Old 01-10-2013, 04:10 PM   #2201
sc00by4life
Member#: 97135
Originally Posted by jimbosv650 View Post
Lol Platin here in the states the things you consider mundane about your car are rare. Your fogs, hood, grill, even headlights are not readily available.
Joking right? That's a stock RS hood, and fog are readily available through Japan parts...a buddy of mine got his in the mail last week.
Headlamps appear oem too?
Old 01-10-2013, 05:13 PM   #2202
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
Finished up my scoop delete/vent and did a test fit. Cutting the hood was pretty easy but scary
Stock Scoop:
Scoop insert removed:
How much I cut from the hood. These were rough cuts, I need to even it out a touch along the front edge still.
Test fit of the new scoop insert:
Side view:
Under hood view:
atf78 is offline   Reply With Quote
Old 01-10-2013, 05:22 PM   #2203
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Can't see the pictures ^
alt14 is offline   Reply With Quote
Old 01-10-2013, 05:25 PM   #2204
Seegy24
Member#: 319426
2012 STi
Plasma blue pearl
I can
Seegy24 is offline   Reply With Quote
Old 01-10-2013, 05:31 PM   #2205
alt14
Member#: 271928
2014 WRX Limited
Now I can, odd..
Old 01-10-2013, 06:31 PM   #2206
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Nice work atf78! This is exactly why i check out this thread. Very cool idea and it looks great.
Mike
GrimmSpeed is offline   Reply With Quote
Old 01-11-2013, 12:52 AM   #2207
xlaterdaysx
Member#: 285807
2011 WRX 5-door
I completely love that vent! Kudos to you.
I think if I ever went front mount, I'd try to put something like that. But instead on the back/top of the scoop, and then block off access to engineering bay under the hood. So air would flow thru, then up and over.
xlaterdaysx is offline   Reply With Quote
Old 01-11-2013, 01:04 AM   #2208
Agentm
Member#: 343242
Originally Posted by mrchyes View Post
whats the point of a gauge when you dont look at it???
My WB02 is set up for logging. When I will be needing to be look at it I will be strapped to a dyno. And it's not pointless, it is a clean install. I dislike having A-pillar pods, and I already have a SMY cluster that has 2-gauges.
Agentm is offline   Reply With Quote
Old 01-11-2013, 11:59 AM   #2209
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
That hood scoop is awesome. Good work. A truly unique modification.
Old 01-11-2013, 12:59 PM   #2210
MotorOilMcCall
Member#: 342910
Whats the point of the scoop if you're running an FMIC anyway?
MotorOilMcCall is offline   Reply With Quote
Old 01-11-2013, 01:12 PM   #2211
easterbran
Member#: 307359
'05 STi Stage II
Cooling perhaps?
easterbran is offline   Reply With Quote
Old 01-11-2013, 01:58 PM   #2212
JSti07
Member#: 190019
07 STi
swp
awesome work on the scoop vent!
JSti07 is offline   Reply With Quote
Old 01-11-2013, 03:32 PM   #2213
jimbosv650
Member#: 261307
04 wrx wagon
No I'm not joking. Japanparts, as in shipped from Japan... and therefore not readily available in the conventional sense.
You're right on the hood, it is just like an RS model. Headlamps (oem cleared of reflectors), grill, and fogs are foreign market only.
jimbosv650 is offline   Reply With Quote
Old 01-11-2013, 05:00 PM   #2214
ppayer38
Member#: 234407
04 Self-tooned
STi
Stock Scoop:
Side view:
Under hood view:
As much as I like the idea of this I believe it will not work... You have put a vent directly infront of the hood scoop... If you didn't block the scoop off the it will just vent and go right back into the the engine compartment.
The idea was good and the work looks great and nobody would ever notice it wasn't a factory piece. I like it just don't think the functionality is there while driving. Idling yes it will work great!
ppayer38 is offline   Reply With Quote
Old 01-11-2013, 07:57 PM   #2215
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
The scoop is blocked off.
Old 01-11-2013, 08:09 PM   #2216
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
IN YO FACE!!!
looks great, are you gonna paint it?
m1r4g3 is offline   Reply With Quote
Old 01-11-2013, 08:52 PM   #2217
sc00by4life
Member#: 97135
readily available means anyone can order them at any time. which you can do with the fogs. go to the japanparts website, enter your credit card, and wait for them to show up at your door.
not readily available means the item isn't in production anymore, or would require someone to go to great lengths to acquire said parts....not just order from a website.
Old 01-11-2013, 09:16 PM   #2218
jimbosv650
Member#: 261307
04 wrx wagon
Ok guy whatever makes you feel better
Old 01-11-2013, 09:23 PM   #2219
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I guess you were too busy quoting all 6 of his pictures for no particular reason and didn't actually read his post that explained what he was doing:
Since installing an FMIC I've been looking for a way to block the gaping scoop in the hood on my 2011 WRX. I don't want to deal with an aftermarket hood and the integrated scoop can't simply be deleted like older models so I made a custom scoop delete + vented scoop insert out of a stock scoop insert.
Old 01-11-2013, 09:26 PM   #2220
sc00by4life
Member#: 97135
the one downside i see to that design.....
is you now created a parallel 90* surface with the direction the car is moving, thus generating drag. At least with an open scoop, there is somewhere for the air to go. I would've just bought a 2.5i hood if you didnt want the scoop.
awesome craftsmanship though.
Old 01-11-2013, 09:39 PM   #2221
mrchyes
Member#: 294069
98 Forester
Green
use the eyes God gave you and examine the pictures and you will realize that it is a mesh.
Air does indeed go through mesh. who knew. unless he got it enchanted in mordor, then obviously it will shoot fireballs at the air.
mrchyes is offline   Reply With Quote
Old 01-11-2013, 10:27 PM   #2222
ppayer38
Member#: 234407
04 Self-tooned
STi
While I read it I guess I skipped over that part... So if you would read mine, I wasn't being a douche just constructive critisim. But since we are on this, he is now trapping air at the delete because there is still a lip at the factory scoop inlet. So this could lead to the hot air benig pulled back in by a swirl effect by nobody knows until tested... I've done quite a bit of research and built my own deletes, this is new and creative which I like but why not make it more functional? He may have over looked this little feature which is why I pointed it out. Enjoy your day kids cause obviously the post above mine is just pointing out little things to help
Old 01-11-2013, 10:29 PM   #2223
sc00by4life
Member#: 97135
Since there is no direct frontal shot, there is no way to really tell. Judging by the post directly above mine, it appears I'm not the only one.
If there IS mesh on this part (excuse my ****ty description) ___| <-- this part, then I guess it really isn't a scoop delete, is it?
Old 01-11-2013, 10:32 PM   #2224
mrchyes
Member#: 294069
98 Forester
Green
that picture shows it Pretty clearly
Old 01-11-2013, 10:34 PM   #2225
sc00by4life
Member#: 97135
that is actually the mesh section just in FRONT of the scoop, which wasn't what I was talking about (circled below). It looks like it also might be mesh, but theres no good angle to make an accurate judgement.
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
