Old 01-06-2012, 09:06 PM   #1
erockk
Member#: 59975
Default 2012 STi AP installed - now car wont start
I received my new AP and installed it, everything appeared to go exactly like it should. It recognized the car correctly, backed up the stock flash then applied the stg 1 93 flash. When it finished the install of the new map the car now wont start. Any ideas? I have read several posts from Bill@Cobb saying this is nromal and to leave the car in the on position for 5-10 seconds, I have tried that about 10 times so far with no luck.
FIXED - reset the ecu again by pulling the neg batt cable and pumping brakes and I have a car again.
erockk is offline   Reply With Quote
Old 01-06-2012, 09:34 PM   #2
hutch959
Member#: 267463
i dont know the answers... but if it was me (at this time of night when i couldnt reach cobb), i would make sure my a/p was up to date. had the correct maps... and if it did, i would try to install the stock flash back.
hutch959 is offline   Reply With Quote
Old 01-07-2012, 08:12 AM   #3
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Hi there. Sorry for your troubles. We've identified an issue with some of the later model Subarus where they may fail to exit programming mode after installing the AccessPORT (or potentially reflashing a map). This doesn't hurt anything other than the vehicle won't start. The solution, as you discovered, is to disconnect the negative terminal of the battery (and then obviously re-connect). We are working on a fix for this and will make an annoucement when it is ready.
Bill
Old 01-07-2012, 09:32 AM   #4
erockk
Member#: 59975
Bill
No worries and thanks for confirming that it is a known issue. I would suggest you guys throw up a known issue and workaround solution page on your website. It is a little disconcerting to feel like you just created a very expensive soap box derby car.
Now my biggest problem is I am relatively sure that stg 1 isnt going to keep me happy for long.
Help! Installed Downpipe Now Car Wont Start! ucmeuc3 Factory 2.5L Turbo Powertrain 6 09-16-2011 09:27 AM
up/dp install now car wont start bbun Factory 2.0L Turbo Powertrain 8 11-15-2009 09:48 PM
Parking lights wont work now car wont start inevitable_101 Electrical & Lighting 0 07-21-2009 04:51 PM
installed intake now car wont start King Fish Factory 2.5L Turbo Powertrain 13 07-25-2008 09:34 AM
ssauto fmic installed n now it wont start cobbler Factory 2.5L Turbo Powertrain 16 10-01-2007 11:41 AM
Message Board Statistics All times are GMT -4. The time now is 02:56 AM.
