Old 01-10-2012, 03:09 PM   #1
92SVXMAN
Member#: 77834
1992 SVX
Claret
Unhappy Smoking MY04 Forester XT
It All started with code p0011/p0021, so i replaced the banjo bolt/filters. The filters had been removed already but i put them in anyway, and still got the codes. Then i checked the timing belt and found it off by a few teeth off, replaced belt,pullys,waterpump,tenionor and lined up all 9 points and put it back together. Then i started getting smoke out the exhaust pipe, after warming up? Can cooling be leaking into the turbo? If so where and how can i stop it?
92SVXMAN is offline   Reply With Quote
Old 01-10-2012, 04:22 PM   #2
bluesubie
Member#: 767
04 FXT
Do you see smoke coming out of the hood scoop or have you popped the hood to see if it's coming from around the turbo?
-Dennis
Old 01-10-2012, 05:14 PM   #3
92SVXMAN
Member#: 77834
1992 SVX
Claret
Thanks Dennis
No smoke when its warming up, after that its coming out the tail pipe big time. Looking under the hood near the turbo side of the engine see some, also see some leakage of coolant on the passenger side of the engine.I can't see where its coming from, point me in the right area and i'll look harder. A little smoke comes up around the hood and scoop at time nbut not much. Does any of that help?
Michael my04 foresterXT, 92 SVX
Old 01-10-2012, 06:20 PM   #4
bluesubie
Member#: 767
04 FXT
I'm really thrown off. It's almost like there are two different problems (turbo or seals and coolant lines/radiator). Here's someone with a bad water pump. http://www.subaruforester.org/vbulle...nt-leak-87019/
I don't recall anyone having coolant leak and smoke but check around on subaruforester.org
No more codes?
Anybody else??
-Dennis
Old 01-10-2012, 06:52 PM   #5
92SVXMAN
Member#: 77834
1992 SVX
Claret
Have replaced the radiator once before, and will be doing it again because its leaking around the top where the plastic tank is held on with the metal taps, ordered from 1stsubaruparts.com costs $100 less then my local Subaru dealer.
Still getting the P0011/P0021 codes.
Old 01-10-2012, 09:27 PM   #6
bluesubie
Member#: 767
04 FXT
I got those codes just before my turbo blew. Which is the turbo that had only 20k miles on it after being replaced for the seals.
-Dennis
Outback XT vs Forester Xt ? gumball Forester Forum 71 10-13-2013 12:51 AM
FS/FT : Sold rg3bonz Wheels/Tires 14 02-06-2012 07:42 PM
FS : NYC: Aluminum Dead Pedal for 02-08 Subaru WRX, STI & 04-08 Forester XT jamesfacts Interior/Dressup/Audio & Security 2 01-10-2012 04:02 PM
Forester XT v. Outback XT JSR Forester Forum 3 04-24-2006 10:59 AM
My04 White Forester XT ne0stai2dust Member's Car Gallery 12 10-03-2005 03:10 AM
