Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 01-29-2012, 04:01 AM   #51
vicious_fishes
Member#: 158864
2003 GD w/EZ30D swap
sprayed my calipers:
whilst they came up good i was hoping the colour was a bit darker. i wanted the ferrari/porche yellow brake colour which is a very dark/slightly orange yellow, but as you can see they're basically banana yellow.
a gloss pack or similiar might darken them up a bit. need to go buy a can assuming it exists.
vicious_fishes is online now   Reply With Quote
Old 01-30-2012, 05:54 AM   #52
vicious_fishes
Member#: 158864
omg YES YES YES JUST GOT AN EMAIL BACK FROM UNITED PETROLEUM AND THIS STATE IS FINALLY GETTING E85 WOOOOOOO
Old 01-30-2012, 08:45 AM   #53
vicious_fishes
Member#: 158864
about to sort out the surge tank, couple of questions:
this diagram is the best way to set it up yeah?
and i'm trying to work out the difference between in tank & external pumps. i've currently got a walbro 255 in-tank replacement, what's stopping me from running that externally?
Old 01-31-2012, 08:37 AM   #54
Mr.Burns
Member#: 290898
i've currently got a walbro 255 in-tank replacement, what's stopping me from running that externally?[/quote]
Being in tank is for cooling the the pump I believe.
Mr.Burns is offline   Reply With Quote
Old 02-01-2012, 07:51 AM   #55
subasurf
Member#: 192883
1995 E36
Red
gday gday
Nice thread mate. Enjoying the build.
subasurf is offline   Reply With Quote
Old 02-01-2012, 11:48 AM   #56
vicious_fishes
Member#: 158864
cams/valvesprings should be done monday so i can FINALLY start putting the engine back together.
Old 02-01-2012, 12:00 PM   #57
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Don't worry, after some hard track sessions those front calipers will be dark yellow/brown anyway
boost junkie is offline   Reply With Quote
Old 02-01-2012, 12:27 PM   #58
vicious_fishes
Member#: 158864
i'm ok with this
they had all manner of paint missing and so forth so they needed a coating to keep the corrosion etc out. so i scrubbed them down and went with brightass balls-out yellow
Old 02-05-2012, 06:33 PM   #59
vicious_fishes
Member#: 158864
bonnet vents are cut. i've still gotta mesh them, clean them up etc etc (still marker on the bonnet and some other stuff) but that's a rough idea of how they're going to look.
should have my heads in a few hours.
Old 02-06-2012, 07:43 PM   #60
slovak
Member#: 168922
07 STi
Obidissian Black
Looking good. Get your heads back yet? lol. Loving the in-your-face-yellow, definitely stands out, in a good way.
slovak is offline   Reply With Quote
Old 02-08-2012, 07:53 AM   #61
vicious_fishes
Member#: 158864
pics momentarily
Old 02-08-2012, 08:12 AM   #62
Evil STI
Member#: 36792
2014 Camaro 1LE
gold chains & meatballs
edited
Evil STI is offline   Reply With Quote
Old 02-08-2012, 08:42 AM   #63
vicious_fishes
Member#: 158864
these bad boys arrived
and i managed to get this far yesterday:
and got it done today!
it's alive it's alive!
and how the vents look at the moment:
haven't even begun to clean them up etc.
engine is just N/A at the moment as i've got a new charge pipe/etc coming. not that it matters as i need to wear the cams in as it is.
i only made one error reinstalling and that is that i got my fuel in/return lines mixed up. ergo the pump pressurised the line AFTER the regulator. anyone know if this can harm it at all?
stay tuned for more!
Old 02-08-2012, 01:10 PM   #64
slovak
Member#: 168922
07 STi
Obidissian Black
Damn, got this thing done pretty damn quick if I may say so. What else you going to do to the car? or is it one of them things to what we just need to wait for? Don't know if that can harm it, but I know that the car wont start if they are mixed up. Speaking of fuel related things, I need to re-do my set up.
Old 02-08-2012, 04:12 PM   #65
vicious_fishes
Member#: 158864
plenty to do yet, i just had to get the damn engine in.
and yeah, learnt that the annoying way. crank-crank-crank-crank-crank-crank-crank-crank-FFS START?
stop, squirt aerostart down the intake, crank-crank-crank-crank-KICKS OVER...
ok so it's fuelling... start checking that, yep injectors are attached, lines atta-OH F**K ME
Old 02-08-2012, 06:49 PM   #66
slovak
Member#: 168922
07 STi
Obidissian Black
LMAO!!! Thats why I taped mine and wrote on there which way they go. I knew I would of, at that time, burned the car to the ground, then just sit there and dump it somewhere and buy something else. BUT, I didn't, so now it just sits as I am awaiting parts myself. Hate playing the waiting game.
Old 02-09-2012, 01:50 AM   #67
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
just wondering as seeing the stock Rs hood is the heavy ass steel version wouldn't you have been better getting an alloy wrx hood and run a reverse scoop for weight saving?
And70 is offline   Reply With Quote
Old 02-09-2012, 06:52 AM   #68
vicious_fishes
Member#: 158864
if i could have got my mits on one, yes
but the reverse scoop actually flows air INWARDS. the area of the windscreen join is actually high pressure. if you check out the "homemade aero" thread you'll see some data on it.
the front of the bonnet is the lowest pressure points. (in fact any part of the front half is negative pressure or suction) so the vents basically need to go just after the radiator ala evo.
i searched for months for an alloy bonnet but didn't have any luck, so i had to keep/slice up the steel one.
more goodies arrived in the mail today, will post up pics in the morning.
Old 02-10-2012, 01:57 AM   #69
vicious_fishes
Member#: 158864
much better picture of the engine bay as it sits running the cams in:
these arrived in the mail:
to put these on:
and i also run a "custom" setup with the AOS.
the AOS (i'm sure you can guess the brand) actually runs both a breather line out of the top crankcase ventilation, and runs a return line for the oil back into the SAME vent hole. the idea being that the blowby flows up one tube and then just trickles down the other/isn't forced up because oil sticks to the side of the tube and is much heavier than air. this obviously isn't optimal, so i now have a line out from the top of the crankcase and actually have the oil return line run straight back down into the sump:
as you can see, it runs out of the sump with a brass barb, and then up between the swaybar and the steering rack, through the hole in the engine crossmember and then runs straight into the bottom of the AOS.
this is what i consider to be the ultimate blowby/crankcase breather setup.
Old 02-11-2012, 03:17 PM   #70
slovak
Member#: 168922
07 STi
Obidissian Black
damn, this looks great, was hoping you would have the SC on there, can't imagine how nice that is going to sound. Have you driven the car yet with it in the NA setup? Also, are you going to wrap your plug wires in heat resistance wrap? Just curious.
Old 02-11-2012, 09:04 PM   #71
vicious_fishes
Member#: 158864
been driving it around running the cams in. i'm about halfway there.
SC will go on soon enough, and i've never seen a reason to wrap the plug leads?
Old 02-11-2012, 10:32 PM   #72
slovak
Member#: 168922
07 STi
Obidissian Black
Got friends that do it on their V8s, just so the heat does not get to em, since I know you got more heat over there, and since you will be road racing it, might hellp the spark plig wire. Just some food for thought. Since we are on spark plug wires, are you running any special set of them, or are they just replacements?
Old 02-12-2012, 12:55 AM   #73
vicious_fishes
Member#: 158864
just standards with plugs a step colder. never had a problem.
Old 02-13-2012, 03:19 AM   #74
slovak
Member#: 168922
07 STi
Obidissian Black
I got you, and the reason for my question is because I have a ton of V8 guys that run that DEI stuff on their plug wires since they are right by the headers. They say it does not make the plug wire as hot, one even did some test and he said after a few runs his car ran slower and felt that not all was there. Don't ask me for the data, this was way back in 2007 and it was on GTO, or as you guys call em, holden monaros. Just wish they would of came SC from the factory. Anyways, keep it up, and also, what else you got? any vids?
Old 02-13-2012, 02:27 PM   #75
vicious_fishes
Member#: 158864
more coming don't worry
Soccer05 Bugeye GTX3071 ej205 Street/Track Build Thread soccer05 Member's Car Gallery 616 02-04-2015 01:24 AM
DutchOven's Daily-driving, 2010 SWP WRX Track Slut build & showoff thread. DutchOven Member's Car Gallery 132 12-20-2013 10:23 PM
FS : Varis Half Carbon Front Lip 04-05 WRX, STI **Track Warrior Scars Included** rey_vibora Exterior/Styling 47 02-23-2012 07:51 AM
('08-'10) My car history and small build thread of 09 LR Impreza 2.5i 5mt! sl0wbaru Impreza Forum 4 10-04-2011 06:36 PM
Finally got my ej207, here is my build thread! Cyclops Built Motor Discussion 77 11-04-2009 12:19 PM
