Old 01-10-2012, 10:38 PM   #1
Waskier
Member#: 294780
2008 WRX sedan
Default Cobb stage 1 data log review
I have an '08 WRX with 30k all stock but the stage1 Cobb map and SPT catback exhaust.
This is on Chevron 92 octane fuel and the standard stage 1 map
Temp was 32 degrees.
Wife was in the car only ran up to the posted speed limit
https://docs.google.com/spreadsheet/...WNMSHVCV2dHUlE
Waskier is offline   Reply With Quote
Old 01-11-2012, 10:23 AM   #2
Cobb Tuning
Member#: 4803
What is your altitude?
Bill
Old 01-11-2012, 10:42 AM   #3
Waskier
Member#: 294780
2008 WRX sedan
Bill
Altitude 600'
Forgot to specify I am running the 91 octane stage 1 map
Old 01-11-2012, 11:14 AM   #4
Waskier
Member#: 294780
2008 WRX sedan
duplicate
Old 01-11-2012, 02:50 PM   #5
Cobb Tuning
Member#: 4803
Altitude 600'
Log looks good. Boost is a little slow to build. You could possibly try the high wastegate map to see if that improve things. You can download the high wastegate (HWG) map from our map repository (and then transfer to the AccessPORT with the AccessPORT Manager software):
http://www.cobbtuning.com/info/?ID=3061
If you do reflash the HWG map, try to get a longer run (i.e. higher RPM), if you can do so safely.
Bill
Old 01-11-2012, 08:26 PM   #6
Waskier
Member#: 294780
2008 WRX sedan
Bill
Bill,
Thanks for all your help.
The car boosted slightly higher before I switched out the stock CBE for the SPT catback.
Is it normal for peak boost to go down when a CBE is added?
Heres another slightly abbreviated run with the 91 octane hwg map (I'm old and this took me over 80 in a 70)
https://docs.google.com/spreadsheet/...G9WbmhuWk1HMEE
Old 01-12-2012, 11:12 AM   #7
Cobb Tuning
Member#: 4803
Bill,
When you reduce exhaust back pressure, it can change how boost control reacts. This log looks good, but we don't want you to exceed the speed limit just to get it. We want you to have fun but be safe!
Bill
Stage 1 Data log review Waskier AccessPort 2 01-06-2012 12:06 PM
2010 Cobb Stage 2 Data Log Review WRXineohP Engine Management & Tuning 5 01-04-2012 08:36 AM
2002 WRX 1st data log review request the dude AccessPort 9 10-31-2011 04:46 PM
OTS Cobb Stage 2 Data logs Comparision jimbo15471 AccessPort 0 06-20-2006 01:18 PM
help reading Stage 2 data log wu299 Engine Management & Tuning 5 06-20-2006 11:59 AM
