Closed Thread
Old 01-11-2012, 12:52 AM   #1
Rdizzle
Member#: 305385
Default 2012 Impreza Break-in Fluid Change?
I'm a first time Subie owner here and just picked up a 2012 Impreza Sport Limited. I usually do break-in fluid changes for all my cars at 1,000-1,500 miles. A couple of questions:
1. Do Subaru owners typically do break-in oil changes?
2. Do Subarus come with a special "factory fill" oil that helps seat gaskets, etc.?
3. Since the 2012 Impreza comes from the factory with 0w-20 synthetic, think I still need to change out the oil after the break-in period?
BTW, I tried search for break in posts in this forum but couldn't find anything.
Rdizzle is offline
Old 01-12-2012, 12:16 PM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
I changed out my factory fill in the 2011 WRX after around 700 miles, but that was because I was going to autocross it. Do whatever the manual says, and you should be fine. Or, pick an arbitrary number like 1K (so it's easier to base future drain intervals off of) and then go from there.
Did you get the CVT or Manual? There is some thought to drive the CVT in Manual Mode to vary the RPM's, otherwise the CVT likes to just stick it at around 3K and drive like that 80% of the time. Manual mode may help seat rings, etc.
Enjoy your new Impreza!
JamesWilson2 is offline
Old 01-12-2012, 02:41 PM   #3
FCP Import
Member#: 305489
91 skyline GTR
champ white
On my 2011 WRX I changed the oil out at 1000 miles even thought the manual said not to and I plan on doing it again at 3k and then normal intervals there after.
FCP Import is offline
Old 01-12-2012, 03:09 PM   #4
bluesubie
Member#: 767
04 FXT
I would probably keep the factory fill in for 3k miles unless the oil that you're going to switch to has high levels of zinc and Red Line levels of molybdenum like the Subaru factory fill. The SM version of the Subaru oil may have high levels of moly, but not the new SN version. Whatever you do, stick with synthetic 0W-20 since the engine was designed for it and for proper operation of the AVLS.
From Idemitsu Lubricants of America in regards to an email about Subaru and Toyota 0W-20.
First, just so you know where the information is coming from, Idemitsu supplies most of the OEM’s for both Factory fill and service fill. In the case of Toyota, we do not supply their service fill oil so I cannot comment on that particular formulation.
OEMs specify Moly in their factory fill formulations to increase fuel economy during the initial period. In general a factory fill formula will be more robust in the additive treatments etc. This is done for a variety of reasons which I will not go into here.
Some of the service fill formulations also contained molybdenum however, with the transition to the ILSAC GF-5 specification, most 0W-20 service fill 0W-20 formulations now do not have Moly. That being said, you are always safest following the OEMs recommendations. All service fill OE formulas that we supply have been submitted to a full battery of tests at that respective OEM’s R&D facilities in Japan and have been approved.
UOA on a Forester with the 2.5 FB engine.
UOA on Pennzoil Platinum. Notice how the zinc level dropped with the switch to Pennzoil. It would be the same for most off the shelf oils.
Like I mentioned in some of those replies on the uoa links, some of the moly from the uoa is assembly lube. But now that I've seen the above email from Idemitsu, I know that the factory fill oil also has a lot of moly.
Congrats on the car.
-Dennis
bluesubie is offline
Old 01-12-2012, 05:01 PM   #5
Rdizzle
Member#: 305385
Thanks for the replies guys. I got the CVT version (wife's car) and that's an interesting theory to use manual mode to vary the revvs. I'm going to try that.
I was planning to swap out all the fluids to Amsoil but looks like I'll leave the engine oil alone until around 3k. I'm guessing the WRX manual recommends this because of the high zinc to help seat the internals during break in.
I'm going to change out the transmission gear oil (not the CVT fluid) and the rear diff gear oil to Amsoil though. On a side note, I changed out the rear diff fluid on my Honda S2000 at around 1,500 miles and it was black from all the metal shavings from the new diff so definitely believe these break-in changes are worthwhile.
Rdizzle is offline
Old 01-12-2012, 05:02 PM   #6
Rdizzle
Member#: 305385
Forgot to add that I'll be sticking to 0w-20 synthetic motor oil for sure when the time comes to change it out.
Rdizzle is offline
Old 01-12-2012, 05:25 PM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Metal shavings aren't black and the color of oil has zero to do with whether its still good or not. You think you care about oil, but your posts show you are shotgunning ideas based on no knowledge. Either get smart (protip: sticky thread titled Oil FAQ) or just change your oil with whatever you like for no reason as you could fill your car with Butter Flavored Crisco and it would run just as good and last just as long. I've been down both roads....and now my oil changes run $22 total for parts as I just don't give a crap.
<---------150,000 1 owner miles on odometer
Unabomber is offline
Old 01-12-2012, 05:41 PM   #8
Rdizzle
Member#: 305385
I'm new to this forum but not new to cars or oil. I am basing my questions on what I know about dino oil and their relative suseptibility to shearing and the fact that new engines and gears will have more metallic shavings as they are broken in. Maybe my posts, in the form of questions, on this forum make it seem like I know nothing but I assure, I have very good reasons for doing the break-in oil changes.
As for the rear diff on my S2000...the metal particles are black. Take a look at any magnetic drain plug and you will see what I've seen (example of a magnetic drain plug): http://www.dirtguide.co.nz/images/products/5484.jpg
Break-in fluid changes probably aren't necessary but they certainly will help in extending the life of the vehicle. Consider the rear diff where you have about 1L of fluid with a lot of metal particles floating around. I don't want that in there longer than necessary.
Rdizzle is offline
Old 01-12-2012, 06:47 PM   #9
bluesubie
Member#: 767
04 FXT
With Amsoil I would go with the OE or XL oils since they are API certified. Dealers and SoA look for every reason to deny a warranty claim. Although if that doesn't matter, the Signature Series is good oil.
-Dennis
Old 01-13-2012, 02:56 PM   #10
79letour
Member#: 302570
2013 XV
DGM!
I also support the idea of changing out gear oils after break-in. It certainly wont hurt anything. Im going to go ahead and do the same... I base my opinion on my instruction at MMI/UTI and their info that I was taught. New pieces of metal wearing in together will produce metal fragments. Not necessary, but I've never spent anythibg close to twenty grand on a car before.
79letour is offline
Old 01-14-2012, 09:32 PM   #11
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Well poop...I traded in my '11 WRX for a '12 Impreza 5-door. And I LIKE IT. I only have 30 miles on it as of tonight, I guess I'm in the same break-in boat as you
Old 01-14-2012, 11:41 PM   #12
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
I am currently planning on ~3,000 for the first oil change, followed by another @ ~7,500. At the ~7,500 point I'll accomplish a tire rotation and then will follow the oil change/tire rotations at ~7,500 intervals. This would equate (at current usage) to twice yearly maintenance intervals.
G-Omaha is offline
Old 01-15-2012, 02:18 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
neither of my wrx's---bought new....had any reason to change the trans lube before 30k miles....nothing but a bit of sludge on the magnet drain plug
and the rear end was the same way
leave the trans and rear end alone
Uncle Scotty is offline
Old 01-15-2012, 12:39 PM   #14
Rdizzle
Member#: 305385
-Dennis
Their Signature series is API SN/SM certified...take a look in the "0W-20 (ASM)" section on the 0w-20 page (I can't link to it for some reason).
Rdizzle is offline
Old 01-15-2012, 12:54 PM   #15
bluesubie
Member#: 767
04 FXT
Ummm, how are you gonna beat down on EVO's now? I presume there is still an auto-x car somewhere at your disposal.
Nope, just slick verbiage like all oil companies.
APPLICATIONS
AMSOIL Signature Series Synthetic Motor Oil is excellent for use in all types of gasoline-fueled vehicles. It is recommended for all domestic and foreign vehicles requiring any of the listed performance specifications:
0W-20 (ASM): API SN (Resource Conserving), SM…; ILSAC GF-5, GF-4…
The XL and OE lines actually get the API Starburst but the ASM does not.
http://www.amsoil.com/storefront/images/XLZ_900.jpg
http://www.amsoil.com/StoreFront/images/asm_900.jpg
Personally, I don't think that really matters though. If you have a warranty issue where the dealer questions your oil, they will only want to see receipts showing that you used "0W-20". This is what Amsoil says about it:
Another common misconception is that motor oils must be API certified in order to meet warranty requirements. The fact is, lubricants are not required to be certified by the API, only meet or exceed API specifications.
http://www.amsoil.com/news/2008_worr...warranties.pdf
Keep in mind that bluesubie nor Amsoil are responsible for your Subaru warranty coverage. FWIW, I have read that Amsoil requests the codes off of each bottle when trying to obtain warranty coverage through them.
-Dennis
Old 01-16-2012, 05:06 PM   #16
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
haha I have a new business that will be taking up most of my time and ALL of my money, but I do have a '93 Impreza that has caught me looking up eBay front-clips with JDM STI V5 turbo swaps as it is pre-OBD hmmmmmmmmmmmmmmmmmmm
Old 01-16-2012, 09:01 PM   #17
fett2288
Member#: 307146
2016 STI
Wait, I'm confused. I took my 2011 WRX in for it's first oil change at 3500 miles and the dealership told me that it's not due until 7000. You guys are saying after 1000 though? What gives?
fett2288 is offline
Old 01-16-2012, 09:45 PM   #18
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Subaru's maintenance schedule is 7.5 months/7.5k miles for most of their cars (except for the ones with the 3.6R) on their website now - however, when I picked up my car there was an addendum for the user manual which said 3 months/3k miles for the LGT, so who knows... most of the service manuals have the change interval for severe operating conditions as 3.75 months or 3750 miles. They also didn't change the drain intervals even though they switched many of their cars to synthetic oils (WRX, '12 Impreza, LGT, Forester)
Do what you want to do - if you want them to change your oil, tell them "change my oil" and they should do it - if they say "it's not due yet" say "that's ok - please change it anyway"
DrD is offline
Old 01-17-2012, 07:14 PM   #19
Rdizzle
Member#: 305385
Changing at 1,000 miles is a break-in change for those owners who are anal about oil and engine wear. The thought being that new cars with new engines, transmissions, and differentials will have a lot of metallic particles shaven off while the components are new.
In my experience, I've witnessed a lot of metallic particles in new differentials in the new cars that I've owned (CRV, S2000) and my Ruckus. However, I've noticed the transmission and engine oils to be pretty clean and clear when changing them out at 1,000-1,500 miles.
The counter point is that doing a break-in fluid change is a waste of money and uneeded. Take a look at UnaBomber's Oil FAQ thread: http://forums.nasioc.com/forums/showthread.php?t=499177
Up to you to decide. For me, I'm going to change out the grear oils (both in the transmission and rear diff) at around 1,000 miles and let you guys know what I see. I'm anal about oil and want to switch everything to Amsoil so I'll probably do the engine oil at around 3k.
Rdizzle is offline
Old 01-17-2012, 11:22 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
I guess you are operating under the misconception that the gearbox and rearend are 'broken in' at 1k miles....and the engine and the rest of the car for that matter
mmmmmm.....im glad i got over that one long ago
oh....and you are doing it wrong, too
Old 01-18-2012, 10:52 AM   #21
2011OBPWRX
Member#: 296791
2011 wrx
I was told to leave break in oil for longer, 4000-5000 miles(depends on the way you drive).
Since subies come with regular oil from the factory, we waited til 5k and changed it then.
2011OBPWRX is offline
Old 01-18-2012, 10:44 PM   #22
79letour
Member#: 302570
2013 XV
DGM!
The 2012 Imprezas come filled with 0w-20 synthetic.
79letour is offline
Old 01-18-2012, 10:47 PM   #23
79letour
Member#: 302570
2013 XV
DGM!
And changing out gear oil will never hurt your car, maybe just your wallet a bit. But for twenty large, I sure feel all warm inside knowing its uber-maintained. To each his own. Changing my oil makes it feel more like "my" car for some reason.
79letour is offline
Old 01-19-2012, 06:40 PM   #24
79letour
Member#: 302570
2013 XV
DGM!
Just finished the +/- ten minute job of changing the fluid in the rear diff. The stuff that came out had quite a bit of metallic fragments, which I strained out. It was black as night. I filled it with amsoil 75-90 and will do the transmission as soon as I get ahold of new plug washers.
79letour is offline
Old 01-19-2012, 10:53 PM   #25
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Ugh. Change it every week if it makes you feel like more of a man, otherwise keep an eye on your oil level and run it until it needs to be changed.
CosmoTheCat is offline
Closed Thread
Where is my 2012 Impreza Sport Limited thedataman General Community 19 03-01-2012 02:55 PM
1st Time Fluid changes in my WRX and a Impreza dhjester Transmission (AT/MT) & Driveline 2 06-22-2008 03:31 AM
about to do a 6mt tranny and diff fluid change...where to get fluid? OneArmedScissor Texas Impreza Club Forum -- TXIC 9 10-21-2007 01:07 AM
Trans Fluid special at Scrub-a-dub - They'll pay YOU for a fluid change!!!! Mr Ludecrs Off-Topic 9 09-15-2005 10:30 AM
Socket size for a tranny and rear end fluid change/fluid question too keithja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-20-2002 10:52 PM
