Old 03-19-2013, 09:16 AM   #4026
Zeeper
Member#: 299286
2015 WRX CVT
No one is concerned about meeting the Window Sticker numbers who is driving within the parameters of the EPA tests. Most of the complainers have one of three factors that are killing their MPG's:
1) cold start/short commutes where the engine never reaches operating temps.
2) high speed driving (you know who you are).
3) those who stomp on the accelerator.
If you drive on the highway at 65mph with the cruise on you will see 30-40mpg
If you drive in the city for distances more than 10 miles you will see the city numbers.
If you drive it like you stole it, or never let it warm up, or expect the EPA numbers at average speeds over 70mph it ain't gonna happen, and it isn't the fault of Subaru, nor the EPA, nor the PZEV, nor the CVT, etc.
And you can get better mpg with a fwd, or a prius. Them's are facts. You can get window stickers with this car, no matter what the transmission, but you need to drive like you value mpg's more than not.
Zauri, you already know all this because your car does fine when you drive it longer distances, but your short commute with a cold engine provides crap for mpg's. Potential City drivers should be aware, but it does not mean that the EPA test was gamed or Subaru is lying. The EPA test uses a cold start but the rest of the 30 minute test is with the engine warming and warmed up.
Zeeper is offline   Reply With Quote
Old 03-19-2013, 09:27 AM   #4027
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
Originally Posted by Zauri View Post
What about current vehicles with similar ratings? Not trying to add fuel to the fire just asking though.
Simply put most of the equally rated FWD counterparts are pulling averages of around 29-31. Those barely scraping 25 are wondering why this car can't achieve these numbers with the same type of driving even with all factors considered.
I get 28.5 with mediated driving, basically always drive at 75, and tend to add 5 or 10 around town depending on traffic. I don't floor it often. When I tried I got 30. Then I got bored. But yes, it is possible.
Dirt Bringer is offline   Reply With Quote
Old 03-19-2013, 09:31 AM   #4028
Zauri
Member#: 333487
2012 Impreza 4DR 2.0
Limited DGM CVT
I average about 24-25 with a lead foot. 27 feathered. and 33 when I take long trips. Not jaw dropping but it'll do for now. and yes that feathering crap just takes all the soul out of how much fun it is to drive this car.
Zauri is offline   Reply With Quote
Old 03-19-2013, 09:48 AM   #4029
Zauri
Member#: 333487
Limited DGM CVT
Of course.
Yeah I wasn't referring to my case(as I have little/no issue tbh) just providing perspective for where all the the discontent continuously comes from.(It tends to get lost in all the pot shotting). I also do not think Subaru is on the hook for false advertising, not even close.
On those days where it has warmed I have already seen a slight improvement in how this cars performs MPG wise. Also I have started driving further into work instead of the short trips to the bus stop. Only managed about a 1-2 mpg increase but my tanks are inching much closer to at or above 300 miles now.
Mid distances drives > 10 but < 20 are often a toss up between the factors listed above. Mine are on back roads that tend to result in a constant mid speed drive with a few stops here and there which of course has contributed to the slight improvement.
Old 03-19-2013, 12:12 PM   #4030
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
This is precisely the logical failure. Take all of those cars with equivalent numbers and run them through the EPA test and they'll probably come out about the same. I'm sure you'd see a greater disparity if the EPA tests were closer to "normal" driving styles. The details on the EPA tests are just silly.
Look at the "Detailed Comparison" tab on this page:
http://www.fueleconomy.gov/feg/fe_test_schedules.shtml
What has been established here ad nauseum is that the Impreza differs greatly from other cars OUTSIDE of that test.
It is what it is and there's nothing to be done about it except get a different car if it means that much to the owner. I'd probably be really upset too if I were the leadfoot impatient type. But I'm not. I love my Imp even if it isn't quite as fuel efficient as I'd like it to be.
If the haters eventually sue and win, I'll take the annual $100 debit cards that the Feddle Gubmint would force Subaru to send. Not that I think the haters have a leg to stand on or the fortitude to even start a lawsuit...
hemophilic is offline   Reply With Quote
Old 03-19-2013, 02:01 PM   #4031
richde
Member#: 79498
2013 XV
I think the root cause of the CVT mileage issue is that it's harder to drive in an efficient manner with an auto transmission. In a manual, it seems like if you short shift and don't drive like an idiot, you'll get good mileage...with an automatic, you either have to force it to do so (which I haven't tried yet) or change your driving style.
richde is online now   Reply With Quote
Old 03-19-2013, 02:11 PM   #4032
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
The automatic knows what to do. Most people accelerate faster than what is the most efficient. The Impreza has a small engine. A larger engine might do 0-60 in 10 seconds more efficiently than the 2.0, as this would put the Impreza at max output, while the larger engine would only be operation at 70% (for example) of that or so. If you use a light foot and accelerate slowly, the automatic will behave accordingly. If you use a heavy foot and accelerate quickly, the automatic will behave accordingly.
foghelmut is offline   Reply With Quote
Old 03-19-2013, 03:02 PM   #4033
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
The logical failure here is that if you stray away from the EPA standards on most other cars the hit on MPG is not nearly as significant as it is for some of us. If we stray from the EPA standard it's a huge drop in fuel economy compared to EPA ratings. If you stray from the standard in the same exact manner in most other cars (not ALL FWD btw) you still get pretty close to EPA ratings.
Saying WHY ad naseum we get lower numbers does not explain WHY THIS PARTICULAR CAR suffers more when straying than others. & it's not ONLY an AWD vs FWD concept here. I myself stray from these standards & know why I get lower numbers. But I've strayed far more in my younger, faster days in many other cars (other AWD & another Subaru CVT recently too) & have still come very close to the EPA ratings. Even taking the old testing methods into consideration back then which would rate slightly higher I was able to come close, meet & exceed the ratings. But on this car.... not gonna happen. & I'm okay with that for the most part. But.....
That's the illogical part & why people are upset. That's what a handful of folks here seem to be missing the point on.
SleepNMnky is offline   Reply With Quote
Old 03-19-2013, 08:35 PM   #4034
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
I understand people are upset/disappointed. I'm not denying the emotional part at all. I'm slightly disappointed in the mileage but we've THOROUGHLY identified the shortcomings and workarounds. I suppose the options are adjust, replace, sue, or stay upset. Pick one. We all have to live with our choices so enjoy your first world problems.
Old 03-19-2013, 11:10 PM   #4035
stevehnm
Member#: 329526
2013 Impreza Spt cvt
LMFAO.
We understand that those (especially the unqualified to comment with the 5MT) who do not understand this relationship might be happy with their new car:
http://forums.nasioc.com/forums/show....php?t=2477627
But those of us who have had several new or newer cars and understand a little math know there is a problem.
stevehnm is offline   Reply With Quote
Old 03-20-2013, 07:44 AM   #4036
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
That thread is a rehash of this thread started by you to tilt at windmills.
Old 03-20-2013, 07:51 AM   #4037
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
Originally Posted by stevehnm View Post
LMFAO.
Not all the cvt owners are unhappy with their car so don't put us all in the same category. You are entitled to your opinion but that is all, your opinion not facts.
Caocao is offline   Reply With Quote
Old 03-20-2013, 08:31 AM   #4038
fistv
Member#: 350063
2013 Impreza sport
All true, it can take about 10-20 min for the oil to reach operating temp from a cold start. Go drive it for 5 min, stop, check the oil with your fingers, it will still be cold to the touch, depending on ambient temp, even though the blue temp light is out. Once the oil reaches operating temp it will start to cook off the moisture from condensation. I sure miss having gauges on this car and that is a future mod I intend to make.
fistv is offline   Reply With Quote
Old 03-20-2013, 08:51 AM   #4039
stevehnm
Member#: 329526
Sorry, we are all entitled to the facts. Besides, I didn't say I was unhappy with the car, I am unhappy with the mpg because it doesn't get the mpg of other cars rated at 36 mpg highway EPA.
Old 03-20-2013, 12:16 PM   #4040
Caocao
Member#: 330507
2015 Jetta TDI
Pure White
You stating something doesn't make it a fact!
Old 03-25-2013, 11:28 AM   #4041
Monkeybones
Member#: 351332
Default Better mileage after oil change, AEM filter
I wanted to wait to comment to this post until after my first oil change. I, like many others didn't have the best mileage out of my 2012 5-door CVT when new. But after my first oil change (a little late at 8k), filled with Mobile 1 and a Bosch premium filter, I also put an AEM filter on at the same time. My average mileage (according to the computer) would hardly ever get close to 36 on long flat highway cruises in TX before the oil/filter change. Now I am happy to comment that even with the AC on and not really paying much attention to efficient driving, the same computer is registering on the higher end of 36, even saw some 37/38 figures briefly. Now I haven't calculated my actual MPG yet, but I figure that if the computer was registering under 36 before, and now is registering above 36 without me disconnecting the battery (if that really changes anything) then its still an improvement. I'll update later with an actual calculation.
Monkeybones is offline   Reply With Quote
Old 03-25-2013, 01:57 PM   #4042
dubiousmike
Member#: 327473
2012 Impreza Sport L
With cruise control on and going 50mph, I can get 38-40 mpg. It's just a harsh fact that you need to keep the rpms down under 2k or so to get decent milage
dubiousmike is offline   Reply With Quote
Old 03-25-2013, 07:54 PM   #4043
Nomadic Logic
Member#: 135213
2012 2.0i Sport Prem
2012 Sport, CVT.
So I just finished a round trip of about 700 miles between MD and CT. I was at about 12k miles at the start, having only completed the 7500mi oil change. The trip was 95% highway, and was fairly varied elevation wise.
Each way consisted of 1 tank of gas. I averaged 32 MPG via Fuelly, 34 MPG on the digital read out. I stuck to 62 mph in 55 mph zones and 65 mph in 65 mph zones.
Nomadic Logic is offline   Reply With Quote
Old 03-25-2013, 08:55 PM   #4044
vwgti123
Member#: 335945
2013 Sport Limited
Satin White Pearl
Originally Posted by Nomadic Logic View Post
2012 Sport, CVT.
Thanks for sharing.. did you hand calc? Sounds like you drove responsibly and economically. JMO but I would have expected a bit higher MPG based upon the MPG claims for this car.
vwgti123 is offline   Reply With Quote
Old 03-26-2013, 08:28 AM   #4045
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
You cant justify expecting 36mpg when all you know is approx. avg. speed and distance. Many other things to consider: acceleration, road conditions, tire pressure, temperature, precipitation, traffic to name a few. All affect fuel economy so its hard to ecpect a certain number. To expect to be within the epa range of highway mileage is more reasonable. JMO
32 sounds pretty decent to me.
Old 03-26-2013, 08:33 AM   #4046
Zeeper
Member#: 299286
2015 WRX CVT
also winter fuel blends, usually 10% ethanol, which returns fewer mpg's. So the same exact drive in the summer could be return another 2-3 mpg.
Old 03-26-2013, 08:52 AM   #4047
stevehnm
Member#: 329526
You're probably right about 2-3 mpg.
Unfortunately for CVT owners (which leaves you out) 2-3 mpg just isn't going to do it, if one knows how well other 36 mpg highway EPA cars do. Here's the evidence (called data for you Zeeper) that the Impreza CVT should be rated at no more than 32 mpg highway:
Old 03-26-2013, 09:05 AM   #4048
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
My 39mpg at 65mph must be a freak statistal anomaly.
This car punishes heavy feet. I bet I could make your car get good mpg.
Old 03-26-2013, 09:15 AM   #4049
myrt1987
Member#: 323103
2012 Limited 2.0i
my money's on hemo.
Old 03-26-2013, 09:50 AM   #4050
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
i don't believe you got 39mpg because clearly when I got 38mpg in the 5speed it was proven that I was doing 60 in a 55mph zone and clearly no one drives that speed on i90. Your numbers sir are a complete fabrication
stop being an anomaly
/ sarcasim
aeoporta is offline   Reply With Quote
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 10:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 01:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 12:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 08:08 AM
