Old 01-09-2012, 04:38 PM   #1
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Default Question scaling injectors
I'm fairly new to tuning so bear with me, but I have a car with a stock intake but STI pink injectors, and the car is a 2002 WRX with a 2003 ECU.
Today, I went out to scale my injectors and this is what I found:
I have them now so anything above 1.7 V on the MAF, I have +/- 1% combined fuel trim error, but from 1.5 - 1.7 V I see as low as -5% correction, and lower than 1.5V, I see 3% correction.
Also, right after starting up the car, even if it is already warm, I see around -22% fuel trim, which is very strange. But once I drive around and let it idle, It sits around 3%.
Any input would be greatly appreciated, thank you in advance.
BlazeRex is offline   Reply With Quote
Old 01-09-2012, 04:52 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
sounds fine to me, I like to be within +5,-5%
renosubby is offline   Reply With Quote
Old 01-09-2012, 10:38 PM   #3
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
True, and I'm very happy I have it scaled very nice after 1.7V on the MAF, but just thought it was weird that corrections go positive, then drop negative, then level out perfect. I was just getting afraid something like an O2 sensor failed or had a bad injector.
But at least that's reassuring hearing that the +/- 5% overall seems to be in spec.
Also, any comment on the -22% corrections upon startup?
Old 01-11-2012, 11:26 PM   #4
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Ur just dumping fuel on cold start by the sound of it.. prob settles as temps stabilize and idle goes to normal rest?
What settings did you use for your pinks?
I run a stock intake but still scaled my MAF to get <2% trims, they will fluctuate from time to time but TBH if you are 5-7% I would not loose any sleep
Hows your WOT fuel?
Kastley85891 is offline   Reply With Quote
Old 01-13-2012, 06:31 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
if you rescale the maf so all your corrections are the same way (IE all positive or all negative) then the car will drive smoother.
Old 01-15-2012, 07:50 PM   #6
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Hows your WOT fuel?
Yeah, the corrections are not too bad, I'm just really anal with things like this, so I like to have it as close as possible.
I have the injectors scaled at 560cc and .8 latency at 14V, thats the best I could get it so all my corrections were close enough to zero.
Thanks for the tip! I will try scaling the MAF and see if that helps, I was just making sure there wasn't another issue I was missing.
Old 01-15-2012, 09:40 PM   #7
sorrowfulkiller
Member#: 170439
I <3 Lamp
Scaling the maf is the only way to get the injectors to function perfectly like you want them to. although +-2.5% is not really any fuel in the scheme of things.
sorrowfulkiller is offline   Reply With Quote
Driving on different scale injectors TheSomethingorother Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-08-2009 12:38 PM
Scaled injectors in ECU map. Now Pulling alot of fuel out. NITROS Mid West Subaru Owners Club Forum -- MWSOC 7 08-16-2007 02:51 AM
scaling injectors orionh2215 AccessPort 5 03-11-2007 10:00 AM
anyone know how to scale injectors kcook Mid Atlantic Impreza Club -- MAIC 6 07-25-2006 04:46 PM
Cobb StreetTuner: Question involving Injector scale. darksands Engine Management & Tuning 1 10-18-2005 11:05 PM
