#1 |
Member#: 78417
SCIC
Vehicle:2005 WRX/STI Stage 2 Aspen White |
This thread will be journaling the build of my 05 STi that I have slowly and meticulously chronicled in the 7+ years that I have owned the car. I have no idea why I never made a journal on NASIOC before but it is better late then never. When I first purchased the STi in Oct of 2004, I kept telling myself that I would not modify the car too much. But as time went on I could not control myself and the never ending build began. Through out the years modifying my STi has become an uncontrollable obsession for me. It has not only been a hobby but a way of life. I will try and post the pictures of my build in a chronological order from past to present.
The Mod sheet below has all the current parts and parts that are currently being installed. ENGINE: Cobb Accessport Stage 2 K&N Typhoon Intake Invidia V3 Downpipe W/race cat JDM Fujitsubo Legalis Super R one Piece Exhaust Modified 3inch piping Tomei Un-Equal Length Headers and Up-pipe Earls Temp-A-Cure Oil Cooler Custom Mounted Top Fuel Zero1000 Power Neo Professional Koyo Radiator Samco Radiator Hoses Grimmspeed AOS Fumoto Valve + Oil filter mag Sun Auto Auto Hyper Force Igntion System Sun Auto Hyper Voltage System Currently Sitting at the shop being Installed: ATP GTX3071R Full Race Header ---> waiting for my order Full Race 1.5 Scroll Up-Pipe---> waiting for my order PTP T3/T4 Turbo Blanket Tial QR Recirculating BOV Tial 44mm MV-R ext wastegate 1000cc Injector Dynamics T1 Side Feed to Top Feed Conversion Kit Weldon Fuel Pressure Regulator Aeromotive 340 Stealth Fuel Pump Grimmspeed Electronic Boost Controller Grimmspeed 8 mm Phenolic Spacers TGV Deletes Custom Black Ceramic Heat Coated APS Turbo Inlet Custom Powder Coated Candy Violet APS 70mm Cold Air Custom Powder Coated Candy Violet APS 525 Front Mount with Custom Coated Candy Violet Piping Moroso Aluminum Coolant Expansion Tank Moroso Dual Billet Aluminum Air Oil Seperator Tanks Gates Race Timing Belt and Accessory Kit Tomei Timing Belt Guide Beatrush Floor Performance Bar Innovative MTX-L Wideband Air/Fuel Ratio Gauge Killer B V2 Performance Oil Pan Killer B Ultimate Oil Pickup Killer B Oil Pickup/ Windage Tray DRIVETRAIN: Cusco Motor Mount and Transmission Mounts STI Oem Short Shifter Whiteline Steering Rack Bushing Upgraded STI short shifter linkage Kartboy Short Shifter Kartboy Front 05 Stifter Stay Bushing Kartboy Rear Shifter Stay Bushing Katboy Pitch Mount TiC 6MT Pivot Bushings TiC 05 STi Shift Linkage Bushings TiC Crossmember Bushings TiC Botox Rear Subframe Lock Bolts Kartboy Limited Edition STI pink exhaust hanger bushings SUSPENSION: Cusco Zero2E + Econ Controller Cusco Front Strut Bar Cusco Rear Strut Bar + V-Brace Whiteline 24mm Adjustable Front Sway Bar Whiteline 24mm Adjustable Rear Sway Bar Whiteline Anti-Lift Kit (Sport) KartBoy Front Endlinks KartBoy Rear Endlinks Kartboy Rear Subframe Outrigger Bushings Do-Luck 7 Point Aluminum Subframe Brace---> back to stock for time being---> M1 Chromoly Sub Frame TiC Rear Diff Mount Bushings TiC Lateral Link Bushings TiC Front Trailing Arm Bushings TiC Fender Braces MSI Rear Trailing Arms EXTERIOR: Upgraded 6000k HID Bulbs Advan TCII 18x8.5 +37 dunlop Direzza Star Spec Z1 245/35/18 Prodrive GC010E 18x8.5 +50 (British Black) Nitto NT05 245/40/18 Project Kics R40 Forged lugs Perrin Stiffies Beatrush Aluminum Undertray HKS Kansai Service Carbon Fiber Rear Diffuser BRAKES: APM 2 Piece J-Hook Front Rotors DBA 4000 Rear Rotors Ferrodo DS2500 Pads TiC Brake Master Cylinder Brace Earls Stainless Steel Brake Lines Motul RBF600 Fluid INTERIOR: Works Bell Short Hub Works Bell Rapfix II Nardi 350mm Deep Corn Leather Red Stitching Custom Ti Burnt Blue Shirt Knob by Lathe Works Defi 3 Meter Hood Defi Boost Gauge Defi Fuel Pressure Gauge Defi Exhaust Temp Gauge Blitz Power Meter JDM STI Head Rest Pillows Suede Center Console Suede Arm Rest Suede Glove Box Suede Pillars Suede Doors Kicker Components in the Front and Kickers in the rear Waiting to be installed: Bride Stradia II Special Edition Japan Carbon Fiber x 2 Bride Stradia Leather Knee and Bolster Protectors x 2 sets for each seat Bride RO seat rails x2 October 2004 When I first brought my baby home from Sierra Subaru in Monrovia, CA. It was the only Aspen White Subaru I could find anywhere around me. ![]() Super stock, virgin engine bay. ![]() Within the first couple of months of having the car a buddy of mine told me that he wanted to do an article in a automotive magazine called AUTOTIME which is similar to Motortrend in the US comparing the Chinese WRX with the USDM STi. My car only had a CUSCO front strut bar and rear V-brace at the time. Other than those two mods the car was completely stock. I was more than happy to help out. ![]() Magazine Cover: ![]() The article in Chinese of course: ![]() A little comparison chart between the WRX and the STi ![]() Here is an actual picture that was used for the article. ![]()
#2 |
Member#: 78417
SCIC
Then the mod bug bit me in the ass.
First up was the INVIDIA Downpipe with race cat for just that extra itty bitty horse power. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 02:55 AM. |
#3 |
Member#: 78417
SCIC
Then I decided that I would start with the suspension mods. First up CUSCO Zero2E with E-Con aligned and corner balanced for aggressive street driving by Daryn at West End Alignment in Gardena, CA.
![]() ![]() ![]() ![]() ![]() ![]() E-Con Mounted to the gauge cluster ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 02:56 AM. |
#4 |
Member#: 78417
SCIC
When I took the car to the alignment shop Daryn noticed that I had flipped my rear strut bar and bent my rear endlinks after a local shop had installed the coilovers. He temporarily straightened them out for me but this was only a temporary fix. I then decided to hit Turn In Concepts and purchase new rear Kartboy Endlinks to replace my stock ones. I also purchased a couple of other goodies along with the endlinks.
Whiteline Steering Rack Bushings Kartboy Rear End Links TiC Tranny Crossmember Bushings ![]() ![]() ![]() Whiteline 24mm front and rear sway bars ![]() CUSCO Engine and Transmission Mount ![]() During this time I actually drove my car quite regularly to Las Vegas so I decided to add a custom oil cooler. ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 03:00 AM. |
#5 |
Member#: 78417
SCIC
Was bored one day so I decided to take a nice drive up to Palos Verdes and take some random pictures. Sorry outside is stock but its whats inside that counts. Right? Added some Perrin Stiffies and NRG Carbon Look dampers.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 03:05 AM. |
#6 |
Member#: 78417
SCIC
Sunday drive to Terminal Island in Sand Pedro. There are two 06 STi's and my aspen white 05 STi which are all stage 2.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 03:06 AM. |
#7 |
Member#: 78417
SCIC
On Feb of 2008 I purchased a set of used ADVAN TCII 18x8.5 +37 with crappy Falken all season tires on them which I later replaced with RT-615’s.
![]() ![]() ![]() ![]() ![]() BEWARE OF THE DOG ![]() Here are some more from Angeles Crest ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 03:15 AM. |
#8 |
Member#: 78417
SCIC
I then purchased a set of used CUSCO Un-equal length Headers which gave me much better low end throttle response while still keeping the boxer rumble.
CUSCO Headers ![]() ![]() ![]() ![]() ![]() Some random Pics from Suby drive to Terminal Island ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 03:14 AM. |
#9 |
Member#: 78417
SCIC
Then came along a JDM Fujitsubo Legalis Super R one piece exhaust. It was actually a JDM version so had to modify the flange to make it mate up to the USDM INVIDIA DP.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Then more suspension mods: Do Luck 7 point Aluminum SubFrame Brace ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 03:23 AM. |
#10 |
Member#: 78417
SCIC
![]() Ok, need to sleep. More to come in the next couple of days. I have plenty more pics. Last edited by SpeedMasterLee; 01-06-2012 at 03:27 AM. |
#11 |
Member#: 78417
SCIC
Here goes the updates in the order they were upgraded.
![]() Defi Hood with Defi Boost, Exh Temp, and Fuel Pressure installed. ![]() Oh yeah if yo havent noticed by now I am a suspension whore. I am a firm believer in suspension first and power second. Turn In Concepts Fender Braces, MSI Trailing arms, TiC Front Trailing Arm Bushings, Kartboy Pitch mount, Kartboy Short Shifter. ![]() I bought a set of Tomei headers when I thought that my CUSCO ones had cracked. Everytime I went past 3 thousand RPM I would hear a metalic rattle under my car. After taking off the header and replacing the stock up-pipe with the TOMEI up-pipe it turned out that it was the heat sheald on the stock up-pipe that had broken off and was rattling in the engine bay. I had to give up my Do-Luck brace to install these headers. TOMEI Header and Up-pipe, sorry these are the latest pictures. Didn't get a chance to take pictures when I first got them. ![]() M1 Chromoly Sub Frame Brace. My first brace was a Do Luck brace but ended up going back to stock for a bit when I changed my headers to the Un-equal length Tomei Headers which do not fit with it. After a while of not having a sub frame brace I came across a very nice M1 brace that I could not keep my hands off of. There was definitely an improvement with both aftermarket sub frame braces I have used. It just makes the front end feel much more connected and really stable at high speeds and turns. ![]() From going from CUSCO to TOMEI headers the stock undertray was getting beat up and stretched out from the heat. Beatrush Aluminum Under tray was installed to fix this issue. Last edited by SpeedMasterLee; 01-06-2012 at 01:24 PM. |
#12 |
Member#: 78417
SCIC
My stock brake rotors lasted through two sets of brake pads and close to 70,000 miles before the rotors needed to be changed.
![]() APM Two piece front rotors, rear DBA400 slotted, Ferrodo DS2500, Grimmspeed brake master cylinder brace, and whiteline front A arm bushings. Custom Earls Brake Steel Braided brake lines were also installed but not shown in this picture. ![]() ![]() ![]() APM Two Piece Rotors vs Stock Sti Rotors ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 05:12 PM. |
#13 |
Member#: 78417
SCIC
My buddy had a brand new HKS Kansai Rear Diffuser sitting in his shop for years and I was just tired of seeing it not being used. Finally decided to make him and offer use the damn thing. Installing the diffuser required alot of cutting into the stock bumper and modifying of the HKS Diffuser bracket that came with the kit. The end result speaks for itself.
HKS Kansai Rear Diffuser Installed ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 05:17 PM. |
#14 |
Member#: 78417
SCIC
Works Bell RapfixII Quick Release Quick Release (Blue) Works Bell Rapfix Flipper Nardi Deep Corn Leather w/red stitching Custom Ti Burnt Blue Shirt Knob by Lathe Works ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-07-2012 at 01:09 AM. |
#15 |
Member#: 78417
SCIC
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by SpeedMasterLee; 01-06-2012 at 05:21 PM. |
#16 |
Member#: 122598
SCIC
Vehicle:2006 WRX Wagon |
Love your car man, by chance is there a large difference in the way the car feels with the sub frame?
#17 |
Member#: 254699
South East
Vehicle:2011 STi, 05 FXT Red, Sliver |
I gotta say I am jealous. I am loving your STi, the mods and the cute little doggie.. But the best picture is the guy waving in the back ground..LOL
How is the performance and handling now? |
#18 |
Member#: 254699
South East
#19 | |
Member#: 78417
SCIC
I went from Do-Luck---->stock---->M1 I can definitely say that it helped tighten up the front end quite a bit. At high speeds the car was much more stable and at low speeds the car was much less harsh over road imperfections. |
#20 |
Member#: 78417
SCIC
Oh thats a buddy of mine who ownes the black hawkeye 06 STi of the right side of that picture. With the E-Con my car is very flexible in terms of handling. I can go from & little bit better than stock to go cart in a few seconds. When I have it set up for maximum handling the car has almost no roll.
#21 |
Member#: 78417
SCIC
Ok now for the stuff waiting to be installed.
ATP GTX3071 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#22 |
Member#: 237362
looks like the mods are piling up quick. Gonna be a good time when the new turbo set up is on. Ur car makes me wish i got aspen white ha, gorgeous color
~Z |
#23 |
Member#: 30745
South East
Vehicle:SRP Greddy(R.I.P) Bugeye & '00 LandRover D2 |
Very nice mods....
#24 |
Member#: 305053
so beautiful.
#25 |
Member#: 177861
NWIC
Vehicle:1999 Built! RSTI FP Red, E85, IM FAST! |
What do you do for work!??? looks great!
And I am in love with that works bell Nardi set up! |
| Thread Tools | |
| Display Modes | |
| From daily driver to weekend cruiser | Bill in Mtl | Newbies & FAQs | 5 | 07-25-2011 06:47 PM |
| 2004 STi track car/maybe daily driver | dxrat | Private Vehicle 'For Sale' Classifieds | 132 | 12-25-2008 09:54 PM |
| 2004 STi track car/maybe daily driver | dxrat | SCIC Private Classifieds | 17 | 04-16-2008 12:16 AM |
| Converting a daily driver to alcohol | TampaWRX | Factory 2.0L Turbo Powertrain | 5 | 06-22-2002 12:20 PM |
| Who uses their RS a daily driver to save your other car | RS ING | General Forum Archive | 29 | 02-22-2001 06:29 PM |
