Old 01-08-2012, 06:19 PM   #1
leecea
Member#: 37359
2003 WRX
Default Root cause of raw fuel smell issue?
First, I do not have the fuel leak for which the SOA fix applies. But, I did just get a fuel leak from a different hose on the days when it got very cold in PA.
Does anyone know why cold temps caused the original leak?
I want to see if the same root cause would apply to my leak (from a piece of non-OE fuel hose that connects to the fuel filter "in"). I was fine during the warm months and seems fine again now that we're in the 40s.
Thanks.
leecea is offline   Reply With Quote
Old 01-08-2012, 10:31 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Well - the fix is to shorten the hard line and lengthen the rubber hose - based on that, I would guess that as it gets cold, the rubber line gets stiff - if it's short, there isn't enough material there to deal with engine vibration, and the seal is lost, resulting in a leak.
I would check the fuel line and make sure it's not scored on the inside or something, then try a different clamp to hold it in place (maybe the tubing is too large an id and when you crank down the clamp, it results in a leak?)
Old 01-09-2012, 12:44 AM   #3
leecea
Member#: 37359
2003 WRX
Thanks. Since my issue is the rubber hose connection from the firewall to the fuel filter, engine vibration isn't an issue. I've re-tightened the clamp, but I'll have to wait until it gets cold to see if it starts leaking again.
Raw Fuel Smell Log fluffybunny Warranty Issues & SOA Problems 3400 04-24-2016 09:28 PM
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 11:28 PM
Raw Fuel Smell/Leaking Fuel Line on WRX pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 39 02-10-2009 12:50 AM
Raw Fuel Smell.... Rebellion South East Region Forum 7 01-25-2005 10:48 AM
Raw Fuel Smell Giljorak Rocky Mountains Impreza Club Forum -- RMIC 10 03-08-2002 08:03 AM
