Old 01-08-2012, 08:06 PM   #1
gene22
Member#: 273790
2012 Impreza Sport
Default 2011 WRX Shifting Issue
Has anyone noticed a occasional slight grinding when shifting into second and third with a 2011 wrx? It seems like it happens more at lower rpm
gene22 is offline   Reply With Quote
Old 01-09-2012, 01:21 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
These trannies are always slow and stiff when cold, but I'm not sure if this is what you're talking about.
flycaster is offline   Reply With Quote
Old 01-09-2012, 05:43 PM   #3
gene22
Member#: 273790
2012 Impreza Sport
I notice it when I shift at low rpm even when warm. It only happens every once in A while
Old 01-12-2012, 05:52 PM   #4
donkey_cart
Member#: 151448
2007 FXT sports
UGM
My car would pop out of gear in 3rd at low RPMs, plus the slight grind. Occasional at first, then I could make it happen every time i drove it.
Talk to the dealer ASAP to document the problem. Mine is getting the trans torn apart and re-built ;(
donkey_cart is offline   Reply With Quote
Old 01-12-2012, 11:19 PM   #5
Tripintaz
Member#: 245218
2013 STI Limited
That is not right at all. Take it to the dealer and tell them about it. Grinding can be caused by too low of fluid level, wrong type of fluid, damaged syncros, broken c-clips the hold the gears in place, or bent shift forks.
None of these should be happening to a new car unless the transmission was abused.
Tripintaz is offline   Reply With Quote
Old 01-13-2012, 01:47 AM   #6
xbeamelite
Member#: 281250
2007 STi Ltd
UGM
I have something similar but only in third and only low rpm once in a while...It doesn't really grind as much as feels like metal contact for a split second. When I shift 3.5k rpm and above never happens. Not sure if its really "normal". I do have a kartboy ss with both bushings...I think its been documented on 3gwrx. My experiences arent as bad, but maybe try the new subaru tranny fluid? http://www.3gwrx.com/forum/index.php?topic=11874.0
xbeamelite is offline   Reply With Quote
2011 wrx overheating issue, help please THE_SMURF Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-01-2014 09:32 PM
2011 WRX Hesitation Issue at Full Throttle jpinto516 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 06-08-2011 01:50 AM
2011 WRX supply issues? DAC17 General Community 5 04-18-2011 06:27 AM
2011 WRX turbo issues. . . maybe??? THE_SMURF Warranty Issues & SOA Problems 27 04-09-2011 08:03 PM
2011 WRX HVAC issue...? blindgoldfish z Electrical & Lighting 19 01-01-2011 12:36 PM
