Old 03-25-2013, 07:11 PM   #2651
cr4zy3lgato
Member#: 265179
well you don't have to use vacuum bagging, when i want to do something quick with minimum excess resin i wet lay my CF and i put the peel ply on top, then i use the breather cloth to absorb the extra resin, the peel ply will prevent you from damaging the weave pattern. All you need is epoxy that will let you enough time to work on your piece... at half the curing time you remove the peel ply.
cr4zy3lgato is offline   Reply With Quote
Old 03-25-2013, 07:19 PM   #2652
Wussman24
Member#: 157283
2003 2.5RS
Rattl'd white
Oh! Thanks, I might have to try that.
Wussman24 is offline   Reply With Quote
Old 03-25-2013, 08:58 PM   #2653
xirallicgdb
Member#: 247850
2007 SWP STi
CGM '07 Forester
What do you guys use to trim your carbon pieces once cured? Also what is your edge smoothing process? Thanks!
xirallicgdb is offline   Reply With Quote
Old 03-25-2013, 09:04 PM   #2654
Wussman24
Member#: 157283
2003 2.5RS
Rattl'd white
Dremel with a cutoff wheel.
Old 03-25-2013, 09:11 PM   #2655
cr4zy3lgato
Member#: 265179
For cutting, i find that a cutoff wheel works best, be very careful though, carbon fiber dust is VERY dangerous and will make any exposed skin itchy... I recommend a 3-M mask, cover all, gloves and safety glasses.
For edge smoothing, it depends of the part, the best is to make your piece so you don't have any (folded ends)... But i have used split brake line hose and plastidip too.
Old 03-25-2013, 09:34 PM   #2656
xirallicgdb
Member#: 247850
2007 SWP STi
CGM '07 Forester
Just tried my hand for the first time with a buddy last weekend. We wound up trimming with tin snips when the piece was about 2/3 cured. I'm trying to figure out how to make folded edges if im making a new piece (not wrapping something)?
Only thing i can think of is wrap another top layer once the piece is out of the mold/ template?
Old 03-25-2013, 09:59 PM   #2657
cr4zy3lgato
Member#: 265179
As i said it depends of what you're trying to do, you can do some kind of rib with balsa, core, even vinyl tubing... If you're doing something flat you can use cardboard, foam, etc. As a core and wrap around the edge, you will have something stiffer with fewer layers of carbon.
Old 03-25-2013, 10:45 PM   #2658
xirallicgdb
Member#: 247850
2007 SWP STi
CGM '07 Forester
Thank you for the tips.
Old 04-04-2013, 06:42 PM   #2659
Rexypoo
Member#: 286745
2004 WRX STI
JBP
This is awesome. Can I get a build list and steps?
Originally Posted by matts View Post
I could not find a catch can that looked decent on the market, so I made one. I have an AOS prior to the can so I don't have any fluid in it yet. I might not be as pleasing to look at with a bunch of oil in it. We'll see.
Rexypoo is offline   Reply With Quote
Old 04-04-2013, 10:15 PM   #2660
ag04
Member#: 182051
2006 WRX Sedan
SGM
Originally Posted by Wussman24 View Post
No, it's got some clearcoat with UV protection. It's not vacuum infused, just laminated. I was thinking of ways to vacuum infuse it but couldn't think of a way since this was my first attempt with carbon fiber. It's more for looks than anything.
Do you have a write up or setups? A guide that you sort of followed? I attempted this a few years ago, and while I'm decent with composites, carbon was pretty new to me. Did you use spray adhesive first?
Thanks in advance!
ag04 is offline   Reply With Quote
Old 04-05-2013, 02:51 PM   #2661
cr4zy3lgato
Member#: 265179
^just watch the videos on youtube, it's fairly simple...
Also depends if you want to make a part out of CF or if you just want the look
Old 04-06-2013, 03:27 AM   #2662
LegacyW90
Member#: 346104
1990 Legacy wagon
Faded red (stock) haha
Originally Posted by GhostSenshi View Post
in a way it was after applying the first coat, even after sanding, the paint still ran a bit rather than stick so I had to improvise. After that, each coat I applied stuck and the clear coat cleaned it up.
You can still noticeably tell at least in pictures but I thought it looked cool it gave it character cause it didn't really look like drips. To me it just looks cool I guess. I love it.
LegacyW90 is offline   Reply With Quote
Old 04-06-2013, 08:18 AM   #2663
mrchyes
Member#: 294069
98 Forester
Green
might not be the most "unique" but definitely don't hear too much about it.
i'll be mocking up my td04 turbo setup on my 2.5 RS today, pics to follow.
mrchyes is offline   Reply With Quote
Old 04-06-2013, 10:55 AM   #2664
mrchyes
Member#: 294069
98 Forester
Green
blurry but looks cool
the biggest hurdle of the install, how to get that up pipe to connect.
bottom view
Old 04-06-2013, 01:36 PM   #2665
207STi
Member#: 197062
1998 Swapped Impreza
black
bottom view
You're going to have to either notch the cross member or get a legacy turbo or a turbo GC cross member (assuming this is going into a GC or GF chassis). I notched the cross member during my swap and welded in some supports, probably would have been easier to just buy a factory one.
207STi is offline   Reply With Quote
Old 04-06-2013, 01:40 PM   #2666
mrchyes
Member#: 294069
98 Forester
Green
this is my 04 RS so its a GD. im probably either getting a GD turbo crossmember and front sway, or having custom up and down pipes made
Old 04-06-2013, 01:52 PM   #2667
LegacyW90
Member#: 346104
1990 Legacy wagon
Originally Posted by sc00by4life View Post
Those are grids.
XXR's look nothing like those. Neither do the varr's, or the volks.
Just saying grids have thinner spokes. Xxr522's look exactly like that. Not to mention changing the offset would change the look of the spokes. And the wider rim.
Old 04-06-2013, 04:12 PM   #2668
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
How would two wheel with a different number of spokes look identical?
Grids have 6 spokes, 522s have 7 spokes...
JourdanWithaU is offline   Reply With Quote
Old 04-07-2013, 03:35 PM   #2669
Hiburn
Member#: 217585
2015 STi Limited
Dark grey metallic
Combo of custom stuff, my shift knob from WC Lathe Werks, docking station integration for my Zune into the dash head unit and the holster for the pistol by the gearshift.
Hiburn is offline   Reply With Quote
Old 04-07-2013, 04:33 PM   #2670
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
That cell phone docking location would drive me nuts being by my knee...
spyrule is offline   Reply With Quote
Old 04-07-2013, 05:27 PM   #2671
Andrew025
Member#: 303408
04 STi
I used to have a similar setup until my zune finally bit the dust. Could hear it spinning for a while and then it just pooped the bed
Andrew025 is online now   Reply With Quote
Old 04-07-2013, 05:43 PM   #2672
garudatwo
Member#: 322385
My iPod from 2004 has been through 3 HDD's already because I'm too cheap to replace the damn thing
Alcantara hand brake lever, last time I've seen one offered was for an M3/5.
garudatwo is offline   Reply With Quote
Old 04-07-2013, 06:17 PM   #2673
Ed05WRX
Member#: 319401
05 WRX
WR BLue
Where do u get that material!?
Ed05WRX is offline   Reply With Quote
Old 04-07-2013, 09:15 PM   #2674
Hiburn
Member#: 217585
2015 STi Limited
Dark grey metallic
It's actually not bad at all, gives a good line of sight so I can glance down at it without any glare. Doesn't interfere with my driving position at all. And for the other zune guy, I'm on my second HD as well but I really hate apple and theres not much aftermarket support for anything else.
Old 04-07-2013, 09:25 PM   #2675
garudatwo
Member#: 322385
Carbon6 from NSX forum. 20% cheaper than JPM.
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
