Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 07-11-2012, 09:25 AM   #1451
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
Originally Posted by Haunty View Post
I noticed the first half of the bars go slower, the last half of the bars drop quickly. My last car was like that too.
Every car i have owned seem to do that also. from my 88 chevy blazer to 2012 subaru.
auskip07 is online now   Reply With Quote
Old 07-11-2012, 10:25 AM   #1452
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
This link goes into it a little saying that the fuel gauges are notoriously inaccurate. I've always noticed the same trend, more miles out of the first half of the tank than the second. According to this it's just the way the gauge reads it. Also, even with the low fuel light on & after I've hit the one bar left & continue to drive past that for say another 20 miles, the tank is certainly not near Empty. When I fill up I get 12.5 gallons at most in that tank so actually at 30mpg there's still be at least another 45 miles I could get out of the tank. So that low fuel light must be calibrated for when there is still 1.5-2 gallons left in the tank. I don't make a habit out of running it to E but that one bar left & low fuel light I'd say gives you at least another 50 miles.
http://auto.howstuffworks.com/fuel-gauge.htm/printable
SleepNMnky is offline   Reply With Quote
Old 07-11-2012, 10:32 AM   #1453
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Owners manual states reserve fuel is about 2.5 gallons, once the light comes on.
Ladeef is offline   Reply With Quote
Old 07-11-2012, 10:57 AM   #1454
ocellaris
Member#: 302559
Fuel tanks always read E before they are actually empty because the fuel also acts as coolant for the fuel pump. Running out of gas sucks, but then running out of gas and then having to buy another fuel pump sucks even worse than that. Often when people run out of gas, then get more gas into the car, it will not start. Fuel pumps are not cheap.
Also when you really run out of gas, the fuel filter can pickup stuff it would not normally pickup and cause a problem in the fuel filter.
Cars are not like lawnmowers. Running out of gas is really bad for the fuel system.
ocellaris is offline   Reply With Quote
Old 07-11-2012, 11:26 AM   #1455
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Which is why I start looking for a gas station at around 300 miles since my last fill up, regardless of how many segments are showing on the gas gauge.
sgoldste01 is online now   Reply With Quote
Old 07-11-2012, 11:41 AM   #1456
kevinsUBARU
Member#: 2263
2012 Impreza Sport
In my experience the gauge will run out and with the light on, it's something like 40 miles left on the display. When I reach 400 miles past my last fill, I look for a station.
kevinsUBARU is offline   Reply With Quote
Old 07-11-2012, 11:46 AM   #1457
Impreza1228
Member#: 325234
2012 Impreza Pre CVT
I try to never let less than 4 bars appear before I fill up. The reasoning is to prevent pickup of any contaminates they may be in tank.
Impreza1228 is offline   Reply With Quote
Old 07-11-2012, 12:50 PM   #1458
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Satin White Pearl
I had my fuel pump replaced on my last car, it cost over $700 installed, but it was over 100k miles.
Haunty is offline   Reply With Quote
Old 07-11-2012, 01:02 PM   #1459
Impreza1228
Member#: 325234
Did you run nearly dry or allow some fuel to remain in tank during this 100K?
Old 07-11-2012, 01:42 PM   #1460
Haunty
Member#: 319378
Satin White Pearl
90% of the time I filled it at about 1/4 tank left.
Old 07-11-2012, 05:03 PM   #1461
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
The last 3 tank fills all at the same station and same pump at said station, i can add 2.7 gallons after the pump 1st clicks off. I will usually go 100 miles before the first bar turns off. Then Depending on the drive type Which for me is either Normal city or Extreme city. I can get between 10-20 miles per bar through the rest of the tank.
ZionZR2 is offline   Reply With Quote
Old 07-11-2012, 06:40 PM   #1462
stien
Member#: 315086
2012 Impreza Premium
5MT 5 Door AWP Just Black
I've been getting 39mpg mixed reliably by not stepping on it too much (manual hatch, '12, premium pkg with no racks). Love this car. I've even been able to get 46 by really, really grannying it.
stien is offline   Reply With Quote
Old 07-11-2012, 08:31 PM   #1463
subiTWO
Member#: 273054
2012 Impreza CVT HB
The pickup does not float on top of the gasoline. It's at the bottom of the tank.
subiTWO is offline   Reply With Quote
Old 07-11-2012, 08:33 PM   #1464
subiTWO
Member#: 273054
2012 Impreza CVT HB
My first and last bar are very close to 1.5 gallons, while the others are close to 1 gallon. That assumes that my mpg was about the same from the full tank to the empty tank. Since an empty tank is much lighter, that may not be strictly true, though.
Old 07-12-2012, 08:43 AM   #1465
Impreza1228
Member#: 325234
What are you saying the fuel pump inlet is at the very bottom of tank and it does not matter?
Therefore running it to reserve is acceptable?
I find that hard to believe, I think that you should not run any car until is at such small level common sense will tell you if anything is at bottom of tank it will be pickup-ed by fuel pump.
We must use common sense logic regardless of where the pickup is located.
Old 07-12-2012, 10:15 AM   #1466
Haunty
Member#: 319378
Satin White Pearl
There can't be that much sediment in the fuel. I mean it's probably filtered at the refinery, it's filtered at the gas station, and again in your car.
Old 07-12-2012, 11:20 AM   #1467
tomwi53092
Member#: 316315
2012 Imp HB/Prem/CVT
DCP
My question to you is: how do you think the car can draw down the tank dry, or nearly dry, without feeding from the bottom? It can't.
The fuel pump is siphoning from the bottom of the tank, or near the bottom all the time, regardless of the amount of fuel in the tank. Keeping extra fuel in the tank above where it is siphoned off is not protecting anything. It is not preventing any sediment in the tank from being siphoned out. That's OK - the fuel filter will catch any sediment or particles in the tank - that's why it's there.
You're not harming your engine if you run it with a half-gallon of gas in the tank. The only thing that might happen then is if you make a hard turn, the inertia might make the gas move to the side of the tank away from the gas inlet, and the car might sputter momentarily. (Or more correctly, the car will move while the gas will try to stay in place, causing the gas to be at the side of the tank and away from the fuel inlet).
tomwi53092 is offline   Reply With Quote
Old 07-12-2012, 11:56 AM   #1468
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
How are the fuel pumps in our Imprezas lubricated? I know that in VW TDIs (and other brands too), the diesel fuel provides the lubrication for the fuel pump. But diesel fuel has more lubricating properties (lubricity) than gas, which is why putting gas in a diesel car is so catastrophic. The fuel pump gets destroyed very quickly.
So in a gas car, how is the fuel pump lubricated?
Old 07-12-2012, 01:40 PM   #1469
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
Not likely to get cavitation with the gas in the tank. I have been autocrossing for years with a minimal amount of gas in the tank taking turns harder than you would on the street. I never had an issue. I did however with power steering fluid.
ST Eye is offline   Reply With Quote
Old 07-12-2012, 04:11 PM   #1470
saabarupp
Member#: 189032
2007 Sti Ltd 413/800
'12 Impreza Sport Ltd DGM
The fuel tanks are likely baffled like the oil pans are.
saabarupp is offline   Reply With Quote
Old 07-12-2012, 04:59 PM   #1471
BretAZ
Member#: 320866
yup....
BretAZ is offline   Reply With Quote
Old 07-12-2012, 05:40 PM   #1472
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
Best tank so far filled today 14.202 gallons added 393.0 miles driven. (The Low Fuel light was NOT on yet and still showed 2 Bars remained on gauge.)
Calculated 27.7 mpg (Best after 6 fills)
Dash 29.7 mpg avg
A deviation of 2 mpg or 7.2% over
Dash 31 mph avg
E-10( <-- ) 87 Octane Exxon.
I had mixed city driving this tank. instead of mostly extreme city like I usually do. I do Not consider anything within city limits to be highway driving. (even if the road I am on is called a highway)
Old 07-12-2012, 06:39 PM   #1473
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Dash 29.7 mpg avg
Dash 31 mph avg
whoa! 2 bars remaining and you filled in over 14 gallons. do you do a big top off after the first click?
nubsub is offline   Reply With Quote
Old 07-12-2012, 06:48 PM   #1474
Zeeper
Member#: 299286
2012 Sport 5MT
Green/Silver
Topping off is dumb and in some vehicles can damage vapor recovery (aka emissions) equipment.
I don't think (actually I am pretty positive, but too lazy to search the owners manual to correct a practice that I don't do) Subaru or any other manufacturer recommends it.
If you are driving in remote areas without gas stations maybe, but for your typical commute it is dumb, just like wanting to force the car into 1st gear above 20mph is dumb.
I'm always left scratching my head and wondering how so many dumb practices are being talked up on this forum. But it's your car, do what you think is excellent.
Zeeper is offline   Reply With Quote
Old 07-12-2012, 07:15 PM   #1475
SleepNMnky
Member#: 302491
Nubsub wasn't saying he/she did, just asking how someone could fill to 14.2 gallons. I'm always left scratching my head and wondering how so many people feel the need to call people dumb and school all of us on what they assume us little people don't already know.
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 10:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 01:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 12:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 08:08 AM
