Old 07-12-2012, 09:31 PM   #476
strychnine
Member#: 316108
Originally Posted by auskip07 View Post
Im pretty sure thats is argueing. Let me know how those springs work out. i was told by the dealership that springs would void a suspension warrenty issue
So much irony.
Also you should learn to search because they can't void the warranty unless they can prove it damaged whatever you're making a claim for.
strychnine is offline   Reply With Quote
Old 07-12-2012, 11:51 PM   #477
An owned guy
Member#: 313318
2012 Impreza
Deep Cherry Pearl
Originally Posted by wannabwrx_12
Looking to upgrade headlights to hid for 12 Impreza, found one in China. Not feeling to comfortable with that one. What does someone recommend?
Yeah i would also like some suggestions
An owned guy is offline   Reply With Quote
Old 07-13-2012, 12:01 AM   #478
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
I ordered mine from ddmtuning.com never had problems. There's came from China too.
MjSub2.0 is offline   Reply With Quote
Old 07-13-2012, 05:48 AM   #479
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
I recommend getting a retrofit project kit from the retrofit source. Here are the D2S installed.
pkL is online now   Reply With Quote
Old 07-13-2012, 01:12 PM   #480
imcausinmadrukis
Member#: 318978
Originally Posted by brockd View Post
i wouldn't think so. seems like it would be pretty easy to just cut off the stock muffler and weld in a different muffler that is the same length.
this is kind of a dumb question, but has anyone replaced their stock license plate lights with LEDs? want that hyper white look the cadillacs have.
I bought some from Amazon. PIAA brand. They are nice but not as bright as the ones on the lexus.
imcausinmadrukis is offline   Reply With Quote
Old 07-13-2012, 01:27 PM   #481
imcausinmadrukis
Member#: 318978
Has anyone had any issues with the rear bumper melting/damaged from doing a muffler delete?
Old 07-13-2012, 01:32 PM   #482
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
lol, yup. I had the muffler off for a day, put on a short exhaust finisher, but it was pointed straight at the rear bumper... drove 10 miles, and by the time I got home I smelled melted plastic. Took it off right away, and made a new exhaust finisher that points down to the road, no issues since. It's not noticeable unless you are under the car though.
One thing that is somewhat funny is that it popped out the tow hook cover, and of course those are going to be impossible to find for a while.
monkeyracer is offline   Reply With Quote
Old 07-13-2012, 01:58 PM   #483
imcausinmadrukis
Member#: 318978
The exhaust I bought and had welded.
My Exhaust by jmaiden91184, on Flickr
How its going to possible look like once I put it on.
Example of how it would look by jmaiden91184, on Flickr
Is the the second picture how your set up was originally? I might spray some plasti dip around the area (rear bumper)so it can absorb some of the heat and hopefully prevent the plastic from melting.
Old 07-13-2012, 02:13 PM   #484
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
That's a picture of my car....I have had that setup for quite some time without any issues or plastic being melted.
italia490 is offline   Reply With Quote
Old 07-13-2012, 02:32 PM   #485
imcausinmadrukis
Member#: 318978
Comparing it now I noticed you have more of a "J" shaped. It has more of a curved at the beginning of the pipe. Rather than the middle
Aerial View by jmaiden91184, on Flickr
After looking at it I might run into an issue with my pipe because of how far it extends.
Old 07-13-2012, 05:19 PM   #486
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
It does look like it extends out quite a bit from the flange. Test fit it and if its too close to the bumper then you'll know what you have to do
Old 07-13-2012, 08:12 PM   #487
Wes_888
Member#: 320291
2012 Impreza 4DR 5MT
nice job on the headlights! something I would love to do but too afraid to attempt it ( baking, painting, etc).
Wes_888 is offline   Reply With Quote
Old 07-13-2012, 08:36 PM   #488
strychnine
Member#: 316108
What brand of air filter would all of you recommend? Keep hearing horror stories of **** lining the intakes when you use K&N filters.
Edit: something like this good for 6 months living on a gravel road?
Old 07-13-2012, 09:38 PM   #489
imcausinmadrukis
Member#: 318978
Default Muffler Delete
Test fitted it and it is way too long. I don't know whether to cut the entire pipe and have it look like a 2-3 inches stub or find a way to bend the pipe...
2-3 inch stub.
Stub by jmaiden91184, on Flickr
My next issue how did you remove the exhaust brackets?
Exhaust Bracket by jmaiden91184, on Flickr
Did you use a mallet and hammer the black rubber piece that holds both metal pieces to the left?
Old 07-13-2012, 09:57 PM   #490
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
2-3 inch stub.
I dont think you should cut it. You don't want to lose the length and risk exhaust gasses getting inside the car. Any muffler shop should be able to take of it. Removing the exhaust off the hangars isn't too hard. You'll want to spray the portion that goes through and then use a long crow bar to pry them free.
Old 07-13-2012, 10:04 PM   #491
imcausinmadrukis
Member#: 318978
1. Spary with what? Or did you mean spread?
2. Pry to the left or right first?
Old 07-13-2012, 10:15 PM   #492
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Sorry about that..you'll want to spray the hangars with wd-40 or pb blaster. As far as starting in the left or right...doesn't matter really.
Old 07-13-2012, 10:40 PM   #493
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Just get a muffler put on by a shop and delete the resonator, sound so much deeper.
Old 07-13-2012, 11:36 PM   #494
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Do you have a video clip. I'd like to hear what it sounds like without a resonator
Old 07-14-2012, 04:22 AM   #495
MjSub2.0
Member#: 314973
2012 Impreza Sport
Satin White
Unfortunately I don't have a video camera and cell phone don't give it enough justice. Someone here did a YouTube . First with resonator then with out.
Old 07-14-2012, 10:01 AM   #496
IMPREZA 2012
Member#: 318422
2012 Impreza Limited
I just find it on Ebay Strut Bar, I already order can't wait to receive it.
http://www.ebay.ca/itm/Subaru-JAPAN-...#ht_500wt_1413
IMPREZA 2012 is offline   Reply With Quote
Old 07-14-2012, 07:07 PM   #497
Wes_888
Member#: 320291
Standard cross bar for all the different subbies? Let us know how you like it when you receive it.
Old 07-15-2012, 12:24 AM   #498
apexracer
Member#: 257754
2012 Impreza Sport P
Camilla Red Pearl
I was at the Big Northwest Subaru meet today, and I didn't see any 2012 Impreza's except one other and it was the sedan and it was that (not my favorite color) light blue or something.
apexracer is offline   Reply With Quote
Old 07-15-2012, 08:34 PM   #499
FlyerHazen
Member#: 320610
2012 2.0L
This looks sick. Where did you get this? How did you do it?
FlyerHazen is offline   Reply With Quote
Old 07-16-2012, 05:02 AM   #500
pkL
Member#: 313093
2012 Impreza 2.0i
I got the Bi-xenon Morimoto Mini Stage III Kit (D2S) off of the retrofit source, I got a buddy to help me with it. You got to take the bumper off to remove the lights, bake the lights and open them up, and then you would blackout/paint the chrome inside, do some cutting, install the shrouds, slot in the projectors, put in bulbs, connect ballast, harness, and relay, put lights together, install in car. Those would be most of the steps.
I'll upload some new pictures tomorrow, I have them installed in car now.
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
