Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 03-23-2012, 12:05 AM   #51
Grimpreza
Member#: 305300
2012 Impreza
Originally Posted by pkL View Post
Hey man I'm interested in how your car looks right now too, could you post some pictures?
+1. Of all the mods if possible.
Grimpreza is offline   Reply With Quote
Old 03-23-2012, 11:12 AM   #52
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Will do guys! I'll take some after work today and post them up.
italia490 is offline   Reply With Quote
Old 03-23-2012, 04:23 PM   #53
Grimpreza
Member#: 305300
2012 Impreza
Old 03-23-2012, 05:56 PM   #54
alanomfg
Member#: 314402
In case anyone is wondering, this is how the OEM grill with chrome inserts looks plasti dipped.
BEFORE:
MID-WAY:
AFTER:
Am now currently waiting on the back emblem to finish drying.
EDIT -
Here's a pic of the back emblem. Definitely not as quality of a job as the grill, very rushed. Probably going to re-do it within the next few days and fill in those gaps/layer more coats for a stronger, more solid finish.
Forgot to take a before pic but you all know what the subie emblem looks like anyhow. (hopefully)
alanomfg is offline   Reply With Quote
Old 03-23-2012, 09:17 PM   #55
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I took pictures but how do you upload them?
Old 03-23-2012, 09:51 PM   #56
Grimpreza
Member#: 305300
2012 Impreza
You can follow these steps: http://pnwriders.com/motorcycle-talk...ures-free.html
Old 03-24-2012, 12:33 AM   #57
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
BEFORE:
MID-WAY:
AFTER:
EDIT -
That looks awesome, I always found the chrome insert a bit too bling.
pkL is offline   Reply With Quote
Old 03-24-2012, 12:35 AM   #58
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Thanks for the link
Here are the pictures...
http://s1161.photobucket.com/albums/q507/strunz490/
Old 03-24-2012, 07:23 AM   #59
79letour
Member#: 302570
2012 Impreza
Ice Silver Oil Burner
That grille looks nice.
79letour is offline   Reply With Quote
Old 03-25-2012, 09:46 AM   #60
monkeyracer
Member#: 308583
2012 Impreza Sport
OBP/DGM 5-Sp
Thanks for the link
Thanks for sharing!
Where did you get the LEDs from, and do you have the part numbers?
I want to do the full LED swap as well, and might copy you on the lower rear reflector idea.
Did you notice any difference in light output of the fogs? At night do the tail/brake lights seem brighter?
monkeyracer is offline   Reply With Quote
Old 03-25-2012, 10:03 AM   #61
pkL
Member#: 313093
2012 Impreza 2.0i
I have a 2012 Impreza 5 door wagon and am itching to mod it. So far I have 20% tint all around except for the windshield, almost a full LED conversion in and out with the exception of the DRL's. I have added the LED reflectors to the rear bumper and wired them up with the brake lights. I have a VG Sharkfin Antenna on order, plasti-dipped the front grill, added Hella supertones with the blue powder coated surround. Plans are to add a Kartboy or Cobb short shifter. I'm leaning towards the Cobb because of it's adjust-ability. When UEL headers from rallisport racing become available, I plan on getting a set to have the boxer rumble. I need to get under the car and take some pics and measurements since it might be possible that the existing ones for the 2.5i might bolt up with little to no modifications. Rally armor mud flaps are also planned. They should be released soon. Rear roof spoiler and front lip spoiler are also planned when less expensive versions come out. Stabilizer bars and end links should carry over from the 08+ WRX. A few other dress up items like JPM Coachworks shift boot and e-brake boot, different lugnuts, license plate delete are also planned.
Which sharkfin antenna did you order? I don't see one on the site that fits the new Impreza.
Old 03-25-2012, 12:15 PM   #62
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
(Thanks for sharing!
Did you notice any difference in light output of the fogs? At night do the tail/brake lights seem brighter?)
I purchased the LED's off of Ebay. The front and rear turn signals are 7440. If you change those, you'll also want to consider a flasher meant for LED's. I got mine from Fast WRX http://www.fastwrx.com/coledtusibu.html. It costs $19 and prevents hyper flashing. The brake light LED's are 7443-CK. For what ever reason this is a hard bulb to find. YOu might want to check Vleds.com You can use a regular 7443 but you will have to rearrange the leads. Check out this link for a DIY: http://www.scionlife.com/forums/show...&postcount=182. There is a pretty good write up on what you need to do to get the bulbs working properly otherwise you'll keep blowing fuses. The lower fogs are H16. I found these a bit of a pain to install. They have little tabs on either side that need to be cut off so they fit properly. A really sharp blade works great. As far as brightness goes, they seem brighter but I never got the impression that the lights were proper fog lights. They seem to be more for looks.
As far as swapping out the bulbs in the headlights is best done by removing them off the car, which requires removal of the bumper. At night the brake lights are pretty bright. I'll try and get a good picture tonight and post it up.
All the other bulbs are T10. I used T10 for the reverse lights but I am not happy with the output on them so I will be switching those out for T10 Wedge CREE R5 Emitter 7W. For the DRL's I will be using their 6K white 7.5W LED DRL. The map lights in the interior are also T10. The dome light on the roof takes a 31MM festoon bulb.
The lower reflectors are easy to install and take about 30 minutes to install. The instructions that are provided are pretty straight forward, however it would appear the wiring configuration is a bit different. The instructions indicate that you if you want to run the LED reflectors as brake lights, that you need to tap into the pink wire. I found this not to be the case. Tapping into the pink wire will make them run as running lights. You'll need to tap into the green wire instead.
Let me know if you have any other questions.
Old 03-25-2012, 12:17 PM   #63
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I ordered the sharkfin for the 09 model. I had to have them add the color code before I placed the order though. They have two different models or the antenna and the one you need is based on the base of the antenna. You should be fine ordering the same one I did but if you are unsure wait till I get mine and I'll post pics when I get it.
Old 03-25-2012, 09:02 PM   #64
PAO56
Member#: 304676
2012 Impreza Ltd 5DR
Deep Cherry Pearl
would love to know more details on the lower rear bumper reflector conversion to LEDs....where did you get them from??
PAO56 is offline   Reply With Quote
Old 03-25-2012, 09:31 PM   #65
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
You can find them here:
http://shop.jwmotoring.com/product.sc?productId=493
Great customer service and fast shipping.
Old 03-26-2012, 06:50 AM   #66
pkL
Member#: 313093
2012 Impreza 2.0i
I think I'm going to wait a bit and see how it goes for you, I'm interested in getting one for sure.
I watched the 2 videos on the LED bumper reflectors, they're pretty cool. How was the installation process?
Old 03-26-2012, 09:54 AM   #67
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
Installation was pretty easy. There are two tabs behind the reflector that you need to squeeze and the reflector pops right out. The directions are pretty straight forward and the reflectors can be wired to run as brake lights, running lights or turn signals. I cannot comment on wiring them up as turn signals since I wired mine up as brake lights. The wire coloring is the same as previous models however the configuration is different. The instructions indicated to tap into the pink wire for brake lights but as it turned out, this was for the running lights. The brake light wire is the green one.
The kit comes with everything you need. You'll just need a pair of wire strippers and a crimper plus a 10mm socket to remove the tail lights.
Old 03-26-2012, 10:35 AM   #68
pkL
Member#: 313093
2012 Impreza 2.0i
Thanks that sounds easy enough. I'll order a set then, as running lights the leds will just stay lit and doesn't really serve any other purpose?
Old 03-26-2012, 11:16 AM   #69
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
If you wire them up as running lights they will come on when you turn your lights on one notch. I found them to be a tad bit too bright for my liking but my original intention was to wire them up as brake lights anyway.
Old 03-26-2012, 12:04 PM   #70
PAO56
Member#: 304676
Deep Cherry Pearl
thanks...I thought that was the vendor...I has emailed them and ask about fit for these and the rear hatch led lighting to see if they all fit the 12 Impreza.....glad to know at least the led bumper lights do!!
Old 03-27-2012, 12:53 AM   #71
pkL
Member#: 313093
2012 Impreza 2.0i
I leave my lights on auto so basically when the headlights come on not DRL they would come on too? I was thinking to hook them up as brake lights too.
Old 03-27-2012, 11:22 AM   #72
jack9778
Member#: 310398
Where did u get the LED fog light bulbs?
jack9778 is offline   Reply With Quote
Old 03-27-2012, 12:58 PM   #73
italia490
Member#: 308742
2012 Impreza Sport
Marine Blue Pearl
I purchased the LED fog light bulbs off Ebay. The bulb is an H16. The bulb themselves are actually pretty bright but light projection is minimal. I got them more to match the color of the 6K HID's I have in the headlights. I plan on looking for a better solution to having functional fog lights.
Old 03-27-2012, 01:38 PM   #74
jack9778
Member#: 310398
DONT GET HID fog light,it melted the housing,thats what I got!!
Old 03-27-2012, 01:53 PM   #75
jack9778
Member#: 310398
Is this possible to tell me which exactly did u buy from ebay?Maybe you could send me the link.thanks so much
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 1 12-29-2011 11:31 PM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
Message Board Statistics All times are GMT -4. The time now is 02:02 AM.
