Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 10-16-2012, 10:22 PM   #2201
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Got this tonight on my way home. Forgot to check total mileage in this tank so far, but it should be around 60 miles. First 10 miles on this tank were all in town 30ish mph, los of stop lights. Remainder is 61mph driving home, no wind, a few small towns with speed reductions. Even accounting for the 3% higher on the readout pretty darn good mileage for my 5sp.
And what i was getting while driving, was fluctuating between 40-43 on the readout.
Old 10-16-2012, 10:29 PM   #2202
53x12
Member#: 206332
Originally Posted by pkL View Post
Sorry this is kind of off topic but since when are Mazdas reliable?
My '02 has been super reliable. No issues with it at all. Only money I have put into it is oil, tires and gas. Literally. 10 years old and has 142,000 miles on it. Besides Subaru, Mazda is the only other manufacturer that I look at when considering a new car. They are great. Each car has passion designed and built into it.
53x12 is offline   Reply With Quote
Old 10-16-2012, 11:06 PM   #2203
BrDb
Member#: 333203
2012 Sport Premium
MBP 5 SPD
Not sure if this has been brought up yet, didn't want to read through 89 pages regarding fuel economy, but has anyone noticed that the difference between real MPG and what the dash indicator reads is drastically different? (I did see a post about someone saying there is a 3% difference). For example, on my last fill up, the dash read I averaged 29.4 MPG, but when I calculated it myself it was actually 26.7 MPG. I noticed this on the fill up before, however, it did not seem quite as drastic. I have been filling up at the same station so I don't think it's a matter of one pump cutting off earlier/later than another pump.
BrDb is offline   Reply With Quote
Old 10-16-2012, 11:50 PM   #2204
ScoobyCO
Member#: 236205
2013 ImprezaSport5MT
Ice Silver Metallic
Yeah, found the same. Look at the posts 2 & 3 above yours.
The dealer can adjust this for you up or down 10% with their Subaru Select Monitor III. Just tell them exactly how much it's reading high.
ScoobyCO is offline   Reply With Quote
Old 10-17-2012, 05:16 AM   #2205
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Yeah, I found I could get great numbers immediately after a fill-up, especially if the engine was already warm when I filled up. But I was never able to maintain those numbers for an entire tank. All it takes is a few stop-and-go errands to bring the number down.
sgoldste01 is offline   Reply With Quote
Old 10-17-2012, 06:48 AM   #2206
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Lots of times. Do you know your odometer error? Most seem to be 2.7-3.5%.
When i have my block heater installed next month i am going to have them turn mine down 3% which should make it dead on
Old 10-17-2012, 06:50 AM   #2207
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Wasn't warm, but it was warm out so re-warm up didn't take long. I usually see close to [email protected] i just can't bring myself to drive that slow, and my normal commute i drive at 75
Old 10-17-2012, 09:52 AM   #2208
BrDb
Member#: 333203
2012 Sport Premium
MBP 5 SPD
Cool thanks for letting me know. I'll start keeping track of the exact numbers.
Old 10-17-2012, 04:58 PM   #2209
chicagocpo
Member#: 315470
2012 Impreza LTD
Marine Blue Pearl
I've tracked every tank since I bought my car. Until my 1st oil change I usually calculated over 2 mpg lower mileage from the readout, about 5.6%. Then I saw something here questioning odometer accuracy so checked it over several measured distances. Quite a surprise - result is, I times my miles driven by 1.05 before calculating mpg, and now my calculations are usually within .5 of the readout (but still lower).
chicagocpo is offline   Reply With Quote
Old 10-17-2012, 07:24 PM   #2210
nubsub
Member#: 313575
2012 Impreza 2.0i HB
for me, enough checks puts my odometer error at 3.5%
Fuelly for lifetime of car (5900mi or so): 28.0mpg calculated with odometer numbers
Impreza computer reports: 29.7mpg
so correcting for 3.5% odometer error, "real mileage" is 29.0mpg
so, my computer is still a bit overoptimistic.
nubsub is offline   Reply With Quote
Old 10-18-2012, 08:28 AM   #2211
M45
Member#: 333446
2013 Impreza SL CVT
what distances were you using and how do you know you could trust them? I'm a little surprised that the odometer can be that for off. does this mean the speedometer is off as well?
M45 is offline   Reply With Quote
Old 10-18-2012, 09:40 AM   #2212
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
thats good news. that means our mpg-meter is actually more accurate then our calculations at the pump using the odometer miles.
Old 10-18-2012, 09:42 AM   #2213
myrt1987
Member#: 323103
2012 Limited 2.0i
i found that my speedometer was pretty much spot on with the roadside radar speed indicators.
Old 10-18-2012, 09:57 AM   #2214
M45
Member#: 333446
2013 Impreza SL CVT
well if the odometer needs to be increased by 5% I think the speedometer would also be off by 5%.
How fast were you going when you checked? Lower speeds (if it's a constant 5%) might be tough to tell.
I guess we need to know the source of the error in the odometer - is it an incorrect estimation of the tire size? some other weird error? is the error constant or does it change under different conditions?
Old 10-18-2012, 09:59 AM   #2215
pxpaulx
Member#: 306218
2012 Impreza CVT
DarK Grey Met. Sport Prem
It is normal for a speedometer to be off anywhere from 2-5% - the manufacturer sets the vehicle the same, even with slight differences between tire sizes within the same model (i.e. base 16 inch wheels vs the 17s on the sport and limited models). The mercedes we had had a set of amg 18 inch wheels on it, I ran the speedo against my handheld gps (most accurate way to track actual discrepancies) and it was just shy of 9% off!
The reason 2-5% is not uncommon is that depending on tire size and tread depth, a set of tires can change that much on their own over their useful lifetime.
pxpaulx is offline   Reply With Quote
Old 10-18-2012, 10:08 AM   #2216
myrt1987
Member#: 323103
2012 Limited 2.0i
It would make sense that the speedometer is off by the same margin, but it seems accurate with gps as well. my last car (95 accord (dont worry, it was stock lol)) was off by about 5 mph on highways compared to gps!
Old 10-18-2012, 11:41 AM   #2217
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No speedometer in these cars is dead on accurate, odometer is off though. How they managed that i have no idea
Old 10-18-2012, 11:45 AM   #2218
53x12
Member#: 206332
Actually that is pretty damn good considering how different pumps have different cutoffs for when they stop pumping. So fairly decent if you ask me. I bet with more time/miles, the computer and hand calculated values will get closer to each other.
Old 10-18-2012, 12:46 PM   #2219
M45
Member#: 333446
2013 Impreza SL CVT
considering one is the derivative of the other - yeup!
Old 10-18-2012, 09:19 PM   #2220
n00b on demand
Member#: 158355
2012 Sport 5MT
Just got 280 miles on my tank. Mainly City driving with a tiny bit of highway. Took 11.8 gallons to fill up. 23.7 MPG actual....the digital meter indicated 25.8. Not impressed whatsoever. I got better mileage with my 06 impreza 2.5i 5MT.
n00b on demand is offline   Reply With Quote
Old 10-19-2012, 09:33 AM   #2221
53x12
Member#: 206332
^ I bet you take a lot of short trips in town? My wife and I consistently average 27-28 mpg/tank for our city driving. This car doesn't do well for short drives where the engine doesn't get up to the efficient operating temperature.
Old 10-19-2012, 10:15 AM   #2222
vigil05
Member#: 322861
2012 Impreza Spt Ltd
Dark Grey Metallic
This..
I'm lazy and i can attest to the terrible mileage when taking short trips ~2 miles. I get about 20 MPG...
I should really ride my bike to work...
vigil05 is offline   Reply With Quote
Old 10-19-2012, 10:37 PM   #2223
n00b on demand
Member#: 158355
2012 Sport 5MT
Yeah you can say that. My commute to work is literally only 5 miles one way. I do that at least 3 times a day....( coming home for lunch) and ect. This car is great for highway driving.
Old 10-19-2012, 11:21 PM   #2224
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
This car is great for doing 45-60 mph on quiet two lane highways. Serious mpg drop off happens during stop-n-go and anything faster than 60.
My 7 mile oneway city commute and 70-75 mph highway jaunts are about the same mpg. I never get to drive in this cars sweet spot.
Lifetime Fuelly is about 27... Meh.
Lifetime Fuelly for a 2003 Civic was about 29 with the same drive.
hemophilic is offline   Reply With Quote
Old 10-20-2012, 06:57 AM   #2225
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I find that I can get thirty-something MPGs on a highway driving 70 MPH, so I disagree with your "anything faster than 60" statement. However, this is only true if the highway trip is long enough for the car to reach and then stay at normal operating temperature for an extended time. Short trips are brutal on the MPGs.
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 10:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 01:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 12:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 08:08 AM
