Old 01-10-2012, 10:12 AM   #1
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Default Shredded timing belt, need HELP!
So a few days ago while heading home I noticed the car's temp was a little high (slightly overheating) so for precaution I slowly started to put the car off to the side. Then I noticed the smell of something burning, so 'I' decided to turn the car off and push it the rest of the way into a parking lot. A few minutes after letting the car sit to cool down, I attempted to turn the car on but with no success, it cranks but nothing else. The next day having the car parked in front of my house, I decided to look around, eventually I opened the timing belt cover and noticed the belt was shredded. The belt still does have tension. This is where I'm stuck, what next?
Car info:
WRX sti version 8 swap, catback, and intake (34k miles on engine)
nice way to start off the new year
thanks for the help though
dolosolow is offline   Reply With Quote
Old 01-10-2012, 10:35 AM   #2
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
I wouldn't try to start it again until you've removed the timing belt and inspected the idlers, etc. You may have got lucky and not damaged any valves, but that belt looks nasty.
wobbletop is offline   Reply With Quote
Old 01-10-2012, 10:47 AM   #3
leecea
Member#: 37359
2003 WRX
I would assume that something seized, possibly the water pump. I'd take off the belt and check the pump plus other pulleys.
If the pump has seized, I'd "search" to find whether that could cause other issues - I have no idea!
Then replace whatever is needed, put on a new belt, and either run a compression test or just cross my fingers and try to start it.
leecea is offline   Reply With Quote
Old 01-10-2012, 12:19 PM   #4
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
I'm not going to make another attempt at starting the car. I've heard if you do this a few times you will have a greater chance to damage the valves. I'm planning on changing the timing belt and then proceed with a compression test. How does this sound? or should I try something else?
* i'll keep my fingers crossed throughout the testing.
Old 01-10-2012, 07:20 PM   #5
some dude
Member#: 100300
06 WRX
CGM
Would a seized up water pump effect the timing belt in any way tho? It would have to effect the crank pulley in order bung up a timing belt?
I have 113k on my WRX and i have yet to change my belt. I have called a few shops around town and one said $775ish for new everything, gaskets, tensioners, and a new water pump. The dealer said $700ish for all that minus the new water pump.
I asked the woman on the phone why no water pump and she said that they don't usually recommend or see the need to replace the water pump until the 2nd timing belt replacement. I have been diligent about replacing coolant every 30k so maybe the OEM pump would be in good enough condition. Has anyone else who's done the timing belt gotten a new water pump?
sorry for the OT
some dude is offline   Reply With Quote
Old 01-10-2012, 08:17 PM   #6
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Put a breaker bar on the crank and turn the engine by hand to find what has seized up. You are going to need to do this to line your cams up anyway. Then replace the belt and idlers, and water pump if it is the problem.
WRXSD is offline   Reply With Quote
Old 01-11-2012, 04:58 AM   #7
reddawnman
Member#: 293986
2009 WRX Hatch
Change ALL the things... and make sure that you don't have a bent timing cover or other chronic problem that is putting stress on the belt. If you are changing idler pulleys, make sure you get the double bearing caged ones - the "green" ones that come with the cheaper gates kit are OK, but not quire as high quality as OEM.
If something seized, I'd disassemble that part and check the general area to see if the problem was external or internal.
If you still have tension on the belt and no evidence of burned or scraped teeth material on pulleys (evidence of sliding belt) compression test anc count yourself lucky...
reddawnman is offline   Reply With Quote
Old 01-11-2012, 10:15 AM   #8
leecea
Member#: 37359
2003 WRX
It is just a guess as to what might have happened, based on the temp going up and the rubber burning on the back of the belt. I have no idea how likely it is for a pump to seize, but any seized pulley will effect the belt.
BTW, I did not change water pumps on my minivan when I did the belt, and I've made it to 165K so far. Most likely I will not change it in my WRX when I do the belt in the spring. I'm willing to take the chance
Old 01-11-2012, 12:38 PM   #9
Scav1180
Member#: 56832
2004 STI
Java black
I had this happen twice.
First time, belt was ripped up but didnt snap. It was rubbing against the edge of a broken idler puller. All the bearings inside were gone. Looked exactly like the way your belt looks.
2nd time
my belt shredded on the freeway, due to a faulty idler pulley again, bunch of ball bearings all over the place. 2 exhaust valves bent but im back on the road..
Hopefully nothing else is ruined.
replace whatever you can replace in that area.
Scav1180 is offline   Reply With Quote
Old 01-11-2012, 01:04 PM   #10
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
This is great, just my luck. So wait your entire block was ruined or just the heads? and around how much did you spend to get back up and running?
Old 01-11-2012, 02:23 PM   #11
Scav1180
Member#: 56832
2004 STI
Java black
Engine was perfectly fine. Just the 2 exhaust valves were bent.
Cost me about 3000 to get back running.. it was a sad christmas.. happen few yrs back.
hopefully its a faulty idler for you. Piece of junk part.. lol
let us know what it is when you find out..
Old 01-11-2012, 03:13 PM   #12
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
I had an idler seize on me once. Best of luck to you.
Kris.is.awesome is offline   Reply With Quote
Old 01-12-2012, 01:12 AM   #13
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
3000? did you replace the engine? If my valves are bent can't I just rebuild the heads (get them machined)?
Old 01-12-2012, 01:15 AM   #14
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
As for kris, thanks. I seriously had no clue that this type of thing can happen to an engine with so little miles on it. All in all, I'm slowly turning away from subbies, I love them but they are too much of a headache.
Old 01-12-2012, 12:45 PM   #15
some dude
Member#: 100300
06 WRX
CGM
Had you messed with the timing belt or anything in the area recently? When was the last time it was accessed?
Old 01-13-2012, 12:15 AM   #16
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Nope never messed with the belt or anything around that area, it just turned three months that I got this engine swap. As when was it last accessed? I really don't know the engine is JDM.
Old 01-14-2012, 12:27 PM   #17
uberspeed
Member#: 87871
You don't really know that it has 34k miles on it then. The first thing I would recommend doing when installing an engine with unknown miles (the importers are always estimating the mileage on a basic formula of age x average miles driven in the country) is change the belt, idlers, and water pump while its out of the car. I would say you got lucky though that it didn't throw the belt or jump teeth!
uberspeed is offline   Reply With Quote
Old 01-14-2012, 12:30 PM   #18
uberspeed
Member#: 87871
If any idler is going to fail, it's that one! Most mechanics or owners will decide not replace idlers when doing a belt and I think it is a problem waiting to happen. If you were on a budget and wanted to go cheap, at least replace the geared idler and the tiny one.
Old 01-15-2012, 02:43 AM   #19
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Well I'm not completely sure it jumped teeth yet, tomorrow we are planning on taking a quick look into it, before sending it off to get the idlers, belt, pump changed. All in all, if the belt was to have jumped teeth does this mean my engine is a complete goner? or can I send the heads to get machined?
thanks
Old 01-15-2012, 03:17 PM   #20
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
From the worn melted look of the outside of the belt my guess is one of the smooth idlers or water pump is seized. The belt also looks like it separated between the inner and outer layers and shifted over to one side.
If you skipped some teeth you may have valve damage and just need headwork.
GDR is offline   Reply With Quote
Old 01-15-2012, 03:58 PM   #21
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
Just finished changing the timing belt, all went good, the car started right up. Thankfully nothing got damaged. I found out that just about all the pulleys, and water pump seized up. One pulley was so bad that it came apart once we removed the old belt and the ball bearings went everywhere. Water pump got burned marks cause of the heat.
Again, thankfully I'm back up and running, and in good time cause I start spring semester on wed.
Old 01-15-2012, 07:47 PM   #22
uberspeed
Member#: 87871
Go buy some lottery tickets!
Old 01-15-2012, 08:24 PM   #23
dolosolow
Member#: 279605
04' WRX swap STi
v8 TwinScroll 6MT
I know right, lol. We just did an attempt at changing the belt just to see if it will turn on, honestly we had no idea it was going to turn back on normally. Lucky me, tomorrow buying a few tickets.
07 WRX shredding timing belts bmxpunk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 12-31-2010 03:37 PM
Timing Belt Need Help... DjTalan Texas Impreza Club Forum -- TXIC 0 12-22-2010 01:38 PM
Readjustment issues for the timing belt, need help DoucheAlmighty Newbies & FAQs 3 11-15-2008 02:37 AM
Timing Belt Question HELP. neoncrazy101 Legacy Forum 4 06-10-2006 09:11 AM
timing belt removal help elseware Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-20-2003 10:51 PM
