Old 06-09-2012, 03:18 PM   #1276
Rymar
Member#: 310672
2012 Impreza Ltd 5Dr
Dark Gray Metallic
Originally Posted by G-Omaha View Post
My Dealer could not get it to work...
My dealer (Carlsen Subaru, Redwood City, CA) adjusted the MPG gauge for me. At first they said they had never heard of it, but after I pointed out the page in the factory service manual that shows a plus/minus ten percent adjustment range, they adjusted it downward by 5% (that was my number, which I calculated from multiple fill-ups).
Last two tanks, have had 0.3%, and 0.1% error! So it is possible. They also told me I could bring back the car if the adjustment wasn't right.
Too bad we don't get the "high-grade" MFD (multi-function display) like Canadian models; you can adjust it yourself.
Rymar is offline   Reply With Quote
Old 06-09-2012, 04:31 PM   #1277
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Do you happen to have the page number in the factory service manual available. If so, please share.
Thanks...
G-Omaha is offline   Reply With Quote
Old 06-09-2012, 06:50 PM   #1278
Rymar
Member#: 310672
Dark Gray Metallic
Thanks...
Yes. I downloaded the FSM from techinfo.subaru.com ($35 3 day membership). Note that you are limited to 50 files an hour, but at least they allow downloads! (Honda and Toyota make it impossible to download a complete FSM from their sites). And, before anyone asks, sorry, I'm not going to share it. First there are the copyright issues, and second, the whole manual is 850 files, and 232MB.
My manual has release number G1120BE5, and the info is in the "IDI" chapter (Instrumentation Driver-Info), section 11. "User Customizing", on page "IDI(diag)-19". There is no detailed information about where in the SSMIII dealer software the setting is; it just says:
For operation procedures, refer to the PC application help for Subaru Select Monitor.
There are three items in the table: external air temp, MPG gauge, and second level seatbelt warning.
External air temperature
compensation value: default: 0C (F), range: -5C (F) +5C (F)
Mean fuel consumption
compensation value: default: 0%, range: +10% -10%
Second level belt warning
customize default: Shifting prohibited options: Shifting prohibited/Shifting permitted
Old 06-09-2012, 07:02 PM   #1279
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Thanks
Old 06-10-2012, 01:07 AM   #1280
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Dammit, you need the SSM in order to make those changes...
Interestingly I drove my STI today for about 150 miles on 100% highway and my trip computer said 21 MPG, the actual calculation was 22.8 (btw, the highest I have ever gotten!). The '12 Impreza did the same thing on one long trip, on pure highway it underestimated the MPG.
ST Eye is offline   Reply With Quote
Old 06-10-2012, 05:56 PM   #1281
subiTWO
Member#: 273054
2012 Impreza CVT HB
Had to work Saturday, so took the opportunity to drive 5 under the limit for my 40 mile commute. 72 degrees, no wind, I got 42.3 MPG indicated, and with my gauge over estimating 2.2 mpg on my last fill, that's 40.1 actual mpg. On the way back home, 82 degrees, A/C on full blast, and gusty winds, I got 7 mpg less. The car loves warmer temps in the morning.
subiTWO is offline   Reply With Quote
Old 06-14-2012, 09:44 AM   #1282
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
finally figured out how to drive this thing to get the best gas mileage. For some reason letting off the gas on down hills engages engine braking. If you just feather the throttle the CVT will stay in it's tallest ratio and stay in lockup. On my morning hwy commute after 12 miles I avg 40.4 mpg. I've found keeping the CVT in that tall ratio is the key, even in uphills...
I was also surprise to see how well the car torques itself uphills at low rpm. I could hold the rpms at around 2k going up a hwy hill and not lose too much speed. Instant indicated 32mpg going up a 20% (give or take) grade at 65mph!
Ladeef is offline   Reply With Quote
Old 06-14-2012, 10:03 AM   #1283
ocellaris
Member#: 302559
Even if you could adjust it yourself, you would find each tank is going to be off one way or another. It would just drive you nuts
ocellaris is offline   Reply With Quote
Old 06-14-2012, 01:52 PM   #1284
pxpaulx
Member#: 306218
2012 Impreza CVT
DarK Grey Met. Sport Prem
Agreed, with the CVT if I hit a hill I drop it into manual/6th gear to keep the engine braking from occurring. I'll also drop it into 6th at the slightest hint of an incline to avoid the jumpy revs of even the slightest pedal pressure when the car is in D.
pxpaulx is offline   Reply With Quote
Old 06-14-2012, 02:13 PM   #1285
Rymar
Member#: 310672
Dark Gray Metallic
My mpg gauge errors were pretty consistent; these are the percentage errors on the 7 fillups before having the dealer adjust the gauge (all are negative with respect to actual mpg). I know others have seen different results.
6.8%
3.8%
4.6%
5.7%
5.3%
6.6%
4.2%
Since the adjustment, two fillups have both had less than 1% error.
Besides, I'm an engineer (I'm already nuts!).
Old 06-14-2012, 02:16 PM   #1286
Oddbaru
Member#: 315869
2015 Crosstrek
Quartz Blue Pearl
First tank, calculated: 27.3mpg 60/40 Highway/City
The computer actually showed a little less. I'm satisfied, especially for the first tank of gas ever.
Oddbaru is offline   Reply With Quote
Old 06-14-2012, 02:27 PM   #1287
nubsub
Member#: 313575
2012 Impreza 2.0i HB
6.8%
3.8%
4.6%
5.7%
5.3%
6.6%
4.2%
to drive your further nuts ...
have you checked the accuracy of your odometer using Google maps?
i'm 99% sure mine is roughly 3% off. that roughly compensates for my 5% error in the computer.
off topic: so how do you rate the Carlsen service folks? i do most things myself, but if and i ever figure out a way to replicate these rattles or they get worse and become persistent, i'm debating between them (i bought my car from Carlsen) or Capitol.
nubsub is offline   Reply With Quote
Old 06-14-2012, 04:23 PM   #1288
Hooligan76
Member#: 323215
2012 Impreza
Ice Silver Metallic
Just picked up my 2012 Impreza Premium w/CVT two weeks ago so it's nowhere near broken in yet but I'm averaging 28.5-29.2 in the city and about 40.2 highway, liking what I'm seeing so far!
Hooligan76 is offline   Reply With Quote
Old 06-14-2012, 04:42 PM   #1289
ocellaris
Member#: 302559
Dang people from the south always get the good stuff. In Maine I can barely go a mile before going up or down a hill anywhere in my area, and its been cold enough that I hard to turn on the furnace a few days ago
Old 06-14-2012, 04:48 PM   #1290
nubsub
Member#: 313575
LOL.
reminds me of a quote i heard when i helped a friend move up to northern maine several years ago:
"Up here, there are two seasons. Winter and the Fourth of July."
Old 06-14-2012, 05:21 PM   #1291
SZRimaging
Member#: 314053
2012 Impreza
Marine Blue Pearl
Originally Posted by nubsub View Post
LOL.
Michigan's is winter and construction. I swear, the orange cone/barrel is the official state tree or something....
SZRimaging is offline   Reply With Quote
Old 06-14-2012, 05:36 PM   #1292
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i think that applies to most northern states. MN/ND for sure!
Old 06-15-2012, 01:25 AM   #1293
cny12owner
Member#: 322250
2015 WRX Premium
Ice Silver Metallic
Been watching the MPG closely, as I've never owned a car with the CVT or that's AWD. First tank came out at 25.99 MPG (about 1 MPG below the display) and the second tank came out at 27.41 MPG (again, around 1 MPG lower than the display). Both tanks were mixed city/highway driving, with no prolonged highway miles.
Today I had the chance to do some miles on the interstate, roughly a 30 mile stretch with no bottlenecks or slowdowns, just a few rolling hills and some nice flat straightaways. One way, I locked in the cruise at 77 MPH, moonroof wide open, A/C on low at my feet. Display showed around 30 MPG. Return trip, I locked in at 67 MPH (consistently running around 2100 RPM), nothing open, no A/C, but after dark at a lower temperature. Display showed just shy of 33 MPG. I will be repeating this same drive the next couple days, so I'm gonna try tinkering with how I drive it to see if I can squeeze a few more MPG out. Of course with the car still not broken in, that may change some numbers down the road.
I have noticed with the 'instantaneous' MPG display that at 50-55 MPH, the car seems to consistently yo-yo between the low 30s and the low 60s on the display. I'm kinda wondering if there's a 'sweet spot' in the speed range that the car has been optimized at to get the best MPG...
Definitely changing how I drive somewhat in an effort to optimize my MPG. Gonna take a little while to figure it out, though...
cny12owner is offline   Reply With Quote
Old 06-15-2012, 09:55 AM   #1294
SZRimaging
Member#: 314053
2012 Impreza
Marine Blue Pearl
So I got 36.3 MPG indicated on my commute to work. about 16 miles, mostly 55mph country roads with rolling hills, small town with two stoplights. So in total I had to stop at one stop sign, two stoplights, and Subway to grab some breakfast.Probably about 3 miles were at 35mph, 2 miles at 25mph.
Old 06-15-2012, 12:38 PM   #1295
cycling4fitness
Member#: 316471
2012 Impreza Sport
I got 3000 miles on my car. I get about 26-28mpg,on a full tank of gas i get about 340-360 miles of combined driving(city and highway). I don't know or it is just me, I observe that you get high mpg on the dash board when you have travelled less that 50-70 miles (Reseting the odometer and computer) As the computer is calculating the mpg on less miles/gallon used. But if you use the full tank of gas the mpg is less as you have more miles/the gallon used. I happens all the time. The beginning it will register 36-37miles but after burning a full tank of gas truly it will average 27mpg, 1 less mpg if I compare it to actual gas consumption versus miles.
Hopefully in the future when cars are advertised 36 mpg highway they need to specify the speed they tested the vehicle. Because the sweet spot I notice on the car is driving bet 45-55mph. Anything above that will burn more gas. I experimented on mph compared to mpg. 80mph: 26mpg, 70 mph: about 27-28mpg, 60mpg:30mpg. Realistically I can't drive 45 mph on the interstate without getting into an accident.
cycling4fitness is offline   Reply With Quote
Old 06-15-2012, 03:02 PM   #1296
nubsub
Member#: 313575
if i understand you correctly, i do not see the behavior you cite. although the mpg can fluctuate a lot early in a tank, i wouldn't say it overestimates the mileage more earlier in the tank.
for eg, this is my first tank where i was doing purely city driving. for the first 100mi, i was averaging 24ish mpg on the computer with an average speed of 17mph. since then, i'm mixed in some highway and its now at 28mpg.
i do find my computer is roughly 5% high, but in my mind that is partially offset by an odometer that reads 3% too low (ie, underreports miles travelled)
Old 06-15-2012, 05:39 PM   #1297
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
EPA highway tests go up to 60 mph and have an average speed of 48.3 mph. You'd be surprised what their testing definitions are versus what your definition would be. Careful not to confuse the two. http://www.fueleconomy.gov/feg/fe_test_schedules.shtml
SleepNMnky is offline   Reply With Quote
Old 06-15-2012, 08:41 PM   #1298
subiTWO
Member#: 273054
2012 Impreza CVT HB
[quote=cny12owner;37379820]I'm kinda wondering if there's a 'sweet spot' in the speed range that the car has been optimized at to get the best MPG...
quote]
This is what I measured on a flat, tree-lined road. I'm getting about 7 mpg better now than I was at that time, so this may need to be guesstimated upward. Got less than 50 mpg at 25 mph...
Old 06-15-2012, 09:05 PM   #1299
ST Eye
Member#: 73068
What are you using for data logging?
Old 06-15-2012, 11:05 PM   #1300
cycling4fitness
Member#: 316471
2012 Impreza Sport
You are right, very informative link. We can't really compare real world mpg to the way they test. Things I noted was
1. Average distance traveled during the EPA test was 10 miles. Such a short distance to get a good realistic ratio of miles to the gas consumed. As I observed when you reset the computer and travel 10 miles the MPG calculation tend to fluctuate a lot and very sensitive to acceleration and deceleration.
2. Gas burned was measured through the emission with EPA test while we try to compare it with the fuel gauge or amount of refueled gas.
I'm hoping that auto manufacturers would be more detailed when they are advertising car based on their mpg efficiency. Because it is very miss leading to buy a car that is 40 mpg just to realize that you can only achieve that driving around 40-45 mph with no stopping.
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 10:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 01:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 12:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 08:08 AM
