Old 04-29-2013, 09:30 AM   #2801
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
It won't fade as long as you use real alcantara. IT was designed for automotive applications and it's very durable.
p951951951t is offline   Reply With Quote
Old 04-29-2013, 06:40 PM   #2802
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Originally Posted by dangerousatom View Post
It more keeps oil and water temps consistent between each other then actually cool the oil.
I've seen oil temps as much as 20F cooler during track days as a result of adding the factory oil cooler. That's a pretty decent drop, and it's a helluva lot easier to plumb than an external oil cooler (which I've done on my other two cars).
Hence the reason why JDM/Sepc-C and RA-R Subys are not running them.
The spec-c and ra both come WITH the external oil cooler though...
That's a key piece of information that dangerousatom neglected to mention.
If Subaru was truly worried about high oil temps they would be running a line directly through the radiator like an auto trans fluid line or an out front actual oil cooler ....an option on the JDM STi's
A line directly to the radiator wouldn't necessarily be any more effective than the cooler sandwiched between the filter and block. And based on what I've seen with a variety of vehicles, the cooler within the radiator setup is prone to leaking in the long term.
Patrick Olsen is online now   Reply With Quote
Old 04-29-2013, 08:48 PM   #2803
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Finished up my reverse scoop project, I kinda don't like it The lines don't flow that great with the hood, and more importantly the fit and finish of my ghetto fiberglass first timer skills look pretty bad up close. Will probably pick up the new Kaminari hood in a month or so.
atf78 is offline   Reply With Quote
Old 04-29-2013, 09:28 PM   #2804
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Looks good. Just needs some bulkyness removed is all. I like it tho.
I prefer my scoop tho. 05 wrx fmic. Sti scoop.
I run a plate in the winter tho
cosseywrx is offline   Reply With Quote
Old 04-29-2013, 10:03 PM   #2805
cr4zy3lgato
Member#: 265179
I kinda like it too... you should fab a V2.0 instead, with sligthly lower profile... don't give up yet
cr4zy3lgato is offline   Reply With Quote
Old 04-29-2013, 10:33 PM   #2806
Candor
Member#: 219200
Why in gods name do you run a FMIC with a stock hood scoop? Does anyone here even know how aerodynamics work at the most basic level?
Candor is offline   Reply With Quote
Old 04-29-2013, 10:44 PM   #2807
cr4zy3lgato
Member#: 265179
^i don't agree, why do you say that?
Old 04-29-2013, 10:54 PM   #2808
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
lol. the aero is so minute that it doesn't really matter
m1r4g3 is offline   Reply With Quote
Old 04-29-2013, 11:44 PM   #2809
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
The "aero" he is referring to is the pressure differences in the engine bay. By having a hood scoop air is forced into the engine bay, thus creating a high pressure zone. This high pressure could potentially decrease the airflow through the FMIC and cause the air to deflect around the car instead.
JungleFevre is offline   Reply With Quote
Old 04-30-2013, 01:17 AM   #2810
cosseywrx
Member#: 276443
Because racecar
Old 04-30-2013, 09:49 AM   #2811
cr4zy3lgato
Member#: 265179
with the right mods to the rest of the bay, it could also be more efficient... I hate when people just bash on others without having a clue...
Fluid mechanics is a lot more complex than just saying "Does anyone here even know how aerodynamics work at the most basic level?"
I do not own a subaru and i'm not familiar with the engine bay... but i do race my car, i'm a student in mechanical engineering and i'm also part of Laval's Baja SAE team, so i do have a clue, but it's not that simple... and i'm sick and tired of seeing this kind of talk...
I enjoy coming here to see the creativity of people (even if it's paint or stickers)
Old 04-30-2013, 10:07 AM   #2812
Candor
Member#: 219200
What are the “right” mods to an engine bay would make that style setup MORE efficient? Aside from removing the splash tray there isn’t much more you can do besides shaving the entire engine bay. Heat transfer and aerodynamics are pretty simple in their most basic form, close the hood scoop and watch your temperatures drop.
Old 04-30-2013, 10:22 AM   #2813
cr4zy3lgato
Member#: 265179
first, excuse me if i sounded arrogant or rude, but i appreciate a debating over ideas... i just don't like when someone just throws something like this without justification
removing the tray is usually a bad idea for good flow, you are right when you say it's fairly simple, but there are so many things that can come into play...
Basically, it's just a matter of mass flow rate... You make air enter the bay, the same amount as to get out somehow. Basically with no hoodscoop, you can get turbulent/slow flow behind the FMIC, if you add a scoop, you run the risk of too much air entering and get a rise of pressure in the bay, which would slow down even further the air passing through the IC, but if you can create a vacuum effect (by simply removing the seal on the rain tray or spacing the hood) it should help the air move in the bay by creating a low pressure area... same could be done by leaving an open space at the end of the splash tray...
Old 04-30-2013, 10:22 AM   #2814
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I'm really diggin this! From this distance i think it looks great. I could see how it might seem a little bulky up close as you're used to seeing a nice blended scoop. I say give it another shot!
Mike
GrimmSpeed is offline   Reply With Quote
Old 04-30-2013, 10:32 AM   #2815
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
I'm with everyone else. I think it is a good first step. You are still learning how to work with the material. I give you respect for the effort and being one of the first to attempt this on a GR hood. It is not as easy as the older cars that's for sure.
I would like to see you attempt a version 2 and keep at this project. You have something here. Just try to let it flow more with the lines on the hood.
JSchell1309 is offline   Reply With Quote
Old 04-30-2013, 11:05 AM   #2816
TheB00T8930
Member#: 328014
2004 Impreza WRX
Not an extremely unique mod, but I think it freshins it up a bit without going over the edge.
http://s1364.photobucket.com/albums/...ps1b82bbaa.jpg
TheB00T8930 is offline   Reply With Quote
Old 04-30-2013, 11:20 AM   #2817
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Spacing the hood and/or removing the seal will only make the problem worse. The cowl is a high pressure area. An opening from the hood to the cowl will force more air under the hood.
see here: http://forums.nasioc.com/forums/show...7&postcount=53
T-37 is offline   Reply With Quote
Old 04-30-2013, 11:56 AM   #2818
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Thanks for the kind words guys.
I don't totally hate it, I'm just very anal about this stuff so all the imperfections just stick out to me. This was already a second attempt at this, and I don't think investing the money for another OEM scoop + materials and the large chunk of time to do it into a third go would be worth it when a hood like this already exists from Kaminari. I'll probably keep this reverse scoop until I can get that hood or until I get sick of this project.
Old 04-30-2013, 12:11 PM   #2819
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow, that hood looks great for a FMIC. IMO, it is the idealized version of your mod. I like that a lot!
xluben is offline   Reply With Quote
Old 04-30-2013, 12:21 PM   #2820
cr4zy3lgato
Member#: 265179
that's why i said it's not that simple... there's no universal answer, that's why tunnels are used... I know it worked for me, not saying it will for everyone. you need to be aware of all the places air enters and exits...
Old 04-30-2013, 12:22 PM   #2821
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
I know. Unfortunately I only found out it existed when I was getting ready to paint my scoop
They made these hoods for all previous GD body styles, it's about time they made one for the GRs.
Old 04-30-2013, 03:57 PM   #2822
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
Oh man, that kaminari hood is awful!
Your scoop is way better...
JavaBot is offline   Reply With Quote
Old 04-30-2013, 04:07 PM   #2823
cr4zy3lgato
Member#: 265179
I agree with JavaBot
Old 05-03-2013, 01:04 PM   #2824
ea126405
Member#: 317032
Default DIY: 2012 WRX: Use fog lights as DRL
Haven't seen this one listed in this tread yet, hope I did not miss it.
This was one of the first mods I planned after I purchased my WRX in 2012. I searched and couldn't find a DYI, so I planned to research later, got busy with other stuff, blah, blah, blah, time passed. Then I found myself 10 months later ready to move. One more search and viola!
I Found it here:
http://forums.nasioc.com/forums/show....php?t=2383843
This is a very simple mod and as long as you own some ramps, it is easy to perform from under the car. I also replaced the stock fogs with Luminics Krypton Series JDM Yellow bulbs. They look really good as DRLs and will rock yellow as fogs, when needed.
Thanks to OP, REBinc, for the write up!!
ea126405 is offline   Reply With Quote
Old 05-06-2013, 03:15 AM   #2825
x3avier
Member#: 316439
I have a couple of simple mods but they make a big difference to my WRX. I tinted my windows fairly dark and then realized it made backing into my unlit shed at night pretty hard so added a reversing camera setup to my JVC head unit. Wired up properly so it is automatically powered and displayed when I select reverse. The camera I bought has a good quality Sony sensor in it so viewing angles and low light performance are pretty good. No need for illumination IR leads. Tail light is more than enough at night.
My second mod isn't really a mod, just a different way to add wireless a wireless charging mount for my Nexus 4. Turns out with a small right angle usb cable, usb cigarette lighter adapter and a Nexus 4 charing orb, my Nexus 4 sits perfectly in the area in front of my gear lever. A little double sided tape to hold the orb in place and it works perfectly. I'm using "Automagic" app to make it connect to the JVC unit and play my tunes using google music. So simple but it works brilliantly.
The USB cable isn't connected in the photo.
x3avier is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
