Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-08-2012, 07:18 PM   #1
toolie
Member#: 273955
2011 WRX Prem. Hatch
Default '11 WRX rough idle when coming to stop
Hi, my 2011 WRX has started hesitating a little bit when I'm coming to a stop. Just after I put the clutch in shift into neutral to come to a stop the RPMs dip to 500 or so and I can feel the stick shift vibrate a little. It feels almost like the car is going to stall for a split second and then the revs come back up to normal. Seems to be happening since the weather got colder.
Any ideas what might be causing this?
toolie is offline   Reply With Quote
Old 01-08-2012, 07:21 PM   #2
scootarida1
Member#: 154534
2005 Forester XT
Borg Warner S261
do you have a bov, lightweight pulley or flywheel?
scootarida1 is offline   Reply With Quote
Old 01-08-2012, 07:29 PM   #3
143subaru
Member#: 157982
2002 Impreza WRX
World Rally Blue
Mine did that when it was flooding because of a bad tune/lack there of...
143subaru is offline   Reply With Quote
Old 01-08-2012, 07:31 PM   #4
Markovichsr20
Member#: 270371
2004 sti
grey
modifications?
have had any work done lately or just the colder weather
Markovichsr20 is offline   Reply With Quote
Old 01-08-2012, 07:32 PM   #5
toolie
Member#: 273955
The car is bone stock. I've done the break-in and subsequent oil changes myself with Rotella T6. The last oil change was 11/06 but this behavior just started within the last week or so.
Old 01-08-2012, 09:24 PM   #6
WashmyScooby
Member#: 83820
mine just started doing it with the colder temps as well. It's probably a rich condition caused by the cold, dense air?
WashmyScooby is offline   Reply With Quote
Old 01-09-2012, 07:59 AM   #7
TomSTi
Member#: 300431
2012 WRX STi
ISM
Is the heat in "auto" mode? Try manually turning the A/C off, it might be running to defog/dry the air. If it stops in that case, you might have a failing compressor or a refrigerant leak.
TomSTi is offline   Reply With Quote
Old 01-09-2012, 10:13 AM   #8
JordanM9
Member#: 273214
2013 WRX Limited
CBP
The compressor should not be going out on such a new car... I think the stock tune could also be to blame, because I have not seen the problem even in some temps down below 20 deg F
JordanM9 is offline   Reply With Quote
Old 01-09-2012, 11:45 AM   #9
VinSVT
Member#: 77637
The A/C compressor went out on my 2011 WRX with less than 2000 miles.
Subaru replaced it no questions asked.
VinSVT is offline   Reply With Quote
Old 01-09-2012, 11:58 AM   #10
toolie
Member#: 273955
Yeah, I use auto mode. I'll switch it to manual for a while and see if that clears things up. Thanks.
@JordanM9 - Regarding things that shouldn't happen to a brand new car, I've had the passenger side blinker and driver side daytime bulb blow already. So I'm willing to accept that anything could go wrong.
Old 01-09-2012, 08:26 PM   #11
toolie
Member#: 273955
Turning off the auto climate control didn't help.
Old 01-09-2012, 08:54 PM   #12
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Did you have the car in defrost mode? The compressor only turns off on manual heat or vent settings.
Dave D. is offline   Reply With Quote
Old 01-09-2012, 09:33 PM   #13
Longarm
Member#: 132140
'11 WRX Hatch
SSM
Joining this thread - my 2011 does this also. Not all the time, but enough that i noticed it and began to worry
Longarm is offline   Reply With Quote
Old 01-09-2012, 09:59 PM   #14
ande7824
Member#: 289032
2012 WRX sedan
Plasma Blue Pearl
I have noticed my 2012 does this as well. Kinda bothers me :/
ande7824 is offline   Reply With Quote
Old 01-09-2012, 10:56 PM   #15
BarTmaN
Member#: 235650
2011 WRX
Mine does the same thing. Only happened a handful of times though.
BarTmaN is offline   Reply With Quote
Old 01-10-2012, 12:28 AM   #16
toolie
Member#: 273955
I had it on manual heat at the floor setting and no defrost.
Old 01-10-2012, 12:30 AM   #17
toolie
Member#: 273955
Yeah, it's not all the time for me either but it makes me feel like something isn't right. Ran like a top all spring/summer/fall and now notsomuch, so I feel like the cold has something to do with it.
Doesn't seem to matter if the engine is cold or fully up to temp.
Old 01-10-2012, 02:06 AM   #18
YBNormal015
Member#: 217168
My 08 has done that in the past except mine was sometimes during 75 degree weather and sometimes with 20 degrees. It didn't seem to matter to much. It worried me when it would do it because there is nothing you can do. The clutch is in and im stopped, you hit the gas to get the revs up but that doesn't help. Im glad to know im not the only one who this has happened to.
YBNormal015 is offline   Reply With Quote
Old 01-10-2012, 09:18 AM   #19
AWD Freak
Member#: 262593
I had an issue like this on my 08 wrx. The tumbler valve generator had to be replaced. The master tech at the dealership knew what was wrong and said its common to have to replace them. You can thank the EPA for having to have them in the first place.
AWD Freak is offline   Reply With Quote
Old 01-10-2012, 11:38 AM   #20
foolycooly
Member#: 260545
2011 WRX Limited 4dr
have had this problem since I've owned my 2011...happens randomly and is often the cause of a random stall (like when reversing out of a parking space, then shifting to first and starting to move). If the dips coincide with when you try to get rolling, it makes stalling very easy. It doesn't really bother me any more because I am now used to all of the shifting quirks of my car. I do recall seeing a thread a while ago on this same topic and having other people quote the TGVs as the issue as well.
foolycooly is offline   Reply With Quote
Old 01-10-2012, 12:17 PM   #21
toolie
Member#: 273955
I blew an email into my dealer last night to see if they had heard of this happening before now that it seems at least a few of us have had the problem. Probably won't hear back. Now maybe I'll call and ask about this tumbler valve generator.
Old 01-10-2012, 12:46 PM   #22
DCsubaru88
Member#: 301561
2012 WRX LTD 5 Door
Ice Silver Metallic
I've read that this is normal behavior for all subarus in cold weather, heat on, etc.
My 2012 occasionally will dip at idle but all the times I've noticed it happening was with the air compressor on manual mode (i don't use auto). It doesn't bother me because of the infrequency. If it actually affected my drive, I'd be a little more concerned, or if my air didn't work....
DCsubaru88 is offline   Reply With Quote
Old 01-10-2012, 01:07 PM   #23
CO11WRX
Member#: 304018
2011 WRX Sedan
TP Stage 1
This is pretty much what I have experienced (minus the actual stalling). When backing out of a parking spot, or pulling into my garage, the revs seem to dip almost to zero. I plan on asking about this when I go in for my next oil change.
Edit: forgot to mention that I can replicate the issue consistently, whether or not the a/c, defrost is on.
CO11WRX is offline   Reply With Quote
Old 01-10-2012, 01:42 PM   #24
toolie
Member#: 273955
It's sounding more and more like it's common, but it didn't happen on my 2002 WRX (or any other car I've owned), although a lot could have changed since then at Subaru. Regardless, the car nearly stalling on a regular basis shouldn't be considered 'normal'. I can't see the engine basically choking itself regularly as a Good Thing™.
It effects my driving very much. I'm constantly anticipating it now, which is annoying. And I have to wait a beat every time it happens for it to sort itself out rather than proceeding. I admit I'm more of a rolling stop kind of guy, shoot me.
I've set up an appointment to have the car looked at on Thursday and I'll report back.
Old 01-10-2012, 02:34 PM   #25
littlewhitewagon
Member#: 103068
11 STI sedan
These low engine speed conditions are somewhat common on newer cars to lower emmissions at idle and similar situations. As long as the car doesn't stall, it's nothing to spend too much time on. The ECU is trying to keep the injectors off for as long as possible and doesn't turn them back on (idle is about 2.0-2.2mS) until a little later. Then as you sit there, the ECU is trying to run as lean as possible to save fuel. A rock solid idle is not something that is expected these days because most people have no idea what that tachometer means anyway.
littlewhitewagon is offline   Reply With Quote
My 2004 WRX STI stalls when coming to a stop or at a stop sign. panchez0423 Newbies & FAQs 17 12-10-2015 08:03 PM
06 wrx rough idle when AC is on achavez Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-09-2011 09:47 PM
car doesnt want to idle when coming to a stop dukeduster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-22-2009 04:00 PM
Noise when come to stop or turn??? wrxdragger Brakes, Steering & Suspension 0 12-04-2006 01:57 PM
when coming to stop pedal drops a little bit... any fix? i102spd Brakes, Steering & Suspension 9 08-03-2005 09:02 AM
