Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-05-2012, 06:09 PM   #2076
ocellaris
Member#: 302559
I am working on a bit of an experiment where I stick with M mode (CVT) and 5th gear through ~10 mile section of rolling hills on my daily commute. This prevents the engine braking from kicking in and allows the car to slow a bit when going up hills. I have the car on cruise control between 46 and 51 for the whole section. I tried doing sections of this in 6, however the car keeps kicking down to 5 for a lot of the hills so I am just going to leave it in 5 to make it simple.
My drive is highly reproducible (almost zero traffic) so hopefully the next fill up will yield some results.
ocellaris is offline   Reply With Quote
Old 10-05-2012, 08:21 PM   #2077
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Why not leave it in 6th with cruise control?
Old 10-05-2012, 08:57 PM   #2078
ST Eye
Member#: 73068
2008 STI Boost Wagon
2014 Honda Accord Hybrid
I have found that when I am going ~48 MPH, the car is in the 6th gear range. At that time you can flip it over into manual mode and it will stay in 6th gear, provided your speed doesn't drop below 40 MPH. That being said, you can drive up small hills with more throttle and not have the car downshift. You can see the ECO gauge not take a big hit with this method of driving. The only caveat is that you won't accelerate up inclines very fast, in fact if the hill is steep enough it will slow down despite you flooring it in 6th gear.
ST Eye is offline   Reply With Quote
Old 10-06-2012, 01:01 AM   #2079
myrt1987
Member#: 323103
2012 Limited 2.0i
Thats what i would think is most efficient. to drive/coast in 6th
Old 10-06-2012, 10:25 AM   #2080
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by flyboy1100
Didn't think to check my tires this morning before going to work. My gas mileage sucked this morning big time, but not just due to underinflated tires they was also 3"of slush i was plowing though and a 40mph headwind. Was getting 23mpg at 55mph.
Tonight with a 15mph tailwind i was only getting 28mpg at 75, which i know is low. Car was also sluggish in the handling department. When i got home after my 41 mile commute u checked my tires and they were all below 30, the front were down 6, while the back were down 5. Overinflating didn't seem to help much but underinflated site makes a big impact!
Same conditions last night with the tires at 34/32 like i like them and i was back to seeing 31-32mpg. I really didn't see and mpg loss after i dropped from 38/36, but wow when they dropped below 30psi there was a 12% loss
Old 10-06-2012, 11:12 AM   #2081
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
jsteg is offline   Reply With Quote
Old 10-06-2012, 04:32 PM   #2082
Penguin44
Member#: 315883
2012 IMPREZA
Yup same. I use the recommended pressure and we got a cold snap a little while ago. My mileage sacked. Checked and it was at 28psi. Filled her back to normal and all is good.
Penguin44 is offline   Reply With Quote
Old 10-06-2012, 04:59 PM   #2083
subiTWO
Member#: 273054
2012 Impreza CVT HB
I am working on a bit of an experiment where I stick with M mode (CVT) ...
Huh?! My CVT will stay in 6th until MPH drops below 43. It will NOT downshift on it's own even at WOT when in manual mode.
subiTWO is offline   Reply With Quote
Old 10-06-2012, 05:00 PM   #2084
subiTWO
Member#: 273054
2012 Impreza CVT HB
I've notices *worse* mileage in manual mode w/CVT, because I use more throttle to accel, even though RPM's are lower. In auto mode, the engine revs so high at small throttle that I back off the throttle and don't get much accel.
Old 10-07-2012, 11:44 AM   #2085
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
Doesn't take an engineer to figure this one out, bud.
goregasm is offline   Reply With Quote
Old 10-07-2012, 06:14 PM   #2086
subiTWO
Member#: 273054
2012 Impreza CVT HB
Hey, basement genius...
People have been discussing the possibility of manumode being more efficient for the last year. If you actually had a CVT, and an inquiring mind, you'd know that the CVT revs the engine very high under mild accel. Leading to the very understandable assumption that keeping revs down by nearly half would be at least somewhat more efficient.
The reality is that it doesn't.
But I guess it would take a (real) engineer to understand that.
Old 10-07-2012, 07:03 PM   #2087
DougNuts
Member#: 192568
2015 Outback 3.6R
Originally Posted by flyboy1100 View Post
Even after airing up my tires i was only managing 23mpg this morning again at 81mph into a 30mph headwind. So i guess that isn't bad as the car was seeing a combined 110mph wind, but still. Temp was 31f
It is imperative that you guys keep speeds to a max of 70mph if you're looking for economy. The difference in fuel economy between 70 and 80mph can be as much as 6-8mpg on some cars.
DougNuts is offline   Reply With Quote
Old 10-07-2012, 07:13 PM   #2088
ST Eye
Member#: 73068
Heck, it's imperative that you keep the speeds between 55-60 if you want the best mileage.
Old 10-07-2012, 07:55 PM   #2089
53x12
Member#: 206332
Not necessarily true. Many cars have multimodal graphs for speed vs. mpg. Depending on the car, you could be getting better fuel economy at 65mph than you would at 50mph depending on engine and gearing.
53x12 is offline   Reply With Quote
Old 10-07-2012, 08:17 PM   #2090
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I understand, and i fully understand why my mpg sucks so bad in those conditions.
That tank ended up at 26.9 so all things considered i can't complain too much
Old 10-07-2012, 10:53 PM   #2091
ST Eye
Member#: 73068
I'm talking about THIS car!
Old 10-07-2012, 11:34 PM   #2092
53x12
Member#: 206332
Gotcha! Sorry, I thought you were just speaking in general. Sorry.
Old 10-07-2012, 11:45 PM   #2093
ST Eye
Member#: 73068
No hard feelings at all! It is just funny that because I have to drive this car so slow on the highways that my wife tells me to drive faster!! Lol
Old 10-08-2012, 12:47 AM   #2094
n00b on demand
Member#: 158355
2012 Sport 5MT
Just made a 125 mile round trip today and saw 33-35 MPG with my MT impreza sport
n00b on demand is offline   Reply With Quote
Old 10-08-2012, 12:48 AM   #2095
ST Eye
Member#: 73068
Trip computer or calculated?
Old 10-08-2012, 12:54 AM   #2096
n00b on demand
Member#: 158355
2012 Sport 5MT
trip computer
Old 10-08-2012, 09:16 AM   #2097
ocellaris
Member#: 302559
As I noted, I set the cruise control between 46 and 51. Going up a hill, the car will lose a few MPH (like to 43MPH or below) and then drop down to 5th. The car doesn't have enough power to go up hills at those speed and not lose momentum in 6th.
So if you want to see your car downshift itself, set the cruise control at 45 MPH, gear 6, and find a hill.
Old 10-08-2012, 12:02 PM   #2098
ST Eye
Member#: 73068
It's kinda sad how the car can't climb a moderate hill in 6th. I feel like the little engine that could as the car slowly starts to loose MPHs.
My gas guzzling STI on the other hand...
Old 10-08-2012, 01:42 PM   #2099
53x12
Member#: 206332
Define "moderate hill" as CO will have a different definition than say MI.
Old 10-08-2012, 01:49 PM   #2100
ST Eye
Member#: 73068
For CO, it's probably a slight incline!
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 11:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 02:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 01:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 09:08 AM
