Old 01-07-2012, 02:55 PM   #1
SP00LN_WRX
Member#: 305109
Okay so heres the deal...im going to admit im a little noob when it comes to subies. i myself have a 03 evo this is my wifes car....but anyways heres the deal on my way home from work i was on the fwy and noticed a smell of burning oil so i asked my friend and he said he didnt smell anything so i thought i was trippin. then when i went to get off the fwy i came to the light and pushed the clutch in and all of the sudden my car died!!....so i started it again and went to the nearest gas station to check it out(100m from where it died) i went to pull in there and it did the same thing! so i coasted to a parking spot lol and opened the hood and then some white smoke came out and a strong smell of burnt oil so i checked the oil and the oil was full but Deffinetly burnt, so then I checked the coolant(little low but deffinetly nothing to over heat over and i topped it off just to be safe after it cooled down of course. so i waited for about 30 mins or so and tried to start it and it didnt start at all...good thing i had road side assistance to tow it to my house 20miles away! Any suggestions/ solutions are very much apreciated thank you. Here is a list of helpfull info that may help...
MODEL: 02 WRX
ENGINE: 05 STI swap
TURBO: 20G Deadbolt
OIL I USE: Rotella T6
Coolant: All weather forget the name
Radiator: Aftermarket Koyo
HOPE THAT HELPS
SP00LN_WRX is offline   Reply With Quote
Old 01-07-2012, 04:51 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
Uhh, did you check the OIL?
flycaster is offline   Reply With Quote
Old 01-07-2012, 06:48 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
order a new motor
Old 01-07-2012, 07:29 PM   #4
SP00LN_WRX
Member#: 305109
My bad ya I forgot to put it in there I did check it and it was full but Deffinetly was burnt...
Old 01-07-2012, 08:03 PM   #5
ojala
Member#: 255441
05 Saabaru
codes?
crank but no start?
no crank?
check gas, air, spark then sensors
ojala is offline   Reply With Quote
Old 01-07-2012, 10:20 PM   #6
SP00LN_WRX
Member#: 305109
Originally Posted by ojala
codes?
crank but no start?
no crank?
I don't have anything to plug into the ecu to check for codes.
And yes it does crank and wants to start but never turns over...gas is good I'm running on 91 octane and I just filled up at a shell a day prior to this.
I don't understand exactly what you mean by check for air??
Old 01-07-2012, 10:44 PM   #7
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Did your oil light go on when you were driving by chance?
z is offline   Reply With Quote
Old 01-08-2012, 12:45 AM   #8
ojala
Member#: 255441
05 Saabaru
A lot of parts stores will loan you a scan tool if you leave them your credit card number. Or you can find some real cheap ones from Harbor Freight that work just fine.
You need three things to have combustion: fuel, air, and spark
That was my (rushed) attempt to say that you need to make sure that those three things are getting to the cylinders.
Barring an engine blockage, seized bearing, or something else catastrophic like your oil light coming on before the engine stops then check fuses, relays, sensors, fuel pump, etc
Or find a local recommended shop...
Old 01-08-2012, 12:48 AM   #9
SP00LN_WRX
Member#: 305109
No but I wish it did so I could get some sort of an idea what is going on with it...my engine temp read high but that thing is always reading hot even when I first start it but it never shown any signs of over heating till now :/ and another thing my heater just started to go out on me as well like a day before this happened...
Old 01-08-2012, 12:53 AM   #10
SP00LN_WRX
Member#: 305109
Well thanks ojala! I'll Deffinetly check those things out tomorrow and if I can't figure it out ill call down to a shop and see what they say and quote me
Old 01-08-2012, 01:24 AM   #11
ojala
Member#: 255441
05 Saabaru
Ouch, does not sound good.
Good luck and hope it goes as painless as possible with the mechanic.
Old 01-08-2012, 03:33 AM   #12
multimediaman
Member#: 160425
2004 Impreza Outback
PacificaBluePrl+StlGryMet
Did you get this car new or used? I'm assuming used since you said it's always read hot...
How many miles is on it? and if it's used, do you know any of the maintenance that's been performed on it?
multimediaman is offline   Reply With Quote
Old 01-08-2012, 09:58 AM   #13
SP00LN_WRX
Member#: 305109
Got it used tac says 190k but with the swap it has only 58k on it...
Previous owner said the maintenance was kept up being he didn't drive it much but as soon as I got it I changed all fluids
Old 01-08-2012, 10:03 AM   #14
SP00LN_WRX
Member#: 305109
I'm really hoping its not a head gasket or something like that :/
sti wont start when engine is warm RichWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-09-2006 05:54 PM
Need Help Engine Wont Start VitoSu85 Service & Maintenance 12 07-15-2005 03:17 PM
engine wont start IWRXIT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-19-2005 02:24 PM
Engine Wont Start randomly...very frustrated trying to figure this out... Sc3pt0r General Community 21 08-25-2004 08:14 AM
Engine Wont Start jcalder Electrical & Lighting 0 03-30-2004 06:52 PM
