Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 06-30-2012, 02:51 AM   #426
12ImprezaSL
Member#: 322198
2012 Impreza SL
Originally Posted by flyboy1100 View Post
i measured the stock bar tonight, 16.25mm FWIW
Use a micrometer? Base has none all others have 15mm. might be 16.25mm with the coating. Best thing to do is check the bushings. Says the size on there.
Originally Posted by Wes_888 View Post
Oh wow, you got a sweet deal!
I have the sport trim. So with the sports trim.. I wont need to buy all that other stuff?
Thanks. Nope, you should be good to go. I'll let you know this Sunday/Monday if I can find you one.
You ever get the Magnaflow?
12ImprezaSL is offline   Reply With Quote
Old 06-30-2012, 01:27 PM   #427
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Yes, i crawled underneath with a digital caliper. I was thinking the paint probably adds another 1mm or so
Old 06-30-2012, 05:34 PM   #428
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
You ever get the Magnaflow?[/quote]
Thanks man =)
I havent triggered the exhaust yet. Ive been thinking about it lots, even called a shop about it but money is tight right now. Gonna hold out for now.
Wes_888 is offline   Reply With Quote
Old 07-01-2012, 08:15 AM   #429
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Stock is 16 mm and the STi one is 19 mm.
pkL is offline   Reply With Quote
Old 07-05-2012, 10:23 PM   #430
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Originally Posted by IMPREZA 2012 View Post
The strut bar for Impreza 2012 is not yet available. A lot of these is for 2012 WRX or STI but nothing for 2.0l.
I already go to Ultraracing at Candiac Quebec, Canada and they told me that they gonna contact with Ultraracing Malaysia for our model.
I read in certain threads that the 2011 19mm Sti RSB will work on our 2012 imprezas.
gregorz4 is offline   Reply With Quote
Old 07-05-2012, 10:51 PM   #431
eps105
Member#: 205153
2014 Forester 2.5i
Venetian Red
I'll second that. I've been following these threads for many months and have read of several that say the WRX STi RSB is still a drop-in fit for the 2012's.
In fact, they're a drop-in fit for the 2010+ Outback, too, as many had discovered a couple years ago. I have them on my 2010 Outback and plan on pulling them when I trade it in for my 2013 Impreza and bolting them on.
You can order everything you need in one package here ( https://www.subaruonlineparts.com/pr...oducts_id=1267 ), and full details as they relate to installation on the Outback (which should be the same for the Impreza) can be found in the link in the product description of the link above.
eps105 is offline   Reply With Quote
Old 07-06-2012, 01:44 AM   #432
pkL
Member#: 313093
2012 Impreza 2.0i
I have the sway bar from a 2011 STi installed by the way. Easy installation and fits perfectly fine.
Old 07-06-2012, 08:07 AM   #433
darkbug
Member#: 317711
2012 Impreza 5-spd
Cherry
What kinda of improvement was there over the stock bar?
darkbug is offline   Reply With Quote
Old 07-10-2012, 02:10 AM   #434
pkL
Member#: 313093
2012 Impreza 2.0i
Cornering is a lot sharper and the car remains more flat. You can take corners faster? It is definitely worth it.
Old 07-10-2012, 02:23 AM   #435
pkL
Member#: 313093
2012 Impreza 2.0i
For those people who have plasti dipped their grille, does it kind of look "fuzzy" in certain parts? It seems to look smooth for the most part minus those areas.
But then again its a grille and I doubt anyone will be up close enough to enough to see the imperfections I hope? But I want it to be perfect.
Old 07-10-2012, 02:51 AM   #436
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
It almost looks like fingerprints, can see a hand/finger print in both shots in that area. Was it cleaned thoroughly before plastidipping? I wouldn't have noticed it if I wasn't looking though trying to figure out where h close up was.
SleepNMnky is offline   Reply With Quote
Old 07-10-2012, 11:44 AM   #437
pkL
Member#: 313093
2012 Impreza 2.0i
I washed and dried the area thoroughly before plasti dipping it and I held on to my bumper on the back while I was moving it around. I zoomed in on the top left portion of the grille where there is an opening for the air intake. Maybe I'm just anal. I guess taking the picture with my phone doesn't help matters either (there is some image noise).
Old 07-10-2012, 01:09 PM   #438
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
How many coats did you apply? Was it windy or dusty when you sprayed the grill? Could possibly be a result of static electricity.
italia490 is offline   Reply With Quote
Old 07-10-2012, 01:40 PM   #439
strychnine
Member#: 316108
Is changing the muffler going to affect the chance of passing smog check in CA? I would assume not but I don't know what an O2 sensor is so I'm not exactly knowledgeable.
strychnine is offline   Reply With Quote
Old 07-10-2012, 02:46 PM   #440
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
Muffler only affects sound.
saabarupp is offline   Reply With Quote
Old 07-10-2012, 04:16 PM   #441
strychnine
Member#: 316108
thanks.
So any 2.5" oval muffler should work in theory? Or is there something more to it?
Old 07-10-2012, 05:02 PM   #442
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Originally Posted by strychnine View Post
thanks.
Is the inlet/outlet 2.5"? The exhaust tubing is 2". You'd have to go 2" off the mid pipe and use a reducer off the inlet of the muffler. You'd could run 2.5" from the outlet to the tip.
Old 07-11-2012, 02:10 PM   #443
FlyerHazen
Member#: 320610
2012 2.0L
Since the 2011 STI 19mm OEM rear sway fits the '12 Impreza, would the Perrin rear sway for the 2011 STI would work for the '12 Impreza as well? Thanks!
FlyerHazen is offline   Reply With Quote
Old 07-11-2012, 02:16 PM   #444
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
did you just answer your question before you even posted it?
auskip07 is offline   Reply With Quote
Old 07-11-2012, 03:11 PM   #445
FlyerHazen
Member#: 320610
2012 2.0L
I may have ...I'm new to car ownership/Subaru/modding. Also, I'm a college kid on a tight budget and don't want to buy something that won't fit.
Old 07-11-2012, 03:16 PM   #446
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
If people are fitting it on the new impreza then i would venture to guess that it fits alright.
Do you know what that would do to the suspension warrenty?
Old 07-11-2012, 03:23 PM   #447
FlyerHazen
Member#: 320610
2012 2.0L
True. I wouldn't think adding a rear sway would void any warranty. Every 2012 model (other than the base) has a rear sway. There could be a thread for warranty worries.
Old 07-11-2012, 03:40 PM   #448
FlyerHazen
Member#: 320610
2012 2.0L
Link for the Perrin 2012 rear sway:
http://www.perrinperformance.com/sub...r-psp-sus-2xx1
Link for the Perrin 2008-2012 STI rear sway:
http://www.perrinperformance.com/sub...ar-psp-sus-23x
Old 07-11-2012, 03:43 PM   #449
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Wow, what's up with the 2x price difference?
sgoldste01 is offline   Reply With Quote
Old 07-11-2012, 03:54 PM   #450
FlyerHazen
Member#: 320610
2012 2.0L
Exactly. I don't know what's the difference...if the 2011 STI rear sway fits the 2012 Impreza, and the Perrin rear sway is a replacement for the stock STI rear sway, then the Perrin rear sway replacement SHOULD fit the 2012 Impreza.
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 12:18 PM
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-30-2011 12:31 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 11:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 11:58 PM
