Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 01-16-2012, 09:18 AM   #26
vicious_fishes
Member#: 158864
2003 GD w/EZ30D swap
Originally Posted by weathermon View Post
Hey VF - did you end up getting the pistons out of the block yet? I'm keen to see the condition of the pistons to see if any of them had cracked ring lands with the high AFR's. Really sucks you fried the rings though mate - but looking forward to seeing the new beast up and running
not as yet. i should *hopefully* be able to get to it tomorrow. everything else is off the block - i just gotta crack it open.
although that will be put on the backburner should my engine arrive haha!
vicious_fishes is offline   Reply With Quote
Old 01-16-2012, 12:06 PM   #27
delongedoug
Member#: 124113
and beyond!
I can't say I've ever seen a build with removed sound deadening and new speakers.
delongedoug is offline   Reply With Quote
Old 01-16-2012, 06:45 PM   #28
drumchum
Member#: 286027
2008 WRX
I was thinking the same thing! , OP i am definitely subscribed and interested to see how this turns out! good luck!
drumchum is offline   Reply With Quote
Old 01-16-2012, 07:33 PM   #29
vicious_fishes
Member#: 158864
i need my tunes alright guys
i gotta drive this thing on the street too
Old 01-16-2012, 10:57 PM   #30
delongedoug
Member#: 124113
and beyond!
Hey, I'm right there with you. I'm gutted but left my speakers for those long drives to and from the track.
Old 01-18-2012, 07:37 AM   #31
vicious_fishes
Member#: 158864
alright so what effective anti-surge units are out there that don't cost the earth?
Old 01-18-2012, 11:27 AM   #32
dunk
Member#: 15359
Buy the tank on e-bay, then use a walbro external pump. Look at my below thread, start at post 510.
http://forums.nasioc.com/forums/show...e+tank&page=11
dunk is online now   Reply With Quote
Old 01-18-2012, 12:05 PM   #33
vicious_fishes
Member#: 158864
update for today:
these things arrived:
so did these:
so i installed them!
Old 01-19-2012, 04:09 AM   #34
vicious_fishes
Member#: 158864
finally had the torx piece i needed arrive to tear down the heads (or tear them down as much as i can on the bench) to put the new cams/valve springs in.
Old 01-19-2012, 08:49 AM   #35
Rokkit
Member#: 84181
NASA #530 GTS2
Where you going to be running? I run with NASA up here in the Northeast/Mid Atlantic. Would be nice to see another subie running around out there
Rokkit is offline   Reply With Quote
Old 01-19-2012, 10:58 AM   #36
vicious_fishes
Member#: 158864
australia
if you look back through the pics you'll see somewhere i'm RHD
in other news - i'm hoping i can get some input from the chassis gurus on here. i've got a rear chassis brace as follows:
and what i'm wondering is: seeing as it works on tension that stops the chassis from flexing or "pulling sideways" if you will, whether mounting the cables as horizontal as possible is the best way to do it.
i.e i can mount them bottom, middle, or furthest out as shown in the following picture:
as you can see i've got it mounted in the middle at the moment to hedge bets either way, but so far as i can tell the chassis/strut towers aren't going to flex "up" but rather "out", thus the furthest out point would be optimal to mount.
but, i'm not the chassis guru!
anyone able to offer some input?
Old 01-19-2012, 12:47 PM   #37
Rokkit
Member#: 84181
NASA #530 GTS2
Bah, an Aussie...
Where abouts? I might be headed that way for work
Old 01-19-2012, 01:05 PM   #38
vicious_fishes
Member#: 158864
depending on when you come here, melbourne most likely
what work?
Old 01-19-2012, 04:39 PM   #39
slovak
Member#: 168922
07 STi
Obidissian Black
as for the bracing, I want to say that someone makes a brace for this, don't if it is cusco or gt spec. I have seen some people make their own by welding metal that goes in the same direction as you have, some just weld it as much as possible. Everyone has their own opinion on body bracing. I will see if I can find something for you, kinda slow at work at this point, not to mention I want to see this car done as soon as possible.
I would like other opinions on this with some pictures. I will try to support my theory in some way.
slovak is offline   Reply With Quote
Old 01-19-2012, 04:48 PM   #40
slovak
Member#: 168922
07 STi
Obidissian Black
This might be something you might be interested in;
http://www.gtspec.com/product/gtspec...ge-0206-wrxsti
http://www.gtspec.com/product/gtspec...e-impreza-gdgc
I will keep looking around for you. Let me know what you think.
Old 01-19-2012, 07:46 PM   #41
vicious_fishes
Member#: 158864
so i just got a call saying something had arrived... can anybody guess what it is?
Old 01-20-2012, 06:33 AM   #42
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
a turbo
And70 is offline   Reply With Quote
Old 01-20-2012, 07:26 AM   #43
Mr.Burns
Member#: 290898
I have yet to install this, but this is what I purchased.
http://turninconcepts.com/product_in...oducts_id=1176
Mr.Burns is offline   Reply With Quote
Old 01-20-2012, 08:18 AM   #44
vicious_fishes
Member#: 158864
Originally Posted by And70 View Post
a turbo
nope, but i do at least get to start putting SOME stuff back together
too much IMO. i figure the cable version + a strut bar for half the price will be just as effective.
Old 01-22-2012, 08:14 AM   #45
vicious_fishes
Member#: 158864
a turbo
it was this!
and after a fairly boring afternoon, it became this!
i've since put all the newer/better oil pump, coolant pump, sensors, pulleys etc from my old shortblock onto this one ready to slap the heads on when my cams/valvesprings arrive.
i scored the donk from a wreckers with a leaky headgasket (confirmed, and i binned it) for just 300 bucks. they assured me everything was fine but all i needed was the bare shortblock. bonus is i got a timing belt just a couple of thousand k's old with it
what's left aside from the heads is to put the flywheel/clutch back on, install a couple of sensors for the ECU, clean up the deck for new headgaskets, and of course install the engine mounts & sump with pickup/baffle plate.
Old 01-25-2012, 12:36 PM   #46
slovak
Member#: 168922
07 STi
Obidissian Black
Damn, looks like you got a bargain. What else are you waiting for besides the cams and springs? Any more other things like a header or you planning on a turbo down the line?
Old 01-25-2012, 10:52 PM   #47
vicious_fishes
Member#: 158864
there's a supercharger buried in one of the pictures
i've got a few other goodies on the way now too
Old 01-26-2012, 11:01 AM   #48
vicious_fishes
Member#: 158864
got a bit more done this morning.
installing the stonger pickup/upgraded baffle plate
along with the stiffer engine mounts, higher capacity sump and clutch/flywheel onto the new donk!
i also scrubbed down the deck to put new headgaskets on as the old ones were indeed weeping. they'd bubbled and so forth in the deck so were about toast.
the barb fitting you see on the sump is to run the return line from an air-oil separator to.
one problem i am having is that i've inadvertedly thrown out the little tool i need to centre the clutch on the flywheel
i got one with the clutch (it's just a simple plastic thing) but nonetheless managed to throw it out. going to have to see if the local workshop has a spare or head in to the stealership.
Old 01-26-2012, 02:27 PM   #49
pgallagher
Member#: 308075
Lots of nice work... keep the pics coming.
pgallagher is offline   Reply With Quote
Old 01-27-2012, 04:15 PM   #50
ScottyB
Member#: 155883
2005 Impreza 2.5RS
bacon rage
looking good, i like where you're going with it! (from another RS owner)
ScottyB is offline   Reply With Quote
Soccer05 Bugeye GTX3071 ej205 Street/Track Build Thread soccer05 Member's Car Gallery 620 05-19-2015 08:25 PM
DutchOven's Daily-driving, 2010 SWP WRX Track Slut build & showoff thread. DutchOven Member's Car Gallery 132 12-20-2013 09:23 PM
FS : Varis Half Carbon Front Lip 04-05 WRX, STI **Track Warrior Scars Included** rey_vibora Exterior/Styling 47 02-23-2012 06:51 AM
('08-'10) My car history and small build thread of 09 LR Impreza 2.5i 5mt! sl0wbaru Impreza Forum 4 10-04-2011 05:36 PM
Finally got my ej207, here is my build thread! Cyclops Built Motor Discussion 77 11-04-2009 11:19 AM
