Old 01-05-2012, 03:35 PM   #1
cwb124
Member#: 15571
2006 06 Forester XT
Default Blown gasket or thermostat or something else?
The last few days I have noticed that my cabin heat is inconsistent. Sometimes it blows warm air and sometimes it blows cold air, even when its on the highest heat setting. Even when I set it that high, the air that comes out is only mildly warm and it seems to go back to blowing cold air within a couple minutes.
Just yesterday I noticed my eng temp gauge being very active. After it warms up, the gauge can bounce between halfway and all the way up to almost overheating. It jumped all the way up while I was going down a slight hill with the clutch engaged, just coasting. It moves quickly up and down, unlike I've ever seen.
Bad thermostat? Head gasket? I haven't checked under the hood yet for gasket issues, but I will when I go to leave soon.
cwb124 is offline   Reply With Quote
Old 01-05-2012, 03:43 PM   #2
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
Check the coolant level and see if it is full.
JohnM10 is offline   Reply With Quote
Old 01-05-2012, 06:02 PM   #3
FCP Import
Member#: 305489
91 skyline GTR
champ white
Sounds like the thermostat has gone on you.
FCP Import is offline   Reply With Quote
Old 01-06-2012, 10:21 AM   #4
cwb124
Member#: 15571
2006 06 Forester XT
I checked the coolant level and it was down. I topped it off near work and drove home. While driving home, I saw some unusual activity on the eng temp gauge. Usually once the car warms up that gauge doesn't move, but it was pushing higher and higher as I coasted down a couple hills.
This morning I checked and the coolant level was down again. I topped it off again and drove to work (8 miles). I'll check at lunch. Oil isn't milky and looks fine so I don't think the coolant is leaking there. There wasn't any puddle under my car either.
Old 01-06-2012, 08:13 PM   #5
takin_turns
Member#: 303613
02 WRX
AW
Having the exact same issue in my Wrx! I changed my thermostat and it didn't fix it. Very curious to see what your outcome is
takin_turns is offline   Reply With Quote
Old 01-07-2012, 09:07 PM   #6
cwb124
Member#: 15571
2006 06 Forester XT
How long have you had it? Have you kept topping off your coolant?
Old 01-07-2012, 10:54 PM   #7
takin_turns
Member#: 303613
02 WRX
AW
I've had it for the last 5 days. I've been topping off almost everyday. It would take all the coolant from the expansion tank. No smoke, no misfire, just intermittent heat loss and sucking coolant
Old 01-07-2012, 11:18 PM   #8
cwb124
Member#: 15571
2006 06 Forester XT
Same damn thing hear, although oddly enough my heat has been stable the last day or two, although it was near 60 today so no need for heat.
I'd really like to know what the heck is going on. 06 Forester 2.5xt with 62k miles on it. I wouldn't think I'd blow a head gasket, although if that was where our coolant was going, we'd see it in the oil I would presume. My oil is fine.
Old 01-08-2012, 08:15 AM   #9
takin_turns
Member#: 303613
02 WRX
AW
Same here. I'd hate to jinx myself but mine seems to have
stabalized too and yes it was around 65 degrees here too so no need
for heat. I sat in my driveway with a scan tool hooked up
and watched the coolant temp after a 30 minute trip and it maxed
out at 208 degrees with the heat on. The needle was around halfway
Old 01-13-2012, 01:55 PM   #10
sababa1
Member#: 301296
2008 wrx
SS
do either of you smell coolant? in the car while driving, or outside after a long drive?
sababa1 is offline   Reply With Quote
Old 01-13-2012, 02:09 PM   #11
cwb124
Member#: 15571
2006 06 Forester XT
No coolant smell ever that I am aware of. Although I've been stuffed up for a little while.
Old 01-24-2012, 05:07 PM   #12
afdk
Member#: 289327
2016 Subaru WRX
Ice Silber
My 2008 WRX was having the same issue, it was finally determined to have a head gasket problem. The engine heads were removed and found to be alright. One head gasket had a leak. The engine did not pass the head pressure test, that's why it was taken apart.
afdk is offline   Reply With Quote
Old 01-24-2012, 05:18 PM   #13
cwb124
Member#: 15571
2006 06 Forester XT
Oddly enough, it appears that my problem just went away. I did a 2 hour drive to AC and back this weekend and my temps were steady, heat worked. I have no idea what the heck was going on but I haven't had the problem since a week or so after I started this thread.
Old 01-24-2012, 05:54 PM   #14
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Air in the cooling system.
JamesWilson2 is offline   Reply With Quote
280zx? or spend on something else Ruben_guy07 Off-Topic 18 03-25-2010 04:01 AM
Is my power steering pump bad? or is it something else? psychoskip Brakes, Steering & Suspension 11 01-25-2010 02:46 AM
Overheating at track. Head Gasket? New Radiator? Leak? Something else? mav1c Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 06-22-2009 03:41 PM
Is my alternator dead or is it something else? Jus Blaze Electrical & Lighting 4 09-22-2008 10:09 AM
Time for a VF39, or VF34 0r something else? I need opinions NRTmotorsports Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 02-22-2007 10:08 PM
