Old 09-04-2013, 01:03 PM   #2626
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Word. I think I'll just pick up the AEM here soon.. Would you happen to have a part number handy?
On my Si with the Injen intake, I eventually swapped to a Fujita filter. It was actually quite nice. Same design as the Apexi, but like $40 less. lol I'd get one of those if there was an acceptable metal tube intake for our cars..
averagewhiteboy is offline   Reply With Quote
Old 09-04-2013, 01:27 PM   #2627
tenaciousZ
Member#: 342279
2012 Impreza Sport
^^ AEM part number is a couple posts up buddy.
tenaciousZ is offline   Reply With Quote
Old 09-04-2013, 04:25 PM   #2628
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
There is also perrien and green filter we share the same air box as a 05+legacy gt
subaru222 is offline   Reply With Quote
Old 09-04-2013, 04:33 PM   #2629
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I still own a legacy gt so the intake box is the same
If you take apart the box on the impreza or xv you will notice the bottom that goes into the fender has a hole that is blocked off on a legacy gt that hol is open and had a intake silencer on it
I was gonna drill that hole out on the impreza to get some more air flow
Old 09-04-2013, 04:41 PM   #2630
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Post an update. Was curious on such a thing.
Old 09-04-2013, 05:11 PM   #2631
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Ill try and take pictures later wife took the car.
But takemout your stock air box and look on the bottom there is a perfect circle that is block off.
On a legacy gt it is open and has a air silencer on it, i took this off my lgt to let more air in the intake
This would be the same for the impreza or xv 12+
Old 09-04-2013, 06:00 PM   #2632
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm guessing it already is capable of more flow then required......
Old 09-04-2013, 06:15 PM   #2633
CLL_OBP
Member#: 310435
12 Sp Limited
M1 0W30 96,465 miles
You talking about this hole:
This goes into this space:
I cut that hole out last summer and experimented with cold and warm air. Currently using warm air and it makes more of a impact mileage-wise (+3 mpg) despite losing some power. Cool air from the fender just burned more gas and not much zoom zoom with a CVT anyway so I'll take the better mileage instead. This was accomplished by using a 3" aluminum duct from Home Depot and a 3" to 2.something" exhaust pipe reducer to squeeze through that hole in the airbox.
Alright, gotta go cut the grass now
CLL_OBP is offline   Reply With Quote
Old 09-04-2013, 06:37 PM   #2634
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I find your +3mpg claim unrealistic. Cool air should produce more power and cut down the load.
I have a fender well intake on my other car in traffic I have seen iat climb 20f (insignificant really), and at speed it matches OAT. Under hood temps are warmer yes, but not that much warmer unless a at a dead stop
Old 09-04-2013, 06:52 PM   #2635
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
So that little hole going into the fender essentially just further grabs air (in addition to the grille scoop) at idle more than anything I'd assume? I really see no benefit of changing anything with that design short of using a bendy hose and routing it to the hole in the fog light panel (assuming you don't have them), thus forcing more air into the airbox at speed. Otherwise, it's not really doing much opening it up more or closing it out.. Correct?
Old 09-04-2013, 07:49 PM   #2636
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I just removed the intake assembly on my Sport. I have no "hole" marked to the fender liner area from the factory. I will use a flashlight, but it definitely wasn't obviously marked.. Is it on the outside or the inside?
Old 09-04-2013, 08:34 PM   #2637
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I doubt the FB-20 could suck enough air to justify any type of Ram air setup. I'd bet the engine bay doesn't get hot enough for there to be much difference at speed with cold air vs regular intake setup. I'd say a good filter will do as much as possible, and I'm not sure how much if any it'll help. If anything it'll give you a nice intake sound, which would be a huge improvement from a car that takes sound and tactile feedback away from motoring IMHO. I think the car runs better than it seems due to that fact. It seems very mundane and anemic. However, in town that anemia always gets me out in front at the dig under normal driving. With a little noise it would be a spirited drive. I just can't opt for anything sounding like a coffee can without a whine/ whistle and BOV. Otherwise I think I'd feel like a poser.
Side note: had a guy laughing at me in town once in the deuce just before the light turned green. He said car looked nice, sad I couldn't fix the rattling muffler. I shook my head and smiled, he was talking about the twin disk clutch chattering. So I try not to judge a car by its sound if I don't know what I'm talking about. I'd bet he felt the same way shortly after that too! ;-)
G2Spfld is offline   Reply With Quote
Old 09-04-2013, 09:25 PM   #2638
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
I posted this in the one other 12+ thread too, but this one has more viewers..
Inside the stock intake tubing, there's a little mesh insert between the intake filter and the long portion of the tubing holding the MAF. At least on mine, it's white plastic-ish mesh with grey material inside. I've gathered that it has something to do with the PZEV system. If you remove said mesh insert, will this mess anything up in the computer? These cars seem very touchy in the ECU department.
Old 09-04-2013, 09:41 PM   #2639
CLL_OBP
Member#: 310435
12 Sp Limited
Yeah, cool does that and I tried it first. I'm talking about warm now. I switched to the warm air setup in late June. My last 12 fill ups average over 30mpg versus 27-something prior to that. See my fuelly.
Maybe or it could be a lot warmer if you have the duct wedged between the exhaust manifold and the muffler like this:
Old 09-04-2013, 10:50 PM   #2640
CLL_OBP
Member#: 310435
12 Sp Limited
The service manual calls it a HC absorption filter. For it to have 'absorption' in the name, it must have charcoal in it.
Old 09-04-2013, 11:10 PM   #2641
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Must be the black material behind the netting.. Would you say it was "necessary"? I wouldn't.. I'd imagine it's just some "green" crap that's not truly necessary.
Old 09-05-2013, 02:07 AM   #2642
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
Yes sir.
Old 09-05-2013, 02:12 AM   #2643
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
You are correct.
It's when the car shut off UN burnt gas goes out the air box and this charcoal mesh thing get it.
That's why its a pzev
Old 09-05-2013, 02:24 AM   #2644
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
But does it do anything except "protect" the environment? IE, if I remove it, the car won't freak out, correct? lol
Old 09-05-2013, 12:32 PM   #2645
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I don't think it will mess up anything the car, but not sure.
For sure its for pzev.
My Chevy sonic turbo had this also I took it out and did nothing at all.
Old 09-05-2013, 01:03 PM   #2646
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
So if removing the filter does nothing at all, then shouldn't those of us with PZEV cars just leave that extra carbon filter alone? Why remove it if removing it doesn't improve anything?
sgoldste01 is offline   Reply With Quote
Old 09-05-2013, 02:04 PM   #2647
Blackmamba24kb
Member#: 330797
2012 Impreza 5dr Prm
Satin White Pearl
Originally Posted by gregorz4 View Post
Are those LEDs on the inside of the headlight or outside of it?
they are on the outside but underneath along the bottom and side of the headlight so you can't see them unless you get up close. they aren't noticeable unless you look for them.
Blackmamba24kb is offline   Reply With Quote
Old 09-05-2013, 02:17 PM   #2648
Blackmamba24kb
Member#: 330797
Satin White Pearl
Originally Posted by jfarabaugh View Post
pics with all lights off please
ill snap a pic after work today.
Originally Posted by SIA_worker View Post
Some info on parts used and how it was done? Ive wanted to do this for some time now.
all the stuff was bought on ebay. you are looking for the led strips with "SIDE GLOW emit"
i.e. http://www.ebay.com/itm/2x-Audi-styl...6e8662&vxp=mtr
I believe I purchased from the seller above, i got the longest one and just snipped off the excess (i think 24 is perfect measure, the one i had wires from both side to give you option on which side you want the wires to run which was convenient and just cut off one end). I think i got the 24inch so that it wraps along the bottom then up to the side towards the center of the grill.
buy a auto switch so that you dont have to splice into wiring (unless you dont mind) its a small box that hooks up to your battery and lights and once the car is turned on it stays on until you shut it off and the lights should stay on for 20 secs (walk me home feature) depends on the box (most have it). please note that some if not all these switch/box are cheaply made, ive gone through at least 2 of them already after several months. They have fuses but oddly enough the fuse doesnt go so i think its just the box/relay themselves. its easy to switch out but a pain to just take the time to do it.
http://www.ebay.com/itm/LED-Daytime-...4c6f5b&vxp=mtr
Old 09-05-2013, 02:23 PM   #2649
tenaciousZ
Member#: 342279
2012 Impreza Sport
I second that notion if there are no benefits.. what flow rate are those filters capable of? Might they be limiting to high flow air filters? A few cfm would be negligible and I'd rather promote clean air by leaving it alone until I can afford a Tesla lol.
Old 09-05-2013, 02:24 PM   #2650
Blackmamba24kb
Member#: 330797
Satin White Pearl
Originally Posted by foghelmut View Post
As long as there's no highway drone (70-80mph), I'm all in.
^^ same here. i dont mind the sound but the wife might haha so for my own sanity i prefer there not be a drone
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
