Old 01-10-2012, 10:47 PM   #1
donkey_cart
Member#: 151448
2007 FXT sports
UGM
Default 2011 WRX - transmisson pops out of 3rd
The car just hit 12k miles. Previous owner knew about the problem, failed to tell me, and I did not experience it on the test drive. Nice, thank you. I really like to buy other peoples problems.
The shifter will pop out of 3rd gear given the right conditions. It seems to happen at low speed, no/low load from a 2nd to 3rd upshift OR if you rev match a downshift from 4th to 3rd. It's also happened a few times when going over a large bump or bumpy corner. The transmission works perfectly otherwise, and will stay in 3rd during accel/decel. Shift bushings are super mushy, plus it has the factory short-shift kit.
Bent shift fork maybe?
The car is at the dealer right now. I was able to reproduce it several times on a test drive with the tech. Let's hope it gets fixed without much drama. I'm on day 2 without my new car.
donkey_cart is offline   Reply With Quote
Old 01-11-2012, 02:28 AM   #2
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
If it was reproduceable on a test drive with a tech, they will fix it. It's not like they're going to say, it fixed itself. Good luck
furiouswrx is offline   Reply With Quote
Old 01-11-2012, 11:35 AM   #3
2011OBPWRX
Member#: 296791
2011 wrx
Does it have an SPT or any other short shifter? The shifter could just be loose causing it to pop out.
2011OBPWRX is offline   Reply With Quote
Old 01-11-2012, 12:12 PM   #4
donkey_cart
Member#: 151448
2007 FXT sports
UGM
Yes, it has the Sti short shifter kit installed as a factory option.
I don't like short shifters for the reason that they change the way the linkage operates. The damn 5 speeds are sensitive enough. I will upgrade the bushings in the future for sure, and possibly remove the short shifter.
Old 01-12-2012, 08:12 AM   #5
johnvk7
Member#: 245130
Seen this plenty of times, the bush comes off the 3-4 shift fork, and it wears away, so doesn't fully engage 3rd.
Definitely warranty
johnvk7 is offline   Reply With Quote
Old 05-22-2012, 12:33 AM   #6
ketchupfreak
Member#: 179749
2009 WRX
Yimi Tuned 291hp/320tq
Definitely warranty
The bush as in shifter bushing? I have this same issue with my 09 but I have the Perrin shifter bushing.
ketchupfreak is offline   Reply With Quote
Old 05-22-2012, 09:08 AM   #7
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Time to go back to the dealer then. I took my '10 2.5i for third gear poping out and they said they could not duplicate it on a test drive. Now 4th is a problem when down shifting.
Bababou is offline   Reply With Quote
2009 WRX Popping out of 3rd gear fulltimeW.O.T. Transmission (AT/MT) & Driveline 28 10-22-2011 11:38 PM
Popping out of 3rd & 5th drewmob Transmission (AT/MT) & Driveline 18 06-30-2011 04:09 PM
94 WRX 5 Speed pops out of first ThermosMcJug Transmission (AT/MT) & Driveline 3 05-27-2010 08:54 AM
My 6speed popping out of 3rd truckco5 Transmission (AT/MT) & Driveline 7 06-17-2009 04:47 PM
Trans pops out of first with a bang - 06 WRX PartsDept Transmission (AT/MT) & Driveline 13 09-25-2006 10:34 AM
