Old 01-10-2012, 06:38 AM   #1
WrxBrooks
Member#: 263302
2004 Wrx
Default Burning smell
So I'm on the freeway yesterday and I smell this burning smell so I think nothing of it and assume it's the car in front of me so I get off the freeway and still smell it so I pull over open the hood and it's not a heavy scent kinda faint so I'm thinking it's just caught under the hood from another car but then on my way home later that night I smell it again but can't find out where it's coming from I really only smell it when the heat is on but I haven't really put it to the test to see what else it could be if anyone has some insight on what it could be let me know please
WrxBrooks is offline   Reply With Quote
Old 01-10-2012, 08:18 AM   #2
oneputt
Member#: 57607
2003 wrx wagon
red
My wife said the same thing about our 03 wagon. Sh had just gotten off the highway and when she parked the car and got out, she smelled something hot and burning. I am curious on what others think as well. Coolant, brakes, etc was all fine as I talked her through things to check. Catalytic converter??
oneputt is offline   Reply With Quote
Old 01-10-2012, 10:48 AM   #3
WrxBrooks
Member#: 263302
2004 Wrx
Yes please people any insight on this would help
Old 01-10-2012, 11:07 AM   #4
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
What does it smell like? Oil, clutch/ brake pad?
You might have ran over something like a plastic bag that got melted to the exhaust.
I would also check you oil level, it might just be oil leaking onto the exhaust.
Check you brake rotors to see if they are very hot, could be a stuck caliper.
JohnM10 is offline   Reply With Quote
Old 01-10-2012, 11:19 AM   #5
paperdukie
Member#: 214796
2004 OBS
Have you gotten your lower control arm recall done recently? Ever since I got my car back after the recall I smell burning plastic when the car warms up but its because the dealer over sprayed the coating onto the exhaust.
paperdukie is offline   Reply With Quote
Old 01-10-2012, 11:27 AM   #6
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
More info needed for sure.
Could be a cracked CV boot flinging grease onto the downpipe. Could be anything.
wobbletop is offline   Reply With Quote
Old 01-10-2012, 02:14 PM   #7
WrxBrooks
Member#: 263302
2004 Wrx
I dunno it's just a really potent burning rubber smell I have gone in for the lower control arm yet so it's not that I just did an oil change but I do believe I may be burning oil (what should I do to fix that) I'm just confused as what to do I use my car daily for work seeing as I drive all day
Old 01-10-2012, 07:49 PM   #8
flycaster
Member#: 60142
2011 WRX
Grey
...I just did an oil change...
Have you stopped to consider that whoever did the oil change might've accidently spilled some oil? It happens all the time, and it can take a few days to completely cook-off.
How much oil is your car burning, and what oil is it?
flycaster is offline   Reply With Quote
Old 01-10-2012, 08:09 PM   #9
WrxBrooks
Member#: 263302
2004 Wrx
I did the oil change no spill oil and I'm running royal purple as far as burning goes im not exactly sure how much is burning I just know that I'm seeing an oil light sooner rather then later and I have black soot or however you spell/say around my exhaust
Old 01-11-2012, 01:13 AM   #10
flycaster
Member#: 60142
2011 WRX
Grey
You're seeing an "oil light" regularly on the dash? Are you kidding? That's impending engine DEATH, amigo.
Old 01-11-2012, 07:04 AM   #11
WrxBrooks
Member#: 263302
2004 Wrx
Yea it's killing me last night when I pulled in my driveway I noticed oil spots from where I pull in so I know I have a leak but could that be what the smell is coming from like I said it's not a burning oil smell it's a burning rubber smell
Old 01-11-2012, 10:07 AM   #12
WrxBrooks
Member#: 263302
2004 Wrx
Old 01-11-2012, 04:46 PM   #13
WrxBrooks
Member#: 263302
2004 Wrx
Anymore insight on my situation?
Old 01-11-2012, 04:59 PM   #14
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
How often do you see the oil light on in your car?
z is offline   Reply With Quote
Old 01-11-2012, 06:28 PM   #15
flycaster
Member#: 60142
2011 WRX
Grey
Seeing an oil light tells you your oil pressure is catastrophically low, unless you've won the lottery by having a bad sensor. My advice? Make sure it is topped off with oil, make sure the filter is tight, and take it to a mechanic, immediately.
Old 01-11-2012, 06:51 PM   #16
WrxBrooks
Member#: 263302
2004 Wrx
I did the change then didn't see it for maybe 2,000 miles unless I just didn't notice it cause when it flashes it sits behind my boost gauge so it's tough to see unless you lean over I just happened to notice it
Old 01-11-2012, 08:01 PM   #17
WrxBrooks
Member#: 263302
2004 Wrx
I'm thinking my filter got messed up along the line somewhere cause im seeing some oil form at the tip or it
Old 01-11-2012, 08:20 PM   #18
flycaster
Member#: 60142
2011 WRX
Grey
Could be, but the oil pressure light is THE problem right now. You never, ever want to see that come on, much less often.
Pop the filter off, put a new OEM filter back on, clean every thing off really well (brakekleen works well), and top the oil off. Start it, let it idle, and if you see the oil light stay on, or come back on after it initially goes off, turn it off, and tow it to a mechanic.
Old 01-12-2012, 03:48 AM   #19
AeroWRX
Member#: 199026
2004 WRX Wagon
I've been gettin a burning smell on my 04 wagon as well. It has just hit 90k miles. I changed the engine oil last week ,but i still get the smell after i drive. No strange lights come up or anything.
AeroWRX is offline   Reply With Quote
Old 01-12-2012, 07:41 AM   #20
vtbandit
Member#: 52717
11 328i m-sport
I just looked at the LU(H4DOTC) Lubrication section of the service manual and on page 22 it states that the oil light comes on at 2.1 psi. At 600 rpm the oil pressure should be ~14 psi and 5,000 rpm the oil pressure should be 43 psi (176 deg F oil temp). I agree with others in that if the oil light comes on, it is not good news.
*** All numbers provided from service manual. ***
vtbandit is offline   Reply With Quote
Old 01-12-2012, 08:18 AM   #21
WrxBrooks
Member#: 263302
2004 Wrx
Yea I dunno my car this morning didn't make a spuddering noise but it had the feeling as if it were so im I'm thinking I got water in the engine and I have a cracked head I dunno what to do I'm just about ready to call it quits and sell it as is a walk away with nothing from it at this point
Old 01-12-2012, 08:30 AM   #22
wrc_tunedwrx
Member#: 279502
Your oil on your oil filter could pos be the oil cooler seal. (easy fix) other theb that what id say to do is detail/clean the whole engine with degreaser or brake cleaner (your choice) top and bottom of the engine. Put it on jacks if you dont have a lift. Afterwards go about your normal day and check it out in about 3 days to see where its coming from. Oh and if you have a cold air intake cover it with a plastic bag so water doesn't get on it. And dont put too much water pressure on any of the wires especially the MAF.
Hope this helps
wrc_tunedwrx is offline   Reply With Quote
Old 01-12-2012, 09:24 AM   #23
WrxBrooks
Member#: 263302
2004 Wrx
Yea ill give it a go
Old 01-12-2012, 04:45 PM   #24
z
Member#: 41762
04 STi
If the oil level is fine but the oil light is coming on, i'm wondering if could possibly be a cracked oil-pickup tube. (or possibly oil pump?)
Old 01-12-2012, 07:49 PM   #25
WrxBrooks
Member#: 263302
2004 Wrx
I got it fixed the filter was on too tight and it cracked the seal so when I ran the car oil would come out and burn down the exhaust and if I was driving a little faster it splashed up against the engine and made that smell
fuel smell and burning smell e_presley20 General Community 15 01-10-2011 03:11 PM
oil smell, burning smell, weird Tomasu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-28-2005 07:21 AM
Burning smell Freeskier Newbies & FAQs 7 02-10-2001 12:51 AM
Burning smell jeffg Newbies & FAQs 7 12-15-2000 08:33 AM
Burning smell! WiCkeD SoN Bay Area Impreza Club Forum -- BAIC 3 11-03-2000 10:02 AM
