Old 07-11-2012, 04:27 AM   #1051
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
Originally Posted by Chasewrx View Post
so this ap holder isn't unique but i tucked the wire into the dash and it looks nice
quality is crap, sorry night pics
here's the unique part I think. wired up the test mode connectors and the blue connector that comes with the access port to two seperate switches. instead of digging under my dash every single time I need to reflash my car I simply flip these two switches and BAM I'm in test mode and able to reflash
Did it in the carl's junior parking lot to test out a new map, works great but the switchs' housing needs to be cleaned up
It's the two ones on their sides in the same slot, one for each connector to flash
While this is pretty cool, I'll say plugging in the "green test mode connectors" takes 3 seconds without looking.
Old 07-11-2012, 04:42 AM   #1052
Chasewrx
Member#: 290616
2013 STi Hatch
World Rally Blue
yea and yet the blue one you have to keep with you and is more of a pain to do, hey man if you don't mind doing it no worries. I just had to switch maps a lot trying to sort out a problem with my tune, makes it easy for me. It wasn't a problem once or twice when I first got the ap but if you do it alot this makes it easy
Chasewrx is offline   Reply With Quote
Old 07-11-2012, 10:12 AM   #1053
ravenlunatic
Member#: 180601
2003 PSM WRX
(>")>==HADOKEN==<(o)
custom stick made by a friend.
and our mock-up diffuser. currently made from steel scraps and wieghs a ton the plan is to fiddle with some designs and then make the final product with a single sheet of aluminum and a few bends and folds.
ravenlunatic is offline   Reply With Quote
Old 07-11-2012, 10:48 AM   #1054
HinGurl
Member#: 293678
2012 Impreza 2.0i
5 Door Limited. Silver
I bet that's enough for police officers to use as probable cause to search your car. Just sayin'...
HinGurl is offline   Reply With Quote
Old 07-11-2012, 10:57 AM   #1055
Dale2011WRX
Member#: 304299
2011 WRX Sedan
That's straight-up Ghetto.
Dale2011WRX is offline   Reply With Quote
Old 07-11-2012, 10:59 AM   #1056
ravenlunatic
Member#: 180601
2003 PSM WRX
the crown boot is old news folks. build a bridge...
Old 07-11-2012, 11:01 AM   #1057
yellowjacket757
Member#: 296879
2003 Impreza WRX
Sonic Yellow
i think its ****ing awesome, great idea!
yellowjacket757 is offline   Reply With Quote
Old 07-11-2012, 11:06 AM   #1058
ravenlunatic
Member#: 180601
2003 PSM WRX
this was my first go at the crown boot. it was in my old bugeye. I'm still looking for a shift trim for the new bugeye.
and yeah, i did get pulled over with this set up and the officer asked if i was drinking as he shined his light on the boot. I had to explain to him that it was just a boot and that my shift knob was not a bottle cap. kinda funny.
Old 07-11-2012, 12:45 PM   #1059
S4NDST0RM
Member#: 310704
2005 WRX Club Spec 8
Champagne Gold
Nice design! Have you considered fibreglass or cf instead? That will weigh a tonne in aluminium?
S4NDST0RM is offline   Reply With Quote
Old 07-11-2012, 02:09 PM   #1060
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
I know this has been done before, but I feel as though a lot of them look like hack jobs... so here is my go:
Custom air intake feed and heatshield:
The air intake tube/feed:
Bumper re-installed:
On top of the stock air box I am making a custom heat shield to go around the stock air box to block heat from the engine/turbo:
Finished/Painted/Trimming Added:
Installed:
and I made a radiator shroud (as you can see)
and with this set up my intake temps are only 5-10*F hotter than the ambient temps when driving and and 15-20*F hotter when sitting idle... major improvement over my SRI w/ heatshield I was running before this which was about 40*F hotter when driving and 60*F hotter at idle
RoxyTheImpreza is offline   Reply With Quote
Old 07-11-2012, 02:19 PM   #1061
Pidgeon
Member#: 284247
2002 Wrx
MBP!
looks awesome to me, but beware you will suck alot of ish in, not excluding small animals, ask me how i know haha
Pidgeon is offline   Reply With Quote
Old 07-11-2012, 02:21 PM   #1062
ppayer38
Member#: 234407
04 Self-tooned
STi
Installed:
Looks great and about what my setup did... I do like yours as it seals completely and looks great but that's why I didn't so mine like that cause I don't want to trap, water, leaves, etc with the hose attached to a sealed box.
ppayer38 is offline   Reply With Quote
Old 07-11-2012, 02:23 PM   #1063
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
yea, I was debating about putting the grill on the vent that leads to the box or to leave it open... I was going to leave it open and see how much junk was in the box when I cleaned the air filter....and then re evaluate adding the grill back.... here is what it looks like with the grille:
Old 07-11-2012, 02:40 PM   #1064
Unrealgtx
Member#: 178853
2007 Sleeper Suby
thats pretty good dude, and it looks like you can buy all that stuff at home depot which makes it even better
Unrealgtx is offline   Reply With Quote
Old 07-11-2012, 02:46 PM   #1065
Pidgeon
Member#: 284247
2002 Wrx
MBP!
grill looks good, that will stop the big stuff, leaves,sand,rocks etc will be in your box , but looks sweet still
Old 07-11-2012, 02:51 PM   #1066
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
Got it at lowes... But same difference!
Old 07-11-2012, 03:21 PM   #1067
02wrxej208
Member#: 295496
2002 ej208 vf34 wrx
Originally Posted by ppayer38 View Post
Pretty much 0...
It doesn't suck air at all, it is really only effective while driving. The fresh air is delivered through the hose directly to the intake and believe me it does work! But this hose isn't super smooth so water won't travel through it and it is has such an uphill climb
I know it wont suck and is only effective while driving, poor choice of words on my part but my worry is going 75 on the interstate during a thunderstorm, I would hope the uphill climb is enough to funnel any water back out but I have never tried one of these so I was not completely sure
02wrxej208 is offline   Reply With Quote
Old 07-11-2012, 03:48 PM   #1068
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
Mine has a light suction when I get a wild hair I am going to hook my shop vac on the side where it's connected to the airbox (making a huge suction) and then take the water hose with a shower nozzle on the and and point it in front of the fog light (where the funnel is connected) to simulate driving in a monsoon... This way if it doesn't soak up any water I know nothing will... Since both the water and vacuum suction will be way over exaggerated...
My prediction is since the tube I used has divots it will be hard for any water to make it up the tube and to the intake... Just my thoughts.
Old 07-11-2012, 03:53 PM   #1069
Drowner
Member#: 49297
09 WRX
09 ZX6R
That is ghetto, right down to the deck screw holding it down.
Drowner is offline   Reply With Quote
Old 07-11-2012, 04:11 PM   #1070
CobbWRX
Member#: 310040
I agree! Looks dumb but it's your car!
CobbWRX is offline   Reply With Quote
Old 07-11-2012, 05:49 PM   #1071
ravenlunatic
Member#: 180601
2003 PSM WRX
Once again, build a bridge....
I posted for the shifter.
Old 07-11-2012, 05:54 PM   #1072
ravenlunatic
Member#: 180601
2003 PSM WRX
Thanks, my buddy has an extensive shop and neither of us know how to work with fibreglass or CF yet so aluminum was a natural choice. It's still in experimental stage but the shape is coming together nicely.
Old 07-11-2012, 06:49 PM   #1073
Rennsport930
Member#: 325736
Originally Posted by apkarian100 View Post
Impreza V4 Bumper LED Front Turn Signals
This is nice!! I liked it.
Rennsport930 is offline   Reply With Quote
Old 07-11-2012, 06:50 PM   #1074
Rennsport930
Member#: 325736
This is a crazy looking diffuser
Old 07-11-2012, 06:54 PM   #1075
jvsoundwave
Member#: 66060
2007 STI Limited#534
Crystal Gray
Ya, go CF!!! If you made that baby in CF, you could get people on here to buy them... infact, Id go for one!
jvsoundwave is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
Message Board Statistics All times are GMT -4. The time now is 05:35 PM.
