Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-23-2013, 11:41 AM   #3451
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by aeoporta View Post
because you lose psi in winter, car feels better with those psi, personal preference, I have always found oem recommend psi to make tires squishy I don't know if that word actually translates what I am trying to say. 36/35 and 37/36 are my personal favorite psi, I did run 35/34 for a bit but found in snow I prefered a psi higher
I actually prefer 34/32 in the winter and 35/33 or 36/34, in the summer
Old 02-23-2013, 01:21 PM   #3452
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
I always run 35 all the way around...good balance between performance, ride quality, MPG, and tread wear.
jsteg is offline   Reply With Quote
Old 02-24-2013, 07:13 PM   #3453
Chris793
Member#: 336926
2013 Impreza Sport
Ice Silver
Took a trip from north atlanta to birmingham and back last week. Saw 33mpg for the trip, 430 miles on the tank. About what I was expecting driving 70+ and using cruise control most of the time. CVT transmission.
Chris793 is offline   Reply With Quote
Old 02-24-2013, 08:49 PM   #3454
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Roof rack and snowboards demolished my MPG. 26.5 on a trip where I usually get 30+. Included about 60 miles going 80mph. 375 ish mile trip altogether, I will make an effort to fit the gear inside the car.
foghelmut is offline   Reply With Quote
Old 02-24-2013, 09:32 PM   #3455
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
But the rear doesn't need that much because of the weight distribution, hence why I go 2 psi less. So far at 15k on the tires, wear looks pretty good
Old 02-24-2013, 11:29 PM   #3456
jsteg
Member#: 329271
Ice Silver Metallic
I'm not saying it NEEDS it, just saying that's what I run. 2psi will not make a noticeable difference in tread wear IF you rotate your tires like you should. I just prefer 35 all around, that's all.
Old 02-25-2013, 04:00 AM   #3457
bobdole888
Member#: 316658
2012 Impreza limited
5dr silver
I had a 2012 Ford focus rental for 1 week while on vacaton. Drove about 400 miles and got 31.6mpg reported by the in dash trip computer. I only filled one tank, so couldn't hand calculate. Ford focus has about the same epa rating as impreza.
This weekend I had similar type of mixed highway driving around the coast in my impreza. Impreza reported 31.8mpg on the dash. I typically get 1-2mpg less from hand calculated mpg.
It would seem that Impreza mpg is holding up well compared to the Ford focus.
To be honest, I haven't been thrill about the mpg from my impreza. The 36mpg rating had set my expectation to high. At least from this trip with the Ford focus, it seems that epa ratings do give a good reference for comparison between these 2 cars.
bobdole888 is offline   Reply With Quote
Old 02-25-2013, 06:49 AM   #3458
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Maybe not, depends on the tires too. Between the larger rear swaybar and factory tires I found anything over 34 in the back is pretty squirly/easy to loose grip in aggressive cornering. Hence why I go 2psi less.
Old 02-25-2013, 10:45 AM   #3459
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Good post.
Old 02-25-2013, 05:42 PM   #3460
brapple
Member#: 327032
2012 2.0i Premium
I see a much bigger difference between my Focus and the wifes Impreza. The rated mpg part is why I am disapointed with the Impreza. The dash readout of the Focus is much closer to the calculated mpg than the Impreza.
Interestingly enought the best mpg in the Focus was when my wife drove the car.
My Focus has a 5-spd and 16" wheels while the Impreza has the CVT and 17" wheels. This might be why the mpg are further apart then what you noticed.
Impreza
Focus
brapple is offline   Reply With Quote
Old 02-25-2013, 05:48 PM   #3461
brapple
Member#: 327032
2012 2.0i Premium
Since the forum doesn't seem to want to accept my edit to the last post, I have this additional information.
Both the Focus and Impreza are hatchbacks. Additionally my driving is closer to 50/50 while my wifes driving is closer to 25/75 city/highway.
Old 02-25-2013, 06:12 PM   #3462
CLL_OBP
Member#: 310435
'12 Sp Limited OBP
PUP 5W30 87,634 miles
brapple, what app is that?
CLL_OBP is offline   Reply With Quote
Old 02-25-2013, 06:32 PM   #3463
bobdole888
Member#: 316658
5dr silver
My focus rental was a dual clutch auto. I was very rough particularly in low speed crawl. Also there's problem with car rolling back due to the dual clutch auto keeping the car in neutral for too long. It's like sitting in a car driven by someone new at driving a stick.
I wonder if your 5-speed is what's giving it better mpg.
Both the focus and my impreza were hatchbacks.
Old 02-25-2013, 07:37 PM   #3464
brapple
Member#: 327032
2012 2.0i Premium
That must be an early one. The newer ones have hill assist which will hold the car even on flat ground. But then again a automated manual, which is what the DTC is, is suppose to act like a manual transmission.
The 5-spd maybe part of it, however the DCT is rated 26-37 highway where as my 5-spd is 26-36.
Old 02-25-2013, 07:42 PM   #3465
brapple
Member#: 327032
2012 2.0i Premium
Roadtrip - You get that chart when you turn the device sideways
Old 02-25-2013, 08:11 PM   #3466
bobdole888
Member#: 316658
5dr silver
Well, the CVT impreza is rated 36, and stick rated for 34.
I think we all know in this forum that the real world mpg of the stick is better than CVT. (All the people complaining about mpg are CVT owners!)
So I wouldn't be surprised if the 5-speed focus actual do better than the dct version.
Old 02-25-2013, 09:35 PM   #3467
jsteg
Member#: 329271
Ice Silver Metallic
I have a cvt and while I'm not getting 36 I'm not complaining. I think people forget that those are estimated fuel economy numbers.
Old 02-25-2013, 10:15 PM   #3468
ans2k
Member#: 315631
2012 Impreza Sport
I posted a picture a while back when i did nothing but city traffic driving.
867 miles later with my normal 50/50 mix driving the mgp jumps back up
ans2k is offline   Reply With Quote
Old 02-25-2013, 10:18 PM   #3469
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
My dash calc has been hovering around 26 or 27 for the longest time during my usual morning commute. My in-laws are watching the kids now so it cuts out a daycare dropoff. My avg is now over 28 and climbing on the first tank after the change. I'm probably going to hit a 400 mile tank. This is with 90-95% city/suburb. I never imagined HOW I drove would have an impact on my MPG...
hemophilic is offline   Reply With Quote
Old 02-25-2013, 10:46 PM   #3470
Zeeper
Member#: 299286
2015 WRX CVT
I think HOW anyone drives has an impact, and maybe moreso with the CVT transmission, though the reality is spooling up the 5speed also cuts into the MPG's.
Zeeper is online now   Reply With Quote
Old 02-25-2013, 10:48 PM   #3471
stevehnm
Member#: 329526
2013 Impreza Spt cvt
But they are estimated for comparison purposes. The CVT gets horrible mpg *compared* to other cars with the same EPA numbers.
stevehnm is offline   Reply With Quote
Old 02-25-2013, 11:43 PM   #3472
bobdole888
Member#: 316658
5dr silver
Well, the compared quite well between Ford focus and impreza. I got just about the same mpg.
Old 02-26-2013, 12:11 AM   #3473
jsteg
Member#: 329271
Ice Silver Metallic
I disagree!! I don't consider my avg 32-33 horrible compared to ANY car!
Old 02-26-2013, 12:51 AM   #3474
tspunk
Member#: 345444
2013 Impreza 5-door
hi guys...
my impreza shows me miles until i need a fillup on the dash. is that what yours shows? i see a photo above that says AVG MPG.
how are you calculating MPG to be precise? or are you just going with what the dash reads?
i imagine you'd have to set the trip and write down how many gallons you're filling up with and divide to see... (is it possible the MPG calculator in the car is inaccurate ... on purpose?)
tspunk is offline   Reply With Quote
Old 02-26-2013, 03:17 AM   #3475
jsteg
Member#: 329271
Ice Silver Metallic
Originally Posted by tspunk View Post
hi guys...
You too can make your dash read avg mpg or a few other options. I calculate by hand miles driven by gallons used.
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 11:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 02:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 01:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 09:08 AM
