as AWD Ls? Superu Transmission (AT/MT) & Driveline 0 03-31-2002 05:37 AM
Heres a stupid question: Is 4x4 the same as AWD Andrew Newbies & FAQs 15 02-04-2001 04:53 PM
