Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 01-21-2013, 01:13 PM   #3076
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
This is the $30 block heater:
http://www.subarugenuineparts.com/pr...e80886011f0e1d
The plug comes very close to the exhaust manifold, and if you don't orient it correctly, it will touch. The $100 heater has an angled connector, so it doesn't have this problem.
Commander Keen is offline   Reply With Quote
Old 01-21-2013, 02:00 PM   #3077
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
When I called the dealer the price would be $204 + the heater (~$100). I didn't ask if that included replacement coolant; you have to drain the coolant to install it. I know often shop supplies like this aren't included in the quote. I've been meaning to call and ask but haven't.
On the other hand, the install guide for the block heater says it's a 20 minute install, so based on that, and the price of labor, I would think the coolant refill would be included.
Xafen is offline   Reply With Quote
Old 01-21-2013, 02:11 PM   #3078
stevehnm
Member#: 329526
2013 Impreza Spt cvt
Originally Posted by goregasm View Post
This is kinda related to this thread.
Someone said an engine coolant heater was really expensive if you found the one specific to the 2012, but found a generalized one on the subaru website somewhere, for like $30. Does anyone know where to find that? And how much would it cost to have a dealer install it?
Here's another one, magnetic - you just put it on your oil pan:
http://www.amazon.com/Kats-1160-300-Watt-Handi-Heat-Magnetic/dp/B000I8YOR4/ref=pd_sim_auto_1http://www.amazon.com/Kats-1160-300-Watt-Handi-Heat-Magnetic/dp/B000I8YOR4/ref=pd_sim_auto_1
stevehnm is offline   Reply With Quote
Old 01-21-2013, 03:13 PM   #3079
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Regarding the A/C going on with defrost, I had the A/C go on automatically when I had the left and right dials on "Auto" and set my temperature on the colder settings. I have the Limited trim level. Probably covered in the manual!
ST Eye is offline   Reply With Quote
Old 01-21-2013, 03:17 PM   #3080
ST Eye
Member#: 73068
With regards to adding a block heater and any other type of heater, you should incorporate the costs of the hardware/install and also the cost of electricity it takes to heat. Heating elements are rarely efficient and draw a decent amount of current. I don't think it's worth the cost to possibly save a small amount of gas.
Old 01-21-2013, 03:35 PM   #3081
M45
Member#: 333446
2013 Impreza SL CVT
my MPGs recently took a good dive. I went from average around 26-27 MPG doing short trips (reasonable considering) to averaging 23-24 MPG. I'm not sure if the gas just changed over to the winter mix or what.
M45 is offline   Reply With Quote
Old 01-21-2013, 03:59 PM   #3082
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
I know this sounds crazy but i think my car gets better gas mileage with a full tank vs 1/5 tank or less. Any possible reasoning behind this?
Old 01-21-2013, 04:25 PM   #3083
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Originally Posted by stevehnm View Post
Actually it seems to me that if the tank is 90% empty and I fill it with E0 then it will effectively have E01 (1% ethanol) and will be close to the performance of E0. Is that not true?
If you fill when the tank is half empty, then will it be 5/6/7% ethanol or something slightly higher or lower? E0 is E0, E1 is E1, and E5 is E5. If you are measuring E0 against E10, one would assume that the proper mix is being evaluated and not some other unknown ratio.
G-Omaha is offline   Reply With Quote
Old 01-21-2013, 04:43 PM   #3084
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
[quote=stevehnm;38960188]Here's another one, magnetic - you just put it on your oil pan:
[url="[/quote]
Would you recommend something like that? I certainly don't have the tools or skills to install the freeze plug heater from subaru.
Edit: don't even bother asking why my quote is messed up. one of my chrome extensions is a neonazi or something.
goregasm is offline   Reply With Quote
Old 01-21-2013, 04:45 PM   #3085
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Commander keen posted a thread with pictures. I put in the more expensive one because I found it for 88 shipped. I posted pictures in that same thread
Old 01-21-2013, 04:57 PM   #3086
Commander Keen
Member#: 319157
Resistance heaters are very efficient. ~99% of the energy is dumped into the engine and a trace amount is lost through the cord.
The heater draws 400 watts, so if you run it for two hours and pay $0.14/kwh, it will cost you 11.2 cents.
Compared to just climbing into a frozen car, starting the engine and taking off, that 11 cents is about what you'd save in fuel, so it's a wash in that case. However, if the block heater saves you from remote starting or idling to warm up, the savings would be greater.
There are other benefits too:
-Less startup wear ($$$$)
-More cabin heat sooner
-Better driveability
Old 01-21-2013, 05:00 PM   #3087
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
That's a great price, my dealers were 300+
Old 01-21-2013, 05:17 PM   #3088
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Do pad heaters you stick/glue on your oil pan work well enough to be worth $30+ and the $0.20 you'd pay to heat up every day if you'd otherwise just idle for 2 or 3 minutes?
Old 01-21-2013, 05:29 PM   #3089
CLL_OBP
Member#: 310435
'12 Sport Limited
P.U.P 5W20 110,150 miles
Doesn't sound crazy at all. I've thought the same thing for years. Best answer I've found:
Dear Tom and Ray:
While I know I should be worrying about the tension in Kosovo, I am instead trying to figure out the answer to a dumb question. Why do I get many more miles out of the first half of my tank of gas than out of the second half? For example, my car gets about 200 miles out of the first half-tank of gas. You would think, then, that I would get 400 miles from a full tank. But I don't. I get only another 100 miles or so as the needle goes from half-full to empty. This has been true of other cars I've owned, too. Why is this? -- Frank
Ray: You're absolutely right, Frank. It IS true of every car I've ever owned, too.
Tom: I can't say whether or not my '63 Dodge Dart ever did this. I never filled it up all the way because I didn't want to invest more money in the car than it's worth.
Ray: Here's what's going on: Even after your gauge reads "Full," the tank itself is not necessarily completely filled up. You can always cram in an extra gallon or two. Sometimes more. So you've got gas at the top end of the tank that the gauge doesn't even see.
Tom: So right away, you're starting with a couple of "bonus" gallons at the top. Then, you get "cheated" out of a couple of gallons at the bottom end of the tank, because even when the gauge reads "Empty," there's still more gas in there. And the amount varies tremendously from car to car.
Ray: Here's how it may work using hypothetical numbers. Let's say the actual capacity of your gas tank is 20 gallons. The gauge may only show you what's between the 18 gallon mark (Full) and the 2 gallon mark (Empty). The gauge would read "half-full" when you had 9 gallons left.
Tom: So after you've "filled it up," you have to burn off 2 gallons of fuel before the needle even starts to move down from the "full" mark. That means you actually DO go farther on the first half of your tank-full. And by the time you've gotten down to the halfway point (from 20 gallons down to nine), you've had the benefit of 11 gallons of gas.
Ray: Whereas, in the second half, you only get 7 gallons before the gauge reads empty (from nine down to two). And that's only if you run it all the way down to empty, which most people don't.
Tom: Why do most manufacturers make their gauges like this? It's not that they can't make them more accurate. It's just that they don't want you to overfill the tank or run out of gas.
Ray: Overfilling the tank can ruin the charcoal canister that traps fuel vapors. It's part of the emissions system and is therefore the manufacturer's responsibility for the first 100,000 miles.
Tom: And they don't want you to run out of gas for two reasons. One is that, as we all know, they are great humanitarians and don't want you to have to walk home on a cold, dark, rainy night. But more importantly, the car's fuel pump lives in the gas tank and is cooled by the gasoline. And they'd feel just terrible if you ran out of gas and burned out the fuel pump -- especially while the car was covered by THEIR warranty.
CLL_OBP is offline   Reply With Quote
Old 01-21-2013, 05:49 PM   #3090
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Well, you have one answer, but there is also another very simple answer. Think of a perfect cube. Now notch it out in the middle from one side to the other so it is like a saddle. You sit that over the rear control arms and suspension. You have the total volume of said cube at the top until you reach the point that the tank is notched to fit over "stuff". There is simply less volume in the lower part of the tank as a result of the notch. I don't know how many cars are designed this way, but I recall that on my old WRX, ther was actually a secondary fuel pump inside the tank to keep the level equalized in the lower part. Otherwise there would be fuel in one section you couldn't get to for use. Same principal if you had a pyramid. For every inch drop inside, the volume increases. A tank shaped like that would go down quickly at the top and slowly at the bottom. A fuel level indicator is a simple device. Generally, it does not meter fuel flow. It simply tells you the level inside the tank. Nothing more than a bobber floating on the surface connected to a rheostat.
John
Guzzi 1 is offline   Reply With Quote
Old 01-21-2013, 05:50 PM   #3091
vwgti123
Member#: 335945
2013 Sport Limited
Satin White Pearl
Originally Posted by flyboy1100 View Post
How is it not contributing when it drops your mpg an additional 1-1.5 mpg?
Easy.. I very rarely use those settings.
vwgti123 is offline   Reply With Quote
Old 01-21-2013, 06:10 PM   #3092
Commander Keen
Member#: 319157
I'm not sure, I've never used one. It looks like most of the stick-on heaters have less than half of the power of the OEM block heater.
Old 01-21-2013, 06:13 PM   #3093
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
My car fogs up if I don't
Old 01-21-2013, 08:09 PM   #3094
stevehnm
Member#: 329526
Maybe you have more hot air than vwgti.
Old 01-21-2013, 09:10 PM   #3095
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Originally Posted by sgoldste01 View Post
Right. So maybe people who are dissatisfied with their MPGs should consciously avoid both of the defrost settings unless the windows are really fogging up. Five percent is significant.
well, i have to admit: i learned something new. mine has been set that way for the past few months and my mileage has really dropped in that time. i'll have to play around with this as i unlikely need it on all the time.
nubsub is offline   Reply With Quote
Old 01-21-2013, 09:33 PM   #3096
myrt1987
Member#: 323103
2012 Limited 2.0i
Originally Posted by Guzzi 1 View Post
Well, you have one answer, but there is also another very simple answer. Think of a perfect cube...
no no no, yes thats true but thats not what i meant. I get better mpg numbers at a full tank. for example: full tank cruisin down the highway at 55mph at a steady 44mpg vs 1/4 tank cruisin down highway at 55 at a steady 39mpg. All other variables constant.
its easier to keep 40+ mpg while cruising with a full tank. Despite the extra weight. Im not talking about overall miles.
Old 01-21-2013, 10:23 PM   #3097
Commander Keen
Member#: 319157
Maybe a near empty tank allows for more moisture to condense, which is absorbed by the ethanol.
Old 01-21-2013, 10:47 PM   #3098
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
All I know is -10f + 20mph headwind + 70mph = crap mpg
Old 01-22-2013, 02:30 AM   #3099
CLL_OBP
Member#: 310435
'12 Sport Limited
Oh, now that's something totally different. I haven't noticed anything like that and I fill up at half tank.
Old 01-22-2013, 08:30 AM   #3100
stevehnm
Member#: 329526
Very true, unless you are using a relatively long and small diameter cord. However, another thing to think about is the heat lost to the environment because of the temperature differential. Still, the benefits could outweigh the additional cost in electricity, especially since it's probably used mostly by people on their way to work who might otherwise wait until the engine was warmed up for a couple of minutes in order for the colder oil to cycle through and lubricate the engine. That additional time could be work time (as well as the additional time saved by not holding up traffic in the slow lane to eek out a couple more mpg's).
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 11:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 02:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 01:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 09:08 AM
