Old 01-20-2013, 11:58 AM   #2276
rcm scoob
Member#: 186825
dont think anybody else has this, unique to my car
rcm scoob is offline   Reply With Quote
Old 01-20-2013, 03:23 PM   #2277
OhTwo OBS
Member#: 322327
02 Impreza Outback
Originally Posted by emericareaper2 View Post
Not the most unique but fully functional & compatible. I also did this in my previous Subie. I use my GPS quite a bit (pizza delivery) & also charge my iPhone with it.
I wanted a new shift knob. The only appealing one was the STi one, but it had the 6 speed grid on it. So, I got this one & did a little "customizing". Now I won't have to explain to anybody why I don't have a 6-speed.
I have a sti 6 speed grid on mine and no one ever asks. Yours looks cool though
OhTwo OBS is offline   Reply With Quote
Old 01-22-2013, 08:40 AM   #2278
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
A little more progress on my project. Thankfully the fiberglass work actually went well and I'm happy with the way it's coming together.
Here it is after 2 layers of fiberglass and 2 layers of Bondoglass for a little extra strength. Still needs some more sanding and than some regular Bondo body filler to smooth out the rough spots and ready it for primer.
atf78 is offline   Reply With Quote
Old 01-22-2013, 09:06 AM   #2279
tuzzio
Member#: 292532
05 STI
Starting to come to life, I'm not a fan of the reverse scoop look, but good work
tuzzio is offline   Reply With Quote
Old 01-22-2013, 09:55 AM   #2280
MihaiFlorescu
Member#: 249278
2001 Wagon WRX
Originally Posted by Power6 View Post
Interesting I did a similar thing to my Grp N mount, focused more on replicating the stock voids to make the mount more vibration absorbing. It worked well as a "happy medium" in my case.
Why on Earth would you do that to a nice new part that goes on your car?
I have the modified group N from RCM and I don't find it too hard at all...
MihaiFlorescu is offline   Reply With Quote
Old 01-22-2013, 09:57 AM   #2281
xlaterdaysx
Member#: 285807
2011 WRX 5-door
This is f'ing awesome. I can't wait.
xlaterdaysx is offline   Reply With Quote
Old 01-22-2013, 10:10 AM   #2282
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Did you not bother to read his post that you quoted? I thought he pretty clearly stated that he did it "to make the mount more vibration absorbing." And apparently it worked for him since he said, "It worked well as a 'happy medium' in my case."
http://lateralperformance.co.uk/shop...ox%20mount.JPG
Hooray for you! So your personal preferences for NVH should be the baseline for everyone else?
[IMG ]http://bbs.scoobynet.com/general-technical-10/861071-grpn-gearbox-mounts.html[ /IMG]
That's not an image, IMG tags won't work.
Old 01-22-2013, 10:57 AM   #2283
Maritzay
Member#: 344480
Whats the point of the scoop if you're running an FMIC anyway?
Maritzay is offline   Reply With Quote
Old 01-22-2013, 11:39 AM   #2284
cegan09
Member#: 302222
2012 WRX Hatch
because clearly the best way to extract heat from the engine bay is to let it leave and immediately scoop back in behind the engine.
cegan09 is offline   Reply With Quote
Old 01-22-2013, 11:45 AM   #2285
xlaterdaysx
Member#: 285807
2011 WRX 5-door
Well reading his process you'd know that the scoop is blocked off on the inside. And then he just redesigned it again. To make it more effective.
Old 01-22-2013, 11:50 AM   #2286
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Reading? You mean I can't just jump to conclusions?
T-37 is offline   Reply With Quote
Old 01-22-2013, 12:00 PM   #2287
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
xluben posted about taking the factory WRX tranny mount, drilling a small hole, and filling the voids with, I think, silicone. Sort of a ghetto Group N. He said it did stiffen things up without adding too much NVH. Certainly cheaper and easier to try that first before hacking a Group N.
I went with a Torque Solution mount, Kartboy pitch stop, Whiteline cross-member bushings, Factory short shifter, Kartboy front and rear shifter bushings, and Anarchy Motive 1.5 pound shift knob. DEFINITE increase in NVH, but the way it shifts is worth it to me. Race Car.
Dale2011WRX is offline   Reply With Quote
Old 01-22-2013, 04:47 PM   #2288
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Originally Posted by Asymmetry View Post
Neat job! How did you cut it out? I was going to do a similar configuration but thought it was too much hassle to cut it all out, single line was irritating enough.
I drilled holes in the corners of the voids I mapped out, then sawzall the rest out.
Originally Posted by kh15 View Post
hahah somewhere engineers are passing pictures of that around laughing.
"Hey bill come look at this ****"
You probably don't know the engineers creed "everything is a compromise" the stock 5MT mount is super soft to quell the whiny gears they have to use to make the trans strong enough. The Group-N mount is the hardest rubber they could push through a mold for race teams that would have a solid mount if the competition rules would have let them.
At the time I wanted something in between that, and came up with a way to get it, and it worked. Everything is compromise.
I could say the same about you adding extra urethane to your Gp N mount ;-) I have learned in this game everyone has different opinions and priorities. You love NVH I don't. We mod to make it closer to how we like it.
I have done a bunch of drivetrain mounts that way over the years, started with window-weld, worked up to pouring casting urethane. I didn't do that for the Subaru trans mount, becuase I am not sure that it would have held up, the mount is so open. I found from years of doing this there is little adhesion between the rubber and urethane, so you have to rely on casting the urethane i around the original rubber to sort of capture it in. I have a feeling casting into the stock trans mount would not have lasted, but never tested so I can't be sure. I know a few others have done it.
I also already owned the Group-N mount, that's how I found out it had too much NVH for me. I've certainly wasted or hacked up more expensive parts than that ;-) It's only a tranny mount. That said this car was my daily driver. When/if I have a Subaru again it'll be a fun/race car, I'll weld that trans solid right to the cross member, then I can really talk some smack on the Internets!
Power6 is offline   Reply With Quote
Old 01-22-2013, 06:03 PM   #2289
Candor
Member#: 219200
Originally Posted by mattesonb View Post
tired of having a pitch black engine bay. I added 3 LED's and a hidden switch, the switch is mounted under the fender on a flexible piece of plastic that allows you to flex the button into the fender to turn them on and off.
Any chance for a pitch black out picture?
Candor is offline   Reply With Quote
Old 01-22-2013, 07:01 PM   #2290
mattesonb
Member#: 139607
2011 WRX
DGM Wrapped Satin Black
Sure, ill take one in the garage
mattesonb is offline   Reply With Quote
Old 01-23-2013, 06:33 PM   #2291
kickniteasy
Member#: 201661
2013 STI
2002 Forester
I still hate that we don't have an underhood light....I bought my Protege for 13K and it had one....a car more than double that doesn't.
kickniteasy is offline   Reply With Quote
Old 01-23-2013, 07:28 PM   #2292
tcoffin014
Member#: 173734
2011 WRX
Sexy White Princess
Haha yeah my 96 Mustang I got for 3500 had one
tcoffin014 is offline   Reply With Quote
Old 01-23-2013, 09:15 PM   #2293
scoobywagon02
Member#: 317757
2002 Impreza 2.5TS
Savanna Green
Originally Posted by saar View Post
it's certainly not like that in Alberta, you pay the fine, no demerits are added.
Same as in Ontario, pay the fine. No demerit points as they can't prove who was driving the vehicle.
scoobywagon02 is offline   Reply With Quote
Old 01-23-2013, 09:16 PM   #2294
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
Installed my painted sti control arms!!!! I need some better pix
King of Poop is online now   Reply With Quote
Old 01-23-2013, 10:30 PM   #2295
gregroot198521
Member#: 280844
2006 STi
Didn't you start this like 3 months ago? Like how it turned out.
gregroot198521 is offline   Reply With Quote
Old 01-23-2013, 10:44 PM   #2296
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Painted them a while back. We were trying to find he time to make caster spacers but I got impatient and decided to go ahead and install them without.
Old 01-23-2013, 11:09 PM   #2297
chrispsti
Member#: 342676
11' lexus isf
sti sold 2011 Lexus isf
Originally Posted by WRBoss View Post
Hurst T grip and shifter boot with a kartboy short throw
having owned a few muscle cars i appreciate the hurst shifter
chrispsti is offline   Reply With Quote
Old 01-24-2013, 02:44 PM   #2298
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
The Hurst "T" handle is awesome. my buddy has one in his 62 ford falcon. when ever he has allowed me to drive his car, it just fits the hand so well. I feel i can throw the stick shift into gears with authority.
Daddy_Digital is offline   Reply With Quote
Old 01-24-2013, 09:20 PM   #2299
Asymmetry
Member#: 92646
MY03 WRX Toaster
So wait Power6 and I modified a group-N mount to reduce NVH and you post up a pick of a pointlessly modified harden Group-N mount that increases NVH?
Asymmetry is offline   Reply With Quote
Old 01-24-2013, 09:28 PM   #2300
chrispsti
Member#: 342676
11' lexus isf
nothing too fancy. already have a tripe gauge pod and my boost/ meth gauges on the column so i wanted a spot for the afr gauge
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
