Old 08-07-2012, 05:25 AM   #701
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Do you need bushings if your Impreza already has a RSB?
sgoldste01 is online now   Reply With Quote
Old 08-07-2012, 05:32 AM   #702
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Yes, because the original bushings are too small to fit the thicker 19mm unit. You need the get the correct size bushings to go with the new bar, the factory endlinks on the car will work with the 19mm unit.
uspopo is offline   Reply With Quote
Old 08-07-2012, 07:55 AM   #703
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, thanks.
Easy install? Is it true that the RSB must be installed with the car's weight on the rear wheels (that is, the car can't be jacked up with the rear wheels floating in the air), thereby forcing us garage monkeys to do this job with the rear wheels on ramps?
Old 08-07-2012, 08:10 AM   #704
uspopo
Member#: 317014
ISM
I think it took about 15-20 minutes to install at my buddy's shop but it was on a lift so I can't answer that.
Old 08-07-2012, 11:16 AM   #705
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Originally Posted by sgoldste01 View Post
OK, thanks.
I haven't heard of that until now, I actually had mine installed on a lift too. So I don't think it should be a problem.
pkL is offline   Reply With Quote
Old 08-07-2012, 11:23 AM   #706
ans2k
Member#: 315631
2012 Impreza Sport
OK, thanks.
i think that is only on some of them. i think the ones you have to have the wheels on the ground are the ones that says you have to reload. i think most do not have to do this.
ans2k is offline   Reply With Quote
Old 08-07-2012, 11:29 AM   #707
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Interesting. I know that installing/replacing a RSB on a VW Golf requires that the wheels be loaded with the car's weight. I assumed it was the same with all RSB installations.
Old 08-07-2012, 02:04 PM   #708
leeden
Member#: 41654
2005 Impreza WRX STi
2012 Sport Limited
I installed my RSB with the wheels off the ground and on jack stands. Only thing is, I have no idea how much torque to apply to the bolts.
leeden is offline   Reply With Quote
Old 08-07-2012, 02:20 PM   #709
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
According to my service manual, tighten the Stabilizer Link Assembly to 28 ft-lb. Tighten the Clamp - Stabilizer Bushings to 22 ft-lb.
Hope this helps.
Old 08-07-2012, 02:31 PM   #710
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
NOTICE!!!!!
Since I was looking up the torque specs in my previous post, I decided to locate the actual procedure for removing and replacing the RSB. The installation procedure begins as follows:
CAUTION:
  • Be sure to use a new flange nut and self-locking nut.
  • Always tighten the bushing in the state where the vehicle is at curb weight and the wheels are in full contact with the ground.
  • Install the clamp - stabilizer bushing with the "G" character facing upward.
  • When installing, align the edge of identification point (a) to the end of face of the bushing (b).
It looks to me like you can't just randomly bolt the new RSB on. As I was asking earlier, the car should be loaded when installing the new RSB. Just thought you guys should know, because it sounds like people are installing new RSBs without following the recommended procedure.
Also note that I just added more detail to the torque specs in my previous post.
Old 08-07-2012, 02:57 PM   #711
uspopo
Member#: 317014
ISM
Great post and info. My buddy owns a Midas and all his mechanics are ASE certified so I have the utmost faith in their knowledge and ability. This isn't a speed shop of car tinkerers...
Old 08-07-2012, 03:05 PM   #712
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
That's good. But many of us are car tinkerers, and some of us tinker without using/having proper documentation. Doing so can be problematic, and possibly even dangerous.
From the way I'm talking, you might think that I'm a technical writer by trade. And you'd be right.
I don't do anything without referring to the documentation, if possible. I have often wished that women and children came with documentation.
Old 08-07-2012, 03:26 PM   #713
uspopo
Member#: 317014
ISM
Haha, documentation would make everything easier. If I had the guts to tinker I definitely would not be unbolting and bolting stuff without the proper specs and tools in hand. I let the experienced guys that do that stuff for a living do the hard stuff for me and if I can do the simple stuff by myself and save a couple bucks I will such as installing my Sport Grill.
Stan
Old 08-07-2012, 09:14 PM   #714
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
I also installed a "11 Sti RSB 21mm on my Impreza. It came with the larger bushings. I installed it with no ramps or lift, just creeped under the car and installed it laying on my back. took about 45 minutes. Was hard to figure out how to unscrew the nuts in such a tight position but I found it out and it was pretty easy. Ride quality is a bit better around turns, less body roll. Worthy upgrade to increase driving fun and quality.
gregorz4 is offline   Reply With Quote
Old 08-07-2012, 09:47 PM   #715
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
It's good that you did this with the wheels on the ground. Apparently that's the right way.
Old 08-07-2012, 11:21 PM   #716
pRiMe DiReCtIvE
Member#: 301387
2012 Impreza HB
Black/Dark Grey
Just want to confirm, are the '11 STi rsb 19 mm or 21mm?
pRiMe DiReCtIvE is offline   Reply With Quote
Old 08-08-2012, 02:57 AM   #717
pkL
Member#: 313093
2012 Impreza 2.0i
19 mm.
Old 08-09-2012, 02:18 AM   #718
FlyerHazen
Member#: 320610
2012 2.0L
Originally Posted by pkL View Post
Which one in particular would you have a link and the model?
My apologies for the late response, I just got back to college. I know the inlet from the mid-pipe is 2", so some modding may be required depending on which axle back. These are the ones I found for HKS universal mufflers:
http://www.andysautosport.com/subaru...t/mufflers/hks
I don't know yet which one I'll buy. I may just wait for a axle back or cat back specifically designed for our Imprezas. Considering our car isn't really for "tuners", we may have to wait a bit.
FlyerHazen is offline   Reply With Quote
Old 08-09-2012, 02:59 AM   #719
pkL
Member#: 313093
2012 Impreza 2.0i
Yeah I would too much prefer an axle back or a cat back specifically made and designed for our cars.
Old 08-09-2012, 11:51 AM   #720
gregorz4
Member#: 316869
2012 Impreza Sport
Dark Gray
Sorry I meant 19mm, my sport limited came with a smaller one.
The one that came with my '12 Sport Impreza must have been 17mm
Old 08-09-2012, 11:55 AM   #721
pkL
Member#: 313093
2012 Impreza 2.0i
The one with the 2012 Sport Impreza should be 15 mm.
Old 08-09-2012, 02:15 PM   #722
dubiousmike
Member#: 327473
2012 Impreza Sport L
Is the ride prohibitively stiffer when choosing the 21 mm over the 19mm?
dubiousmike is offline   Reply With Quote
Old 08-09-2012, 02:20 PM   #723
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
15mm according to the repair manual
Old 08-09-2012, 10:40 PM   #724
pkL
Member#: 313093
2012 Impreza 2.0i
I measured the bar with a micrometer, it's 17 mm with the paint but its actually 15 mm.
Old 08-09-2012, 10:49 PM   #725
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
mine was 16.25mm with the paint. we might have measure different locations
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
