Old 06-23-2012, 08:23 PM   #951
easterbran
Member#: 307359
'05 STi Stage II
I will always know it's there!
easterbran is offline   Reply With Quote
Old 06-23-2012, 09:05 PM   #952
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
hahaha you guys are such hawkeyes....
or are blob-eyes more sensitive to McD's refuse?
burkart is offline   Reply With Quote
Old 06-23-2012, 09:14 PM   #953
Andrew025
Member#: 303408
04 STi
Pre 05
Andrew025 is offline   Reply With Quote
Old 06-23-2012, 09:22 PM   #954
1RandomW
Member#: 269224
'11 WRX-4 Door, SWP
Does anybody know what kinda bottom grill this is ? I found this picture in a different thread.
Is this made by any company ? I looked online but I couldn't find anything any bottom grills like this for sale.
1RandomW is offline   Reply With Quote
Old 06-23-2012, 10:33 PM   #955
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Here is a Big one I just wrapped up today
Inter Cooler Water Misting Setup
I have had these parts waiting to get installed for months...finally got around to it. This is not a normal inter cooler spray set-up its actual a misting rig like you see at large amusement parks and on hot days at sporting events for the athletes. It creates a super fine mist almost like fog.
Parts:
- 1/4" black push lock hose ....20-25ft
- miscellaneous 1/4" push lock fittings
- 2 misting tips off ebay, included where the push lock T-fittings
- 120psi 120v espresso machine pump of ebay
- 300watt power inverter....I think it hat was off Amazon
- 12v adjustable psi activated switch, included was 20ft wire and the green LED
- Motor Boat 3gal Gas Tank from Walmart
- 1 40amp relay and other miscellaneous electrical bits
- miscellaneous hardware
Started by ripping the rear trunk panels out of the wagon to see what and were things could go and I figures the pump and power inverter would fit just right in the long storage flap area. After bending up two brackets and a quick run for some small/long bolt hardware they were mounted.
I drilled a hole for a push lock pass through fitting just above the passenger side bulk harness in the fire wall.
I ran the misting tips through the holes in the Process West TMIC splitter. The tips require near 100psi for them to work properly. That is the reason why I have used the espresso machine pump, it makes near 120psi in about 2-3 seconds of start up. With the tips in the two outer holes it gives 100% coverage of the core. The feed hoses run through the side gaskets. It gives it a nice clean look and keeps the hoses up and out of the way with out all kinds of zip ties.
Ran all the power wires and feed hose back to the trunk and connected all the appropriate bits. Dropped in the gas tank and bungee it in place till I get a chance to fab up a bracket to mount on the spare tire mounting point. I had wracked my brain trying to find/figure out what to use for a tank. Any thing custom was going to be far too much and there are only 1-2 company's that make spare tire well tanks and they are near $500. So as usual in this kind of predicament I to a trip to Walmart thinking to maybe find a oil pan and figure a way to seal up the pour spout. I usauly walk the home, sporting goods, and auto isles just looking around for an idea. Low and behold the boat gas tank! It was perfect, top feed outlet was 1/4npt it has an internal filter on the end of the inner hose and was low profile. This would also make a killer METH tank.
Lastly I pulled the gauge cluster trim and mounted the LED, tapped into the relay wires for power and was basically done......about 6 hours all in all. Having the LED dead center is nice for a few reasons. It helps when I was adjusting the psi switch's activation, I didnt have to watch the LED just the boost gauge.....its set for 0-1psi Another nice this about the LED is it will help me stay out of boost when Im driving and actually trying to save some gas.
dangerousatom is offline   Reply With Quote
Old 06-23-2012, 10:58 PM   #956
gregroot198521
Member#: 280844
2006 STi
^Very nice! May have to steal the idea sometime to combat the high ambient temps here.
gregroot198521 is offline   Reply With Quote
Old 06-24-2012, 04:43 PM   #957
P-Train
Member#: 279233
2008 WRX
I'm interested to know if your mister/fogger more efficient than a typical sprayer..
#DATA
P-Train is offline   Reply With Quote
Old 06-24-2012, 05:04 PM   #958
dangerousatom
Member#: 70710
IMO it should be, since the water partials are smaller so evaporation will be faster, so it will cool better. Also the mist is soo fine its is like 95% evaporated by the time it gets to the bottom of the core, so there is no water all over the place like a normal spray system.
Ill have numbers in a week or so, I just ordered 2 digital readouts and some thermocouples for intake and after inter cooler temps.
Old 06-25-2012, 05:50 PM   #959
civicdelslow
Member#: 309678
2012 WRX
Dirty Black
civicdelslow is offline   Reply With Quote
Old 06-25-2012, 06:18 PM   #960
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
Originally Posted by civicdelslow View Post
Could you link to the OBDII bluetooth device you bought? I cant find one that is cheap that I know will work with that program.
Thanks
MtnXfreeride is offline   Reply With Quote
Old 06-25-2012, 06:32 PM   #961
civicdelslow
Member#: 309678
2012 WRX
Dirty Black
the one I use, although there are cheaper ones available if you look around amazon. I just know for a fact this one works.
Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: AutomotiveAmazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
I said in my video that I pay 9 bucks... but, I lied. It was 18. there is a 9 dollar one and I decided to opt for the one I knew worked 100%
Old 06-25-2012, 07:18 PM   #962
BluewaterAWD
Member#: 262210
Your answer is further along in that thread ; To save you time it's a custom job, likely a Home Depot special. Current owner tracked down previous owner whom confirmed.
/Endstory - Sorry!
BluewaterAWD is offline   Reply With Quote
Old 06-25-2012, 08:13 PM   #963
gregroot198521
Member#: 280844
2006 STi
Nice septum piercing (could never get myself to get one), and American Headcharge FTMFW!!!!
Old 06-26-2012, 02:07 AM   #964
mattesonb
Member#: 139607
2011 WRX
DGM Wrapped Satin Black
Not sure exactly how unique this is but i got tired of my hatch area being too dark. i had previously added a strip of LED's to rear hatch roof area, but with the cargo cover in the car it still blocked the rear area.
i added 3 more LED's now, 1 in the hatch and 2 on the inner corners, the lighting is awesome.
mattesonb is offline   Reply With Quote
Old 06-26-2012, 09:39 AM   #965
civicdelslow
Member#: 309678
2012 WRX
Dirty Black
It doesn't hurt at all. Do it!!
American headcharge is where it's at man.
Old 06-26-2012, 09:40 AM   #966
civicdelslow
Member#: 309678
2012 WRX
Dirty Black
Originally Posted by mattesonb View Post
Not sure exactly how uneque this is but i got tired of my hatch area being too dark. i had previously added a strip of LED's to rear hatch roof area, but with the cargo cover in the car it still blocked the rear area.
That looks great man!
Old 06-26-2012, 01:38 PM   #967
gregroot198521
Member#: 280844
2006 STi
Nah, too late now, army frowns on piercings, though my tats haven't really caused much grief b
Old 06-26-2012, 05:21 PM   #968
mattesonb
Member#: 139607
2011 WRX
Thanks! im pretty happy with the results
Old 06-26-2012, 09:18 PM   #969
burkart
Member#: 305000
2005 Legacy GT 5MT
Originally Posted by monkeyracer View Post
Plastidipped my headlights and taillights:
Haven't seen anyone with this generation do anything like this with the lights yet, so it's unique.
i really like this- very clever. have a pic of it with the lights on?
Old 06-26-2012, 11:41 PM   #970
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
Yup:
Although it looks like it, I don't have fog overlays, I actually hate the yellow look of the overlays...
monkeyracer is offline   Reply With Quote
Old 06-27-2012, 12:16 AM   #971
kickniteasy
Member#: 201661
2013 STI
2002 Forester
@monkeyracer I bought mine from GO Arapahoe as well. Looking good!
kickniteasy is offline   Reply With Quote
Old 06-27-2012, 01:12 AM   #972
monkeyracer
Member#: 308583
2015 Forester XT
Actually, mine was from Go Subaru West in Golden, but great dealership, good buying experience!
Old 06-27-2012, 08:00 AM   #973
krzywhtboi82
Member#: 280582
2009 2.5i premium
ssm
Just noticed somethin on your car. Did they stop doin projector lens on the new n/a's
krzywhtboi82 is offline   Reply With Quote
Old 06-27-2012, 09:55 AM   #974
monkeyracer
Member#: 308583
2015 Forester XT
Yup, back to reflector lenses. Although I am pretty sure the Canadian versions have HID bulbs in the reflector housings from the factory, no projectors for this generation.
There's a guy on here that has done a retrofit already, and I plan to do one after some spare housings come down in price though.
Old 06-28-2012, 06:03 PM   #975
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Not too unique since quite a few people seem to be doing this mod, but here is my take on rear cargo lighting.
The bulbs I used are; 12 led 7440 bulbs.
Took them apart. The wires with the resistors are the power wires.
Then pulled down the rear trim piece and drilled pilot holes in two circles that were there from casting.
Took a 1/2" drillbit and made the hole bigger. Then used a dremel to get the final fit for the leds
Everything wired, soldered, and taped up.
Also hot glued the leds in place.
The final product:
It's nice and bright and looks almost factory. It was fairly easy to do, and only took about 45 minutes.
~Evil
EvileyeZ88 is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
