Old 04-12-2014, 09:06 PM   #4301
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Originally Posted by gregorz4 View Post
Caltech, just want to confirm what this mod actually does? What's the DRL aspect of it? When you switch your fogs on the drls turn off!
That's right. Fogs on, DRLs off. Not for looks, for function.
CalTech87 is offline   Reply With Quote
Old 04-13-2014, 12:27 AM   #4302
jsteg
Member#: 329271
2012 Impreza Limited
Ice Silver Metallic
Why not just make fogs the DRLs? That's what I did! Works great!
jsteg is offline   Reply With Quote
Old 04-13-2014, 11:37 AM   #4303
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Because I like my DRLs.
Old 04-13-2014, 11:54 AM   #4304
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
For those of you that have replaced your DRLs with something brighter that render your foglights nothing but a cosmetic asset Ive done some tinkering with the assistance of flyboy1100 in order to kill the DRLs when the fogs are turned on:
Post #174
http://forums.nasioc.com/forums/show...2578343&page=7
Nice... This is a much simpler solution than trying to add a switch to the DRLs.
Thanks, CalTech87!!
Tha Chakal is offline   Reply With Quote
Old 04-13-2014, 11:56 AM   #4305
jsteg
Member#: 329271
Ice Silver Metallic
So you like having dimmed high beams as the DRLs?? I thought you didn't want that because it wears out the bulbs faster.
Old 04-13-2014, 12:25 PM   #4306
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
I suppose you didnt read everything. I have LEDs for DRLs. They are VERY bright and should last, as some Asian hookers may say, a "rong time".
Should be doing a retrofit soon, that will be my hi-beam.
Old 04-13-2014, 07:52 PM   #4307
jsteg
Member#: 329271
Ice Silver Metallic
I suppose you didnt read everything. I have LEDs for DRLs. They are VERY bright and should last, as some Asian hookers may say, a "rong time". Should be doing a retrofit soon, that will be my hi-beam.
Ah, I gotcha!
Old 04-14-2014, 10:00 AM   #4308
Kuso_
Member#: 378830
2013 Impreza
CBS
Question for those with Rally Armor mudflaps.
How secure are your front flaps? The bracket is held by that lock pin and it seems very flimsy. I'm hearing some noise at highway speeds from the passenger mudflap and I'm not sure if it's the acutal flap or the bracket making noise.
Thanks!
Kuso_ is offline   Reply With Quote
Old 04-14-2014, 10:01 AM   #4309
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Thanks!
There is a thread on this, had some posts recently too.
It is the bracket...
Old 04-14-2014, 10:02 AM   #4310
imprezaowner72
Member#: 372009
2015 WRX
CWP
Well instead of going with the long screw to connect the bracket and the mudflap I just reused a short screws I had from my aero guards and I haven't had a problem with noise
imprezaowner72 is offline   Reply With Quote
Old 04-14-2014, 11:25 AM   #4311
Kuso_
Member#: 378830
2013 Impreza
CBS
Edit: found it http://forums.nasioc.com/forums/show....php?t=2550654
thanks
Old 04-16-2014, 01:39 PM   #4312
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
Anyone know if the front sway bar off from the 2015 wrx or sti will fit with our cars?
Wes_888 is offline   Reply With Quote
Old 04-16-2014, 01:47 PM   #4313
cris90
Member#: 316180
also wondering if the strut bar fit
cris90 is offline   Reply With Quote
Old 04-16-2014, 02:44 PM   #4314
Pnw Suby425
Member#: 343458
2012 Impreza
I am more interested in seating and steering wheel swapping between the 2015 wrx/sti and the 2012+ imprezas
Pnw Suby425 is offline   Reply With Quote
Old 04-16-2014, 03:10 PM   #4315
cris90
Member#: 316180
actually i know someone who swapped brz seats into a crosstrek, and being that the crosstrek and impreza have the same interior including seats, you could probably get it in,
Old 04-16-2014, 03:46 PM   #4316
cris90
Member#: 316180
BTW teaser this is the tune i'm getting next week:
Throttle plate position max
Requested torque (acceleration pedal)
Old 04-16-2014, 04:09 PM   #4317
Pnw Suby425
Member#: 343458
2012 Impreza
So do you know if aftermarket seats for the brz would fit??
Old 04-16-2014, 04:18 PM   #4318
cris90
Member#: 316180
Old 04-16-2014, 08:55 PM   #4319
Chris223
Member#: 308299
2012 Impreza Premium
Dark Grey Metallic
My guess is no I hear it's a completely different platform/chassis.
But I'm pretty sure the 08+ ones fit. Though most say they're no point in upgrading the front as it's 22mm stock and more than sufficient.
The front strut bar does fit off the 08+ WRX, I have the Perrin one, and it looks great. Doesn't do anything but dress up the engine bay
Chris223 is offline   Reply With Quote
Old 04-17-2014, 04:06 PM   #4320
webster354
Member#: 343343
2014 Impreza 5dr Ltd
Me too...
webster354 is offline   Reply With Quote
Old 04-17-2014, 08:47 PM   #4321
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Those of you with LED Turn Signals...
Just ordered some for myself and was reading about hyperflash of course. Ran across this forum:
http://www.driveaccord.net/forums/sh...ad.php?t=80648
This makes it seem as though load resistors are more of a gimmick than anything. If you cant simply change the resistance in the flasher module by replacing the resistor thats already in there, or even one person filed it down to change the resistance, then why use load resistors? I think this solves the problem at the root, that you dont need high power resistors as an extra load to dissipate heat.
I have a large number of resistors on hand, wattage ratings/ohm ratings, and plan to get to the bottom of this. Removed the module today just to verify ahead of time its location/accessibility/construction.
Any thoughts?
Old 04-17-2014, 10:56 PM   #4322
jsteg
Member#: 329271
Ice Silver Metallic
Those of you with LED Turn Signals... Just ordered some for myself and was reading about hyperflash of course. Ran across this forum: http://www.driveaccord.net/forums/sh...ad.php?t=80648 This makes it seem as though load resistors are more of a gimmick than anything. If you cant simply change the resistance in the flasher module by replacing the resistor thats already in there, or even one person filed it down to change the resistance, then why use load resistors? I think this solves the problem at the root, that you dont need high power resistors as an extra load to dissipate heat. I have a large number of resistors on hand, wattage ratings/ohm ratings, and plan to get to the bottom of this. Removed the module today just to verify ahead of time its location/accessibility/construction. Any thoughts?
First of all, adding resistance does not dissipate heat. As the load (resistance) increases, so does heat! Second, that doesn't look anything like my flasher module. Where did you find that?
Old 04-18-2014, 12:42 AM   #4323
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
The dissipate heat "theory" came from another forum. Obviously E = I x R, so more resistance or current will give you more voltage and thus heat.
Anyhow... I found it by looking at the service module, right behind the knee airbag. Looks damn similar to the one from the other forum thread I posted. Oh, I pulled the casing off, if that's whats misleading about it?
Old 04-18-2014, 02:38 AM   #4324
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
MRT Performance out of Australia is doing some things. Looks like the XV can get ecutek programming.
apexracer is offline   Reply With Quote
Old 04-18-2014, 10:55 AM   #4325
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
http://youtu.be/Hgc3UjW77c0
Interesting. I would very much like a tune once my warranty expires but a turbo... think Ill save that cash for a fun car in the future.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 05:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 12:18 PM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 11:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 11:58 PM
