Old 03-12-2013, 02:55 AM   #2601
theoutbackdream
Member#: 301179
2013 WRX Limited
Originally Posted by SeeingDouble12 View Post
can't somebody please tell me how to get lights setup on those? I cant find any info anywhere!
The reflectors come out with tabs.. super easy... Then just tap into ur taillights by removing them...
Originally Posted by CASHxMONEYxMIKE View Post
How hard was install? About to order my set
Cant say personally, but install seems very easy.. Just remove taillights, tap wire to taillights, route to the reflectors and swap.
theoutbackdream is offline   Reply With Quote
Old 03-12-2013, 07:05 AM   #2602
dhahn1012
Member#: 255578
2005 outback xt
white
Originally Posted by Gamble_WRX View Post
some of the posts on here say painting isnt a "unique" interior mod. this is my buddys 09 impreza premium we did a while back. sorry i dont have a better pic. but everyone compliments him on it. i think it turned out great.
That's pretty cool
dhahn1012 is offline   Reply With Quote
Old 03-12-2013, 11:16 AM   #2603
dothatshht
Member#: 335243
13 WRX
Originally Posted by iammedan View Post
Not custom but I don't see many hatchies rockin the led reflectors
this is one of the things i actually started working on. I have a few little projects in the works
also molding a single pod onto my steering column cover for the boost gauge im installing. I hate where it mounts through OEM and Im not a fan of the cluster bezels. This will be clean and look oem when Im done. (i had done it on my honda) the crack happen after removing it to sell it originally
dothatshht is offline   Reply With Quote
Old 03-12-2013, 12:29 PM   #2604
iammedan
Member#: 317742
2012 Wrx hatch
Plasma Blue Pearl
Sorry I don't check this forum often. "Carlab-design-tuning" on ebay. Wiring was easy. I'm terrible w anything electronic and got it. Comes w red blue black. Red to cars red. Blue to green. Black to black.
iammedan is offline   Reply With Quote
Old 03-19-2013, 04:26 PM   #2605
cr4zy3lgato
Member#: 265179
Not a subaru, but i made a custom gauge pod in one of my vents...
I'll post pics when it's installed
cr4zy3lgato is offline   Reply With Quote
Old 03-22-2013, 01:51 PM   #2606
SabarKcirtap
Member#: 281350
2004 STi
I don't have pictures of everything. Some things without pictures include: mesh painted black on hood, cleared/blacked out headlights, painted wheels black, carbon fiber wrap on roof rack
The hood had this plexiglass scoop delete when I bought my car...
Wrapped my phone battery cover with a carbon fiber vinyl, then laser etched it, as well as my key.
Went back and added the sillouette
Traded STI interior for WRX interior. There was too much blue.
Crown Royal Black shift boot, painted bezel ring satin black, and outlined STI with an ultra fine tip red Sharpie
Painted the rest of the interior dash pieces
Swapped my '04 tails for '06 tails, used a dremel to take them apart, and painted the housings black.
SabarKcirtap is offline   Reply With Quote
Old 03-22-2013, 03:27 PM   #2607
gregroot198521
Member#: 280844
2006 STi
Someone's been a busy bee.
gregroot198521 is offline   Reply With Quote
Old 03-22-2013, 04:05 PM   #2608
tuzzio
Member#: 292532
05 STI
That black crown royal bag is so much better then purple.
tuzzio is offline   Reply With Quote
Old 03-22-2013, 04:06 PM   #2609
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
I got the wiring schematics from my RFID Keyless entry / Push button start dealer so I was able to "test" it out by making a custom button for the system:
Started off with the factory USDM intercooler sprayer button:
Had to solder the 2 LED ground inputs together since the upper LED was normally only activated when the button was pressed. By changing that, I can now force the inputs and tell it when to light:
Also had to solder the back of the switch so that I could use the same ground input for both the LED and the input to the ground activation input. This pic was taken directly after soldering so nothing had been cleaned up yet:
Installed in the dash:
It isn't 100% complete yet. I still need to change the upper LED setup to allow for 2 separate LED's (the factory AK setup uses a green and a red LED to differentiate the different options). I am also having a sticker made to change the lettering to "Engine Start". I'll post up pics once its all finished.
klarowe is offline   Reply With Quote
Old 03-22-2013, 06:08 PM   #2610
P-Train
Member#: 279233
2008 WRX
You could leave it saying IC spray and have it be a theft deterrent
P-Train is offline   Reply With Quote
Old 03-22-2013, 06:25 PM   #2611
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
I installed my garage door opener under my shifter trim and wired up my own button so I can activate it by pressing on a specific location under my shift boot. Also tapped into the 12v in the center console to power it so it will never have a dead battery.
No pictures because it's an invisible install and I'm not taking it apart again
Millhouse_5 is offline   Reply With Quote
Old 03-22-2013, 06:52 PM   #2612
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
There's plenty of theft deterrent built into the RFID system. If the thief went as far as they would need to bypass the RFID, a hidden button wouldn't stop them.
Old 03-22-2013, 07:13 PM   #2613
Nutrients
Member#: 346825
2009 WRX
Found my old horn that I replaced with my supertones. Had to pull the bumper to put a new retaining bracket in place and my Hellas stopped working, so I had to fix the stock horn wire. Then I found my backup horn and realized 4 horns are always better than 3!
Nutrients is offline   Reply With Quote
Old 03-22-2013, 09:13 PM   #2614
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Hey, did you ever take pictures of where you cut open your tail lights?
spyrule is offline   Reply With Quote
Old 03-22-2013, 09:44 PM   #2615
cuztomimportz
Member#: 97904
World Rally Blue
Seconded ^^^
cuztomimportz is offline   Reply With Quote
Old 03-23-2013, 12:05 PM   #2616
xsv141
Member#: 231904
2007 WRX
UGM
not really unique but very usefull....so i had some water get into my trunk and ruin the spare tire cover so i decided to make a entire trunk cover out of 1/4" plywood. All i did was traced the carpet and cut it out with a jigsaw. then cut it in half so i could get the spare tire if needed.
Before
After/ the seam in the center is due to it not fitting so im going to use a mounting bracket to mount my sub to hold the top two pieces together
im also going to put 1/8" foam padding on the bottom of the wood due to annoying rattles when hitting bumps
xsv141 is offline   Reply With Quote
Old 03-23-2013, 02:11 PM   #2617
Candor
Member#: 219200
Before
Sounds good but did you fix the leak?
Candor is offline   Reply With Quote
Old 03-23-2013, 05:07 PM   #2618
kickniteasy
Member#: 201661
2013 STI
2002 Forester
this......props on the fix but hopefully you fixed the real reason for the "mod"
kickniteasy is offline   Reply With Quote
Old 03-23-2013, 05:28 PM   #2619
Rexypoo
Member#: 286745
2004 WRX STI
JBP
Before
Doing this when I get home in a month!!
Rexypoo is offline   Reply With Quote
Old 03-23-2013, 07:44 PM   #2620
xsv141
Member#: 231904
2007 WRX
UGM
yep replaced the old boring 06-07 tail lights with 04-05 tails. the leak was coming from the foam on the tails wasnt sealing on the body of the car so the new lights are all sealed up. Also need to check if its not coming from the bolt on my spoiler
Old 03-23-2013, 09:10 PM   #2621
fourseasonsandles
Member#: 94816
06 STI EFI Tuned
EFI Block, GTX30, 278s
This isnt 100% yet, but getting there.
Nothing exciting here. V1 on the mirror. (also not my pic. I didn't get one yet.)
This is a temporary setup. I am going to fiberglass around it, to blend it in a bit
Night shot
Kill switches for the gauges and V1 mounted
Edit: Some more work
Most of the fiberglass, filler and sanding is done. Have to correct my fitment a hair and should be ready for paint.
fourseasonsandles is offline   Reply With Quote
Old 03-23-2013, 09:43 PM   #2622
bradze
Member#: 103208
2011 Outback
Azurite Blue
failed miserably at making a custom grill so I ended up buying one. the grill isn't custom but the lights mounted to the bumper beam kinda is even though ive seen plenty of others do it
bradze is offline   Reply With Quote
Old 03-24-2013, 01:04 AM   #2623
Bradrcr
Member#: 276382
2005 SaaBeeru
Holy crap, looks like your car is gonna eat those weeds then the neighborhood children. Need to see it in person, but looks clean so doesn't matter if I like it or not...
Bradrcr is offline   Reply With Quote
Old 03-24-2013, 01:18 AM   #2624
Tomnompom
scammer
Member#: 343232
2012 WRX 5DR
When I painted my headlights I decided to paint the cut off plate a metallic purple to give the lens a hint of color.
Not the best picture but you get the idea.
Tomnompom is offline   Reply With Quote
Old 03-24-2013, 01:31 AM   #2625
The Tall Man
Member#: 316804
12 WRX/89 Conquest
TSI / 15 Viper TA 2.0
Just a cheap ass $35 Chinese dash cam install.
1. Auto start when car is started.
2. Auto stop when car is shut off.
3. Set to 720p / 30fps
4. Set to record 10:02 min files on a (extra) 32g class 10 micro sd card. Looping is turned off.
The source file is actually smoother and cleaner than this youtube upload of my first video. Also, at 2:45 you'll hear the audio pick up several bikes way off to the left. (make sure to switch to 720p on youtube)
The Tall Man is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
