Old 06-28-2012, 04:02 AM   #401
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by Wes_888 View Post
Yes sir! I have. It is 9005. High beam functions are maintained.
So what would actually be better? HIDs (in a projector of course) or LEDs?
pkL is offline   Reply With Quote
Old 06-28-2012, 06:55 AM   #402
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by 12ImprezaSL
I liked the way that the RSB eliminated most of the understeer and less body roll while cornering.
My buddy changed both his SB before and it understeered but not as much as stock. So he put the original FSB back in and he likes it better because it almost 50/50.
base model or higher trim level? I think the sti bar is only 1mm larger than stock so I'm not so sure i want to try it, doesn't seem like much improvement to be had
flyboy1100 is online now   Reply With Quote
Old 06-28-2012, 07:00 AM   #403
FastJK
Member#: 317325
2012 Impreza Hatch
Projector. Leds look cool but they don't throw their light very far.
FastJK is offline   Reply With Quote
Old 06-28-2012, 08:06 AM   #404
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I'm wishing my Sport Premium came with the leather-wrapped steering wheel and shift knob found in the Sport Limited. I know the knob is easy to find and install. But what about the steering wheel? I don't want to lose my steering wheel controller buttons and functionality.
How hard would it be to get a steering wheel from a Limited? Would that be plug and play, or would software programming be required to get the new wheel's buttons to work?
Or does someone know of a quality way to add leather to the stock wheel?
sgoldste01 is offline   Reply With Quote
Old 06-28-2012, 08:10 AM   #405
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I might have just answered my own question:
http://www.wheelskins.com/
Has anyone used this product? Is it good?
Old 06-28-2012, 01:22 PM   #406
12ImprezaSL
Member#: 322198
2012 Impreza SL
I have a sport limited. Stock is 15mm RSB and and 19mm FSB
WRX stock is 16mm RSB and 21mm FSB
STI stock is 19mm RSB and 21mm FSB
2mm difference.
12ImprezaSL is offline   Reply With Quote
Old 06-28-2012, 01:47 PM   #407
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
2mm difference.
4mm difference for rsb, that would be worthwhile. In the service manual it states it is a 18mm bar
Old 06-28-2012, 02:39 PM   #408
imcausinmadrukis
Member#: 318978
Can you direct me to where you got your DRL bulbs from?
Website
Name brand bulb
Color temp
Bulb, HID or LED
Swap out swap in? No extra wiring done?
imcausinmadrukis is offline   Reply With Quote
Old 06-28-2012, 04:28 PM   #409
FastJK
Member#: 317325
2012 Impreza Hatch
Haven't personally used them but I hear great things. A lot of guys on the Tacoma forum I used to follow swore by them. As long as you take your time with the stitching they look factory. Good luck.
Old 06-28-2012, 09:46 PM   #410
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
Originally Posted by ans2k View Post
how does the high beam work if it is replaced by LED
It still flashes when you want it too.
Projectors.
Website
Name brand bulb
Color temp
Bulb, HID or LED
Here you go.
http://store.ijdmtoy.com/9005-9006-L..._fog_sku41.htm
LED Bulb.
Plug & Play. No extra wiring.
Wes_888 is offline   Reply With Quote
Old 06-29-2012, 04:53 AM   #411
pkL
Member#: 313093
2012 Impreza 2.0i
Good, that makes me feel better I just picked up a retrofit projector kit from the retrofit source.
Old 06-29-2012, 09:18 AM   #412
FastJK
Member#: 317325
2012 Impreza Hatch
Lucky, gosh. Wanna buy one for me too? Haha. That's gonna look sweet. Which one did you get?
Old 06-29-2012, 12:43 PM   #413
WStrembitsky
Member#: 323877
2012 Impreza Limited
Projectors.
Here you go.
LED Bulb.
Do you know if these will fit the actual fog lights? I have the Canadian HID Xenon headlights and would love to replace the fog light bulbs with something that matches the colour of the headlights.
WStrembitsky is offline   Reply With Quote
Old 06-29-2012, 01:12 PM   #414
1slowscoobie
Member#: 316880
2012 Impreza Sport
Fog lights are listed as PSX24W. Can search ebay/amazon for direct replacement... note that they may be even dimmer than the weak stock bulbs so check light output. Maybe someone else can confirm if you can use a different bulb or the same HB3 instead. Careful going HID with the fogs as you may melt the housing, check the HID retrofit threads for projector fits.
1slowscoobie is offline   Reply With Quote
Old 06-29-2012, 01:20 PM   #415
WStrembitsky
Member#: 323877
Thanks!
We don't really get a lot of fog in Edmonton where I live so the fogs are really more for appearance then anything. A weak LED in the right colour will look better than the stock bulbs.
Again, I appreciate the response.
Old 06-29-2012, 01:32 PM   #416
12ImprezaSL
Member#: 322198
2012 Impreza SL
Took it off before to put a WRX RSB and found out its only 1mm difference so I didn't bother. Got an STI RSB and put it in because it was a 19mm. Makes a big difference considering how much lighter our cars are. Less body roll and car feels more planted.
Old 06-29-2012, 03:10 PM   #417
pkL
Member#: 313093
2012 Impreza 2.0i
I got the Bi-xenon FX-R Stage III Kit with subbed in Matsu****a Gen 5 ballasts. Haha maybe if I win the lottery.
Old 06-29-2012, 03:38 PM   #418
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
I just installed a Kenwood single din Reciever and Sirius Sat radio in the car. The crutchfield kit did work but only because i salvaged the mounting brackets off of the stock stereo and cut the plastic ones off the Crutchfield one. Everything works. I no longer have voice reconition function on the existing radio but i wired the Axxess control module to communicate with the necessary functions volume, seek, mute, answer call, and mode Every steering wheel button works to perform a function.
Also Ran 2 RCA cables and a Remote cable incase i ever felt the need to install a 10" sub in the back.
auskip07 is offline   Reply With Quote
Old 06-29-2012, 08:34 PM   #419
Wes_888
Member#: 320291
Here you go! They make it for that bulb type too! Just less smd's...
http://store.ijdmtoy.com/SearchResul...?Search=psx24w
Old 06-29-2012, 08:37 PM   #420
Wes_888
Member#: 320291
Where did you get your STI rear sway bar? and how much?
big difference eh? hmmm... I want this.
Old 06-29-2012, 11:05 PM   #421
12ImprezaSL
Member#: 322198
2012 Impreza SL
Got it from someone that upgraded his STI sways. Got it for a 12 pack. You can find them for about $20-40 used sometimes.
Check the classifieds or maybe put up a WTB ad.
About 10 min to install and stock endlinks are fine with the 19mm.
If you have a base model, you will need the brackets, bolts and endlinks.
Old 06-29-2012, 11:22 PM   #422
freshrider
Member#: 312955
Hi guys.
How would I go stiffening up the suspensions for the impreza- ie sport tuned? Is it possible to just change the springs and shocks for this? I don't care how harsh the ride will be. I want it to ride like a BMW M. Thanks.
freshrider is offline   Reply With Quote
Old 06-29-2012, 11:42 PM   #423
12ImprezaSL
Member#: 322198
2012 Impreza SL
Originally Posted by freshrider View Post
Hi guys.
Go back 1 page
Seems like Tiens are out, H&Rs are pre production(2-3mo out) and I think Eibachs are out also.
Tien - 1.5 all around (SKS92-AUB00 or SKS84-AUB00)
H&R - 1.4 F, 1.3 R (HR-54463)
Eibach - 1.5 all around (EB-7725.140)
Struts(Koni, Tokico) are all still in R&D.
Not really possible on having it ride exactly like that.
If you want something close, I suggest coilovers. Those are not available yet. Haven't heard of any in R&D yet.
You can try springs on stock struts, it'll look nice but the ride quality/handling won't be too great. Stocks aren't meant to dampen the "sport" springs.
Upgrading the RSB would help a lot, and you will notice it.
Old 06-29-2012, 11:54 PM   #424
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i measured the stock bar tonight, 16.25mm FWIW
Old 06-30-2012, 12:31 AM   #425
Wes_888
Member#: 320291
Oh wow, you got a sweet deal!
I have the sport trim. So with the sports trim.. I wont need to buy all that other stuff?
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
