Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 01-10-2012, 01:55 PM   #1
autofixation
Member#: 269173
2000 Impreza OBS
Default EJ25 Phase I to Phase II CPS wiring solution
I did search the forums and people mentioned that an EJ25 Phase I wiring harness will work on a Phase II intake and engine with the exception of there being two plugs for CPS's on the Phase I harness and only one sensor on the SOHC Phase II engine. How do I get the ECU to be happy with one signal, or is there a workaround?
If this has been answered previously I apologize but I have been a month without a car and am in a time crunch.
autofixation is offline   Reply With Quote
Old 01-11-2012, 11:13 AM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I assume by CPS you mean cam position sensor? Or do you mean crank position sensor?
Either way, there's only 1 of each on the EJ25D (Phase I EJ25), and the sensors themselves are the same as the Phase II sensor. I don't know if the trigger patterns are the same, but I imagine they're probably not.
I've seen very, very few examples of people successfully mixing the two phases. (Mechanically, it's not an issue - there are plenty of engines, including direct from the factory, that have the Phase I EJ25 DOHC heads on a Phase II EJ25 block. Electrically is where it becomes hard.) Actually, I only know of 1 example, and the details of how it was done were a bit lacking. See this thread, and scroll down to the post by mechman900.
Phase 1 to Phase 2 questions jhull Subaru Conversions 2 01-28-2009 11:29 AM
2.5 phase 1 to phase 2 swap limeylight Subaru Conversions 12 12-29-2004 06:31 PM
phase 1 to phase 2 swap limeylight Normally Aspirated Powertrain 0 12-29-2004 10:24 AM
Tech Info: EJ22 N/A changes phase I to Phase II? FuJi K Normally Aspirated Powertrain 2 12-12-2004 10:12 AM
Swapping Parts from Phase I to Phase II Block dan_j_b Normally Aspirated Powertrain 10 10-25-2004 05:30 PM
