Old 04-09-2013, 10:37 PM   #2701
meanjoaquin
Member#: 309723
2003 WRX
When I worked at a hot rod shop, we used a small metal switch that was really heavy duty (we used it as a battery cut off), but good looking and easily concealable. It looked like it would have been a toggle, but there was no "positions". The toggle part stayed straight the whole time, and you just pushed the switch to one side and that would be the on/off motion. I think that would work well, I'll see if I can find a picture of one.
meanjoaquin is offline   Reply With Quote
Old 04-09-2013, 10:44 PM   #2702
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Originally Posted by Bansheeboy11 View Post
Yeh ive been down that road here, and other forums. Ive gotten in trouble for selling too many sets of wheels once lol... I want to find a switch thats enclosed, not like a flip race car toggle looking thing, just something that can hang out under the dash without being bumped.
I would think, why not just wire the switch into the fuse cup that's near your hood latch ?
Secondly, For you to flash, do you have to flip both all the time?
If so, why not just use a DPST style switch, which throws both switches, seperately, with a single switch...
spyrule is offline   Reply With Quote
Old 04-09-2013, 10:49 PM   #2703
meanjoaquin
Member#: 309723
2003 WRX
When Clark Turner tuned my car, he told me I could leave jumper plug in the car, and that it's fine. I've been driving that way for almost a year now. The only switch you would really need is the the one that would connect the two that are under the dash.
Old 04-09-2013, 11:00 PM   #2704
Bansheeboy11
Member#: 182415
1999 RS
Thats one of the styles im testing BUT im not trying to make something permanent, i want it to be simple and functional by being able to be used in multiple cars.
Yes a few people i know leave the flash blocks in.
Bansheeboy11 is offline   Reply With Quote
Old 04-10-2013, 07:52 AM   #2705
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
Originally Posted by jojo69 View Post
hand brake semi-covered... I dunno if unique but different... Same idea as garudatwo, but different spin. No glue, a simple cut&tuck did the trick quite well & totally reversible if needed! Love the feel of it under my fingers.
May try a total wrap (upper part) later down the road but I kinda like the contrast and cleanliness...
I really like this. looks better than just plastic and probably doesn't scratch. On the plastic there's no glue and it's just tucked? Does it feel like it might pull away or slide? I just really like the look of this
breezeby is offline   Reply With Quote
Old 04-10-2013, 10:08 AM   #2706
jojo69
Member#: 309196
2012 Hatch
wrb
Correct about the no glue. Most of the interior parts in my car that are covered in alcantara have cement glue on them. In this case, I initially wanted to get a sense of how it would look and if i liked it (which i do), i would add some glue to avoid any possible movement.
I took the rubber part off (brute force + wiggling does the trick). There is a small amount of glue on the upper part of the shaft from oem. The rubber piece is pretty thick. I just used a razor blade to create a cut all along the oem groove; deep enough that i could fit tuck the edge of the alcantara but not deep enough to cut all the way through the rubber.
Made a template from the material and tucked the alcantara with a small tip flat tool. I didn't have that much extra material after doing my template so I had to stretch the material with my thumbs to have enough to tuck in between the plastic. The material is tight around the rubbber and doesn't seem to move.
Theoretically, you are right in that if I decided to yank in a lateral manner,the alcantara may untuck itself (haven't tried). For daily duty, you typically exert vertical force or rest ur hand while you cruise, so less likely to get the material to untuck.
For now, i will drive as is and leave it on... it's not like you handle your handle all the time that it's likely to get off...
but yeah, once you have a good idea of how much tucks and the proper dimensions without bunching of the material around the grooves, you can glue it on and not worry about it sliding around. Hope that helps. I used a scrap of alcantara I had laying around from bigger projects.
jojo69 is offline   Reply With Quote
Old 04-11-2013, 10:30 PM   #2707
08wrbrex
Member#: 293186
2006 WRX
I converted my Turbo XS RFL into a recirculating valve.
08wrbrex is offline   Reply With Quote
Old 04-12-2013, 04:55 AM   #2708
RallySoob
Member#: 74872
2006 STi
White/Black
RallySoob is offline   Reply With Quote
Old 04-12-2013, 01:16 PM   #2709
ea126405
Member#: 317032
RallySoob, talk about Unique (custom) modifications. Good work, that is really cool.
Now, clean and Armorall that door panel.
ea126405 is offline   Reply With Quote
Old 04-12-2013, 01:20 PM   #2710
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
Well, not really unique. They are selling these kits on eBay. Going to be the hot upgrade soon enough...
Danny5 is offline   Reply With Quote
Old 04-12-2013, 01:30 PM   #2711
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
Finally got a chance to bake and install these. What you guys think? I think its a little too much but whatever.
King of Poop is offline   Reply With Quote
Old 04-12-2013, 01:31 PM   #2712
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
lol @ Subaru ground effects.
Old 04-12-2013, 02:44 PM   #2713
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Cool idea on the headlights, any shots of the whole car?
Mike
GrimmSpeed is offline   Reply With Quote
Old 04-12-2013, 02:49 PM   #2714
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
sorry couldn't resist... lol
Old 04-12-2013, 02:56 PM   #2715
DARTH MAGNUS
Member#: 285248
2014 PBP GR WRX
2006 STi - SOLD :(
Originally Posted by RallySoob View Post
[/url]
I wish they had an STi version. Also, why did you instal it in the pocket and not in the door itself, out of sight?
DARTH MAGNUS is offline   Reply With Quote
Old 04-12-2013, 03:10 PM   #2716
jstevens
Member#: 275318
2004 Impreza WRX
Well, I was going to post a photo... how come the Android doesn't allow me to post photos?
jstevens is offline   Reply With Quote
Old 04-12-2013, 04:28 PM   #2717
easterbran
Member#: 307359
'05 STi Stage II
You have to upload to an image hosting site like photobucket (which has an app). Then copy and paste the IMG code.
easterbran is offline   Reply With Quote
Old 04-12-2013, 11:31 PM   #2718
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Trying something different. Matches my control arms and lat links
Old 04-12-2013, 11:31 PM   #2719
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Mike
I will have some soon.
Old 04-12-2013, 11:36 PM   #2720
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
Those headlights look a bit much, but **** it you already did all that work
m1r4g3 is offline   Reply With Quote
Old 04-13-2013, 08:04 PM   #2721
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
I like it. I would like to see what the rest of car or atleast the front end looks now.
Daddy_Digital is offline   Reply With Quote
Old 04-13-2013, 09:16 PM   #2722
flippymcbean
Member#: 198546
2003 Evolution VIII
Lightning Yellow
Is this unique?? Retro fitted D2S projectors....
Haha. Forgot the picture.
flippymcbean is offline   Reply With Quote
Old 04-13-2013, 10:50 PM   #2723
Andrew025
Member#: 303408
04 STi
In a world full of crappy pnp hids... Almost... Almost
Andrew025 is offline   Reply With Quote
Old 04-14-2013, 06:03 PM   #2724
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
I made this awhile back and figured I would post it up.
ImNOrobo is offline   Reply With Quote
Old 04-14-2013, 06:25 PM   #2725
spyrule
Member#: 222703
2006 Impreza 2.5i
Crystal Grey
Nicely done!
1/4" ABS sheet?
Any pics on how/what you mounted the diff side too ?
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
