Old 01-07-2012, 06:54 PM   #1
Meatbawl
Member#: 175878
Subaru Stars Meatys guide to replacing rear main seal
1. Remove engine or transmission
2. Use 1 to 3 drywall screws and drive them into seal with a drill about 1/2" or so
3. Using a prybar (could probably use a claw hammer as well), pry up on the screws. Sometimes the whole seal will pop out with 1 screw, if not, pry on all screws a bit at a time.
4. Clean crank surface and inside of sealed area with a shop towel
5. Fill inner groove of new rear main seal with a lithium grease / assembly lube
6. Hold seal against crank and keep it aligned with your hand while driving it in with a plastic-tip hammer. As soon as it starts to go on a bit, tap the opposite sides in a criss-cross pattern to keep it going on evenly. Drive the seal to where it is even with the block surface.
Meatbawl is offline   Reply With Quote
Old 01-07-2012, 10:46 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks for this. I like this because it is:
1. Ghetto as hell
2. Works like crazy
<---------has hose clamps holding together busted exhaust hangers right now
Old 01-07-2012, 11:48 PM   #3
Tut4u2
Member#: 40424
05 STi
Yep...used this method last year..works. Just make sure the screws are in there otherwise they will just come out.
Tut4u2 is offline   Reply With Quote
Old 08-24-2012, 08:31 PM   #4
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
This is awesome, thanks!
Bad Noodle is offline   Reply With Quote
Old 08-25-2012, 07:02 AM   #5
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I thought flathead screwdrive and hammer worked just fine
And the factory seal didn't have any grease packed into it...
Old 10-24-2012, 06:25 PM   #6
sackytar
Member#: 149262
03WR Rallycar/FXT/OB
PrimerGrey
Yeah Buddy!!!! Easy!!
sackytar is offline   Reply With Quote
Old 11-11-2012, 12:15 AM   #7
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Great method. Nice and simple BUT... BE REAL CAREFUL YOU PLACE THE SCREWS SLIGHTLY TOWARD THE CASE SIDE OF THE SEAL. If you place the screw toward the crank side of the seal, and the screw contacts the surface of the crank, you run the risk of scoring the crank as you pull the seal out.
This can result in about 30 min of careful work with emery paper...
renhoek is offline   Reply With Quote
Old 11-11-2012, 12:50 AM   #8
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
1. Ghetto as hell
2. Works like crazy
Yeah well
<--------- has a hose clamp holding on an inner CV boot. For at least 2 years now!
recce02 is offline   Reply With Quote
Old 04-21-2013, 01:31 PM   #9
bipolarnrute
Member#: 340737
Exclamation
How serious would this be??
See the little nick to the right??
bipolarnrute is offline   Reply With Quote
Old 04-21-2013, 02:06 PM   #10
bipolarnrute
Member#: 340737
Shouldi bee worried ??
Old 11-28-2013, 09:21 AM   #11
balla_EG6
Member#: 336965
2007 WRX
GREY
AHAHhAhAhahHhAA
"ghetto as hell"
balla_EG6 is offline   Reply With Quote
Old 01-18-2014, 09:03 PM   #12
dknc
Member#: 8165
2001 RS 2.5
Asspen White
I just used a flat screen driver and pry it bit by bit and then digged into the ringand popped it out. For installation, I used the old seal and placed above the new one and use a hammer to tap it in. Without something holding it on one side while hammering the opposite side, it will tend to pop out from the side that is not being hammered. It's a pain. And then with the old seal on top, just slight hit each side and then check if it's flushed. Becareful not to hit it too hard, or the flat ring surface will be bent since it's made out of metal.
dknc is offline   Reply With Quote
Rear Main seal replacement, what else while in there? ScubaruImpreza05 Transmission (AT/MT) & Driveline 5 03-22-2010 11:25 AM
Replacing rear main oil seal (tips appreciated) vbevan Newbies & FAQs 1 06-24-2008 09:30 AM
Rear main seal replacement Lee MD Legacy Forum 14 04-26-2007 08:51 AM
how hard is it to replace rear main seal turbocolin Normally Aspirated Powertrain 14 05-04-2005 08:01 AM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
