Old 01-08-2012, 02:57 PM   #1
SedonaRedwagon
Member#: 291575
2002 WRX Wagon
Sedona Red
Question 2002 WRX Stage 2 Datalog, fine knock and boost spike problems
I have a Stage 2 2002 WRX that seems to have large boost spikes and some erratic fine knock numbers, here is the sreadsheet
3rd gear pull
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
Upgrades:
Invidia Bellmouth downpipe
Borla XR-1 Catback
Stock Airbox/filter
Stage 2 V.310 map
Should i be using a Low wastegate duty map? or could it be another issue im facing?
If i missed any info you guys may need just let me know
Thanks for all the help!
-Anthony
SedonaRedwagon is offline   Reply With Quote
Old 01-08-2012, 06:10 PM   #2
Cobb Tuning
Member#: 4803
3rd gear pull
Upgrades:
Borla XR-1 Catback
Stock Airbox/filter
Stage 2 V.310 map
-Anthony
Your boost is a bit erratic. What is the history of the car? Has it ever had a manual boost controller or have the wastegate lines been touched in any way?
Bill
Old 01-08-2012, 06:59 PM   #3
SedonaRedwagon
Member#: 291575
2002 WRX Wagon
Sedona Red
I bought the car completely stock with 87,000 miles on it, it has 99,000 miles on it and it never had a boost controller. ive never touched the wastegate lines. the only thing i can think of is that i installed a manual boost gauge and the vacuum line is leaking a little bit. i have heard that bellmouth downpipes may cause boost creep but this is different. when it was stage 1 it didn't have this problem
Old 01-08-2012, 07:50 PM   #4
SedonaRedwagon
Member#: 291575
2002 WRX Wagon
Sedona Red
I forgot to mention that i installed a catless uppipe, sorry i missed that haha
Old 01-09-2012, 10:16 AM   #5
Cobb Tuning
Member#: 4803
I would get that vacuum leak fixed and go from there. You may also want to get a pressure/smoke test of the intake tract done.
Bill
Old 01-09-2012, 10:28 AM   #6
SedonaRedwagon
Member#: 291575
2002 WRX Wagon
Sedona Red
Will do, thanks for the advice Bill ill let you know the results
Old 01-10-2012, 09:34 PM   #7
SedonaRedwagon
Member#: 291575
2002 WRX Wagon
Sedona Red
Ok i adjusted the vaccum hose a little and that seemed to have helped. today i also installed an SPT intake, i reset the ecu after installation and then went for a drive so that the car could re-learn with the intake and just to be safe i used the stage 2 LWG v.310 map as a realtime map. i think the problem was that i didn't properly let the ecu relearn when i installed the downpipe because the datalog i took after installing the intake seems to be alot better. heres the datalog with the SPT intake and other mods listed above.
No fine knock learn, boost is not erratic but tapers off at the end( think its becuase of the LWG realtime map i put on there) I kept an eye on A/F ratio and it wasn't out of the ordinary. Anything i missed?
Old 01-11-2012, 10:31 AM   #8
Cobb Tuning
Member#: 4803
Unfortunately, the SPT intake isn't compatible with our maps. It may cause issues with reported airflow and therefore impact fueling and timing. You can get the intake tuned for by a protuner, however.
Bill
Old 01-11-2012, 10:50 AM   #9
SedonaRedwagon
Member#: 291575
2002 WRX Wagon
Sedona Red
huh, according to the sticky at the top of the page it said it was compatible, well i dont plan on driving aggressively anyway until i get that tune, which will be very soon. Thanks for the heads up about that Bill.
Old 01-11-2012, 02:38 PM   #10
Cobb Tuning
Member#: 4803
When the SPT intake was released, we assumed that Subaru had taken pains to make sure that the reported airflow was reasonably accurate given the stock MAF calibration, but, over the years, our calibrators have found that this is not the case.
You'll be OK if you are about to get a tune - I would just not put the car under any heavy load to be on the safe side.
Bill
2002 wrx stage 2 and intake? nattywrx Newbies & FAQs 7 03-30-2011 05:24 PM
FS: 2002 wrx stage 2 twrx2002 Tri-State Area Private Classifieds 2 10-19-2006 03:38 PM
guaging interests 2002 wrx stage 2.5 norcalboi114 NWIC Private Classifieds 3 07-24-2006 04:37 AM
2002 wrx stage 2.5 cobb collin44 Private Vehicle 'For Sale' Classifieds 0 03-20-2006 10:25 PM
OH: 2002 WRX Stage 2 <Excellent Condition> $9500 TRUDAWG Private Vehicle 'For Sale' Classifieds 17 03-15-2006 05:04 PM
